电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » R8C Tiny Reading Rotary Encoders
2010-01-15 14:43:22     打赏
//Encoder
#include "rskr8c27def.h"
#include "ior8c26_27.h"
#include "digitIO.h"
#define encoder0PinA 15  //INT1
#define encoder0PinB 33  //INT3
#define RawPinA      p1_5
#define RawPinB      p3_3
int encoder0Pos ;
void encoder_init()
  //    INT1 Interrupt Setting
  //Note: Set INT1 hardware interrupt pin to input
  //Note: By default, INT1 pin is at P1_7 pin
  //To change to INT1 pin at P1_5 pin, set tiosel_traioc=1
  //To change to INT1 pin at P3_6 pin, set int1sel=1
  int1ic=0x04;
  //Set interrupt priority level and active edge(int1ic bit 0, 1, 2 and 4)
  int1en=1;
  //Input enabled(inten bit 2)
  int1pl=1;
  //Both edges selected(inten bit 3)
  int1f0=1;int1f1=0;
  //Filter with f1 sampling selected(intf bit 2 and 3)
  tiosel_traioc=1;
  //    INT3 Interrupt Setting
  //Note: Set INT3 hardware interrupt pin to input
  int3ic=0x04;
  //Set interrupt priority level and active edge(int3ic bit 0, 1, 2 and 4)
  int3en=1;
  //Input enabled(inten bit 6)
  int3pl=1;
  //Both edges selected(inten bit 7)
  int3f0=1;int3f1=0;
  //Filter with f1 sampling selected(intf bit 6 and 7)
  encoder0Pos = 0;
void encoder_stop()
  int1en=0;
  int3en=0;
void encoder_start()
  int1en=1;
  int3en=1;
void encoder_reset()
  encoder0Pos = 0;
#pragma vector= INT1
__interrupt void INT1_ISR(void)
  // look for a low-to-high on channel A
  //if (digitalRead(encoder0PinA) == HIGH) {
  if (RawPinA == 1) {
    if (RawPinB == 0) {
      encoder0Pos = encoder0Pos + 1; // CW
    else {
      encoder0Pos = encoder0Pos - 1;  // CCW
  else   // must be a high-to-low edge on channel A
    if (RawPinB == 1) {
    else {
关键词: Reading     Rotary     Encoders     e
