电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » 分享一下FPGA的串口通信程序
共11条 1/2 1 2 跳转至
分享一下FPGA的串口通信程序
2011-10-12 21:32:29     打赏
串口通信 UART通信
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity UART is                    --通用异步串行收发器实体
    Port ( UART_clk    : in  STD_LOGIC;          --收发器时钟输入,50MHz
     UART_rst   : in std_logic;
     UART_TX_buf   : in STD_LOGIC_VECTOR(7 downto 0);
     UART_TX_TI  : out std_logic;
     UART_TX_EN  : in std_logic;
     UART_TXD   : out std_logic;
           UART_baudrate  : out  STD_LOGIC);         --收发器波特率输出19200的14倍频(测试完成后可以取消)
end UART;
architecture Behavioral of UART is
signal baudrate_counter :std_logic_vector(6 downto 0):="0000000";  --波特率发生器分频计数器
signal baudrate_out :std_logic:='0';           --波特率发生器波特率信号
signal TX_clk : std_logic:='0';
signal tx_clk_counter : std_logic_vector(3 downto 0) :="0000";
type   TX_STATE is (TX_idle,TX_transfer);
signal TX_current_state,TX_next_state : Tx_state;
signal TX_buf_shift : std_logic_vector(9 downto 0):= "0111111111";
signal TX_counter :std_logic_vector(3 downto 0):="0000";
signal TX_start : std_logic:='0';
signal TXD_buf:  std_logic:='0';
signal TX_TI : std_logic:='1';
begin
baudrate: process (UART_clk)              --波特率发生器进程
begin
  if rising_edge(UART_clk) then             --对输入时钟进行分频获得所需波特率的14倍频
   if (baudrate_counter >= "1011100") then
    baudrate_counter <= "0000000";
    baudrate_out <= not baudrate_out;
   else
    baudrate_counter <= baudrate_counter + '1';
    baudrate_out <= baudrate_out;
   end if;
  end if;
end process;
UART_baudrate <= baudrate_out;             --将波特率信号传给输出接口
sync_proc_tx: process(baudrate_out,UART_rst)      --同步进程,状态机转换
begin
  if (UART_rst = '1') then
   tx_current_state <= tx_idle;
  elsif (falling_edge(baudrate_out)) then
   tx_current_state <= TX_next_state;
  end if;
end process;
comb_proc_tx: process(baudrate_out,UART_rst)      --组合逻辑,状态机转换、输出
begin
   TX_next_state <= TX_idle;
   TX_counter <= "0000";
   TXD_buf <= '1';
   TX_start <= '0';
   TX_TI <= '1';
   TX_clk_counter <= "0000";
   TX_buf_shift <= "1111111111";
  elsif (rising_edge(baudrate_out)) then
   case TX_current_state is
    when TX_idle =>
     if (UART_TX_EN = '1' and TX_TI = '1') then     --如果满足发送起始条件
      TX_next_state <= TX_transfer;           --转换下一状态到发送
      TX_counter <= "1010";               --发送bit计数器置数,发送10个bit,8bit数据加上开始结束位
      TXD_buf <= '1';                  --发送寄存器发送‘1’
      TX_start <= '1';                 --发送过程标志
      TX_TI <= '0';                   --发送进行中标志,表示发送器不可用
      TX_clk_counter <= "1101";             --分频计数器置数
      TX_buf_shift <= '1' & UART_TX_buf & '0';     --寄存器保存数据与开始结束位
     else
      TXD_buf <= '1';
      TX_start <= '0';
      TX_TI <= '1';
     end if;
    when TX_transfer =>
     if (TX_start = '1' and TX_TI = '0' and TX_counter /= "0000") then     --进入正常发送状态
      if (TX_clk_counter >= "1101") then                   --如果分频完成
       TX_next_state <= TX_transfer;                     --没有发送完成,继续进入发送状态
       TX_counter <= TX_counter - '1';                    --发送bit计数器自减
       TXD_buf <= TX_buf_shift(0);                      --发送数据
       TX_start <= '1';                           --发送过程标志继续允许
       TX_TI <= '0';                             --发送器不允许使用
       TX_clk_counter <= "0000";                       --分频计数器清灵,继续下一次
       TX_buf_shift <= '1' & TX_buf_shift(9 downto 1);            --数据移位
      else
       TX_counter <= TX_counter;
       TXD_buf <= TXD_buf;
       TX_start <= '1';
       TX_TI <= '0';
       TX_clk_counter <= TX_clk_counter + '1';
       TX_buf_shift <= TX_buf_shift;
      end if;
     else
      TXD_buf <= '1';
      TX_start <= '0';
      TX_TI <= '1';
     end if;
    when others =>
     TXD_buf <= '1';
     TX_start <= '0';
     TX_TI <= '1';
   end case;
  end if;
end process;
UART_TXD <= TXD_buf;
UART_TX_TI <= TX_TI;
end Behavioral;
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
entity transmitter is
port(cs,clk,rx:in std_logic;
indata:in std_logic_vector(7 downto 0);
txd,ti:out std_logic);
end transmitter;
architecture tr1 of transmitter is
signal sig_count:std_logic_vector(3 downto 0);
signal sig_ti,sig_ti1,sig_txd,sig_buffer:std_logic;
signal sig_data:std_logic_vector(7 downto 0);
signal sig_txddata:std_logic_vector(9 downto 0);
begin
process(cs,clk,rx)
begin
if(clk'event and clk='1')then
if(cs='0')then
if(sig_buffer='0')then
if(rx='0')then
for i in 8 downto 1 loop
sig_txddata(i)<=indata(i-1);
end loop;
sig_txddata(9)<='0'; --加起始位
sig_data<=indata;
sig_buffer<='1';
end if;
else
for i in 9 downto 1 loop
sig_txddata(i)<=sig_txddata(i-1);
end loop;
sig_txd<=sig_txddata(9);
sig_txddata(0)<='1'; --加停止位
if(sig_count="1000")then
sig_count<="0000";
elsif(sig_count="0000"and sig_ti='1')then
sig_buffer<='0';
sig_ti<='0';
else
sig_count<=sig_count+'1';
sig_ti<='1';
end if;
end if;
end if;
end if;
end process;
process
begin
if(sig_ti='0')then
txd<='1';
else txd<=sig_txd;
end if;
end process;
ti<=not sig_ti;
end tr1;
关键词: 分享     一下     串口     通信     程序     logic     down
2011-10-13 11:41:34     打赏
好东西,不错
2011-10-13 13:35:02     打赏
可惜我学的是verilog语言
2011-10-13 22:31:12     打赏
   我先是学习的VHDL后也学过verilog.相比较来说,如果有C语言背后者容易上手,编写测试程序相对容易。
2011-10-13 22:51:09     打赏
有C语言的话Verilog比较容易一些
2011-11-23 14:42:22     打赏
不错啊,厉害的很啊!
2011-12-22 12:00:07     打赏
tks
2011-12-22 12:27:48     打赏
学习了。
2013-04-11 08:12:22     打赏
好东西,。。。。
2013-04-11 08:49:35     打赏
这个是传说中的VHDL语言 好高级的样子啊~~
共11条 1/2 1 2 跳转至
