电子产品世界 » 论坛首页 » 企业专区 » Xilinx » 时序约束
共3条 1/1 1 跳转至
时序约束
2010-05-13 16:11:49     打赏
我用的是ise11.1版本,芯片是xilinx spartan3an系列的 xc3s700an,在时序约束后出现下面的warning,时序仿真不出现结果,请高手指点,非常感谢啊!
WARNING:PhysDesignRules:372 - Gated clock. Clock net adc_OBUF is sourced by a combinatorial pin. This is not good design practice. Use the CE pin to control the loading of data into the flip-flop.
WARNING:Timing:3175 - clk does not clock data to cp
WARNING:Timing:3225 - Timing constraint COMP "cp" OFFSET = OUT 1000 ns AFTER COMP "clk" REFERENCE_PIN BEL "adc"; ignored
   during timing analysis
WARNING:Timing:3224 - The clock clk associated with OFFSET = OUT 13 ns AFTER COMP "clk"; does not clock any registered
   output components.
WARNING:Timing:3225 - Timing constraint OFFSET = OUT 13 ns AFTER COMP "clk"; ignored during timing analysis
WARNING:Timing:3224 - The clock clk associated with TIMEGRP "grp_ado" OFFSET = OUT 1000 ns AFTER COMP "clk"
   REFERENCE_PIN BEL        "adc" "RISING"; does not clock any registered output components.
WARNING:Timing:3225 - Timing constraint TIMEGRP "grp_ado" OFFSET = OUT 1000 ns AFTER COMP "clk" REFERENCE_PIN BEL
   "adc" "RISING"; ignored during timing analysis
WARNING:Route:455 - CLK Net:adc_OBUF may have excessive skew because     1 CLK pins and 1 NON_CLK pins failed to route using a CLK template.
   COMP "clk" REFERENCE_PIN BEL "adc"; ignored during timing analysis
WARNING:Timing:3224 - The clock clk associated with OFFSET = OUT 13 ns AFTER COMP "clk"; does not clock any registered output components.
   OUT 1000 ns AFTER COMP "clk" REFERENCE_PIN BEL        "adc" "RISING"; does
   AFTER COMP "clk" REFERENCE_PIN BEL        "adc" "RISING"; ignored during
   timing analysis
关键词: 时序     约束     WARNING     Timing     cloc
2010-05-18 09:03:31     打赏
此问题已解决,多谢大家的关注啊!
给adc_obuf的path再特别约束一下就好了
2012-10-25 11:15:56     打赏
你好,我也遇到这个问题了,我新手,你是怎么设置的,都设置了些什么呢
共3条 1/1 1 跳转至
