电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » jianzhangx ARM DIY进程贴
共77条 8/8 |‹ 3 4 5 6 7 8 跳转至
2012-05-30 21:40:30     打赏
71楼
ping开发板网卡:
2012-05-31 22:34:38     打赏
72楼
web链接:
2012-06-01 22:57:11     打赏
73楼
准备做个MP3播放
2012-06-01 23:18:47     打赏
74楼
硬解码还是软解码?
2012-06-02 22:35:52     打赏
75楼
调试中~~~~~~~
2012-06-10 21:41:21     打赏
76楼
抱歉啊,最近没时间更新了
2012-06-12 22:30:57     打赏
77楼
NRF24L01 驱动函数
const u8 TX_ADDRESS[TX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //发送地址
const u8 RX_ADDRESS[RX_ADR_WIDTH]={0x34,0x43,0x10,0x10,0x01}; //发送地址
//初始化24L01的IO口
void NRF24L01_Init(void)
 GPIO_InitTypeDef GPIO_InitStructure;
 RCC_APB2PeriphClockCmd(RCC_NRF24L01_CE, ENABLE);           //使能GPIO的时钟
    GPIO_InitStructure.GPIO_Pin = NRF24L01_CE;              //NRF24L01 模块片选信号
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;           //推挽输出
 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
 GPIO_Init(GPIO_NRF24L01_CE, &GPIO_InitStructure);
 RCC_APB2PeriphClockCmd(RCC_NRF24L01_CSN, ENABLE);          //使能GPIO的时钟
    GPIO_InitStructure.GPIO_Pin = NRF24L01_CSN;
 GPIO_Init(GPIO_NRF24L01_CSN, &GPIO_InitStructure);
 Set_NRF24L01_CE;                                           //初始化时先拉高
    Set_NRF24L01_CSN;                                   //初始化时先拉高
    //配置NRF2401的IRQ
 GPIO_InitStructure.GPIO_Pin = NRF24L01_IRQ;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU  ;     //上拉输入
 GPIO_Init(GPIO_NRF24L01_IRQ, &GPIO_InitStructure);
 GPIO_SetBits(GPIO_NRF24L01_IRQ,NRF24L01_IRQ);
 SPI2_Init();                                       //初始化SPI
 Clr_NRF24L01_CE;                                 //使能24L01
 Set_NRF24L01_CSN;                                  //SPI片选取消
//上电检测NRF24L01是否在位
//写5个数据然后再读回来进行比较,相同时返回值:0,表示在位;否则返回1,表示不在位
u8 NRF24L01_Check(void)
 u8 buf[5]={0XA5,0XA5,0XA5,0XA5,0XA5};
 u8 buf1[5];
 u8 i;
 NRF24L01_Write_Buf(SPI_WRITE_REG+TX_ADDR,buf,5);//写入5个字节的地址.
 NRF24L01_Read_Buf(TX_ADDR,buf1,5);              //读出写入的地址
 for(i=0;i<5;i++)if(buf1[i]!=0XA5)break;
 if(i!=5)return 1;                               //NRF24L01不在位
 return 0;                                  //NRF24L01在位
//通过SPI写寄存器
u8 NRF24L01_Write_Reg(u8 regaddr,u8 data)
 u8 status;
    Clr_NRF24L01_CSN;                    //使能SPI传输
   status =SPI2_ReadWriteByte(regaddr); //发送寄存器号
   SPI2_ReadWriteByte(data);            //写入寄存器的值
   Set_NRF24L01_CSN;                    //禁止SPI传输
   return(status);                  //返回状态值
//读取SPI寄存器值 ,regaddr:要读的寄存器
u8 NRF24L01_Read_Reg(u8 regaddr)
 u8 reg_val;
   reg_val=SPI2_ReadWriteByte(0XFF);//读取寄存器内容
   return(reg_val);                 //返回状态值
//在指定位置读出指定长度的数据
//*pBuf:数据指针
//返回值,此次读到的状态寄存器值
u8 NRF24L01_Read_Buf(u8 regaddr,u8 *pBuf,u8 datalen)
 u8 status,u8_ctr;
   status=SPI2_ReadWriteByte(regaddr);   //发送寄存器值(位置),并读取状态值
  for(u8_ctr=0;u8_ctr<datalen;u8_ctr++)pBuf[u8_ctr]=SPI2_ReadWriteByte(0XFF);//读出数据
   Set_NRF24L01_CSN;                     //关闭SPI传输
   return status;                        //返回读到的状态值
//在指定位置写指定长度的数据
//*pBuf:数据指针
//返回值,此次读到的状态寄存器值
u8 NRF24L01_Write_Buf(u8 regaddr, u8 *pBuf, u8 datalen)
 u8 status,u8_ctr;
   status = SPI2_ReadWriteByte(regaddr);                //发送寄存器值(位置),并读取状态值
   for(u8_ctr=0; u8_ctr<datalen; u8_ctr++)SPI2_ReadWriteByte(*pBuf++); //写入数据
//启动NRF24L01发送一次数据
//txbuf:待发送数据首地址
//返回值:发送完成状况
u8 NRF24L01_TxPacket(u8 *txbuf)
 u8 state;
 Clr_NRF24L01_CE;
   NRF24L01_Write_Buf(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//写数据到TX BUF  32个字节
  Set_NRF24L01_CE;                                     //启动发送
 while(READ_NRF24L01_IRQ!=0);                              //等待发送完成
 state=NRF24L01_Read_Reg(STATUS);                     //读取状态寄存器的值
 NRF24L01_Write_Reg(SPI_WRITE_REG+STATUS,state);      //清除TX_DS或MAX_RT中断标志
 if(state&MAX_TX)                                     //达到最大重发次数
  NRF24L01_Write_Reg(FLUSH_TX,0xff);               //清除TX FIFO寄存器
  return MAX_TX;
 if(state&TX_OK)                                      //发送完成
  return TX_OK;
 return 0xff;                                         //其他原因发送失败
//启动NRF24L01发送一次数据
//txbuf:待发送数据首地址
//返回值:0,接收完成;其他,错误代码
u8 NRF24L01_RxPacket(u8 *rxbuf)
 u8 state;
 if(state&RX_OK)                                 //接收到数据
  NRF24L01_Read_Buf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//读取数据
  NRF24L01_Write_Reg(FLUSH_RX,0xff);          //清除RX FIFO寄存器
  return 0;
 return 1;                                      //没收到任何数据
//该函数初始化NRF24L01到RX模式
//设置RX地址,写RX数据宽度,选择RF频道,波特率和LNA HCURR
//当CE变高后,即进入RX模式,并可以接收数据了
void RX_Mode(void)
 Clr_NRF24L01_CE;
   NRF24L01_Write_Buf(SPI_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH);//写RX节点地址
   NRF24L01_Write_Reg(SPI_WRITE_REG+EN_AA,0x01);    //使能通道0的自动应答
   NRF24L01_Write_Reg(SPI_WRITE_REG+EN_RXADDR,0x01);//使能通道0的接收地址
   NRF24L01_Write_Reg(SPI_WRITE_REG+RF_CH,40);      //设置RF通信频率
   NRF24L01_Write_Reg(SPI_WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//选择通道0的有效数据宽度
   NRF24L01_Write_Reg(SPI_WRITE_REG+RF_SETUP,0x0f); //设置TX发射参数,0db增益,2Mbps,低噪声增益开启
   NRF24L01_Write_Reg(SPI_WRITE_REG+CONFIG, 0x0f);  //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式
   Set_NRF24L01_CE;                                //CE为高,进入接收模式
//该函数初始化NRF24L01到TX模式
//设置TX地址,写TX数据宽度,设置RX自动应答的地址,填充TX发送数据,选择RF频道,波特率和LNA HCURR
//PWR_UP,CRC使能
//CE为高大于10us,则启动发送.
void TX_Mode(void)
 Clr_NRF24L01_CE;
   NRF24L01_Write_Buf(SPI_WRITE_REG+TX_ADDR,(u8*)TX_ADDRESS,TX_ADR_WIDTH);    //写TX节点地址
   NRF24L01_Write_Buf(SPI_WRITE_REG+RX_ADDR_P0,(u8*)RX_ADDRESS,RX_ADR_WIDTH); //设置TX节点地址,主要为了使能ACK
   NRF24L01_Write_Reg(SPI_WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址
   NRF24L01_Write_Reg(SPI_WRITE_REG+SETUP_RETR,0x1a);//设置自动重发间隔时间:500us + 86us;最大自动重发次数:10次
   NRF24L01_Write_Reg(SPI_WRITE_REG+RF_CH,40);       //设置RF通道为40
   NRF24L01_Write_Reg(SPI_WRITE_REG+CONFIG,0x0e);    //配置基本工作模式的参数;PWR_UP,EN_CRC,16BIT_CRC,接收模式,开启所有中断
 Set_NRF24L01_CE;                                  //CE为高,10us后启动发送
