定时器外部中断红外通讯问题
我是红外接收波特率1200bps,我定时器是按照这个时间中断读每位的数据吗?我发送应该是38khz,我数据从哪里来呢,定义一个字节,一位一位移动,那校验位要求怎么处理?下面是源代码,请帮忙看看。
void UartIRInit(void)
/*----set INTP3-----------------------------------------------------------*/
PIF3 = 0;
PM3.1 = 1;
EGP = 0x00; //EGP3=0
EGN = 0x08; //EPN3=1
PMK3 = 0; //enable interrupt
PPR3 = 1; //low priority
/*---set TMH1-------------------------------------------------------------*/
TMHMD1 = 0;
TMHMD1 = 0x30;//00110000
CMP01 = 103; //8000000/64/104=1201.92
TMMKH1 = 0; //enble interrupt
TMPRH1 = 0; //high priority
/*---set TMH0-------------------------------------------------------------*/
TMHMD0 = 0;
PM3.2 = 0;
P3.2 = 0;
CMP00 = 104;//8000000/(104+1) = 76.190K
TMHMD0 = 0x01;//enable output
TMMKH0 = 1; //disable interrupt
/*--------byte set--------------------------------------------------------*/
//RXIR=0;
//TXIR
UartIR.Monit500ms = 0;
UartIR.Monit5s = 0;
UartIR.Lapse30ms = 0;
FUartIR_RStart = 0;
FUartIR_REnd = 0;
FUartIR_Treat = 0;
FUartIR_Ting = 0;
__interrupt void IntP3(void)
CMP01 = 51;
TMHE1 = 1;
PMK3 = 1;
IRB = 0;//infrade buf
IRBits = 0;
IRParity = 0;
__interrupt void IntTMH1(void)
TMHE1 = 0;
CMP01 = 103;
TMHE1 = 1;
if (FUartIR_Ting == 1)
if (IRBits < 9) //data bit
if ((IRB&0x01) == 0x0)
TMHE0 = 1;
else
IRParity++; //even parity
TMHE0 = 0;
P3.2 = 0;
IRB >>= 1;
IRBits++;
else if (IRBits == 9) //parity bit
if (IRParity.0 == 0)
TMHE0 = 1;//even 1 bits,even parity is 0
else
TMHE0 = 0;
P3.2 = 0;
IRBits++;
else if (IRBits == 10)//stop bit
TMHE0 = 0;
P3.2 = 0;
IRBits++;
else if (IRBits == 11)
TMHE1 = 0;//end the transmit
#ifndef __IR30MS
if (UartIR.FENum != 0)
UartIR.FENum--;
IRB = 0xfe;
IRBits = 1; //start bit
IRParity = 0;
CMP01 = 103;
TMHE1 = 1;
TMHE0 = 1;
else if (UartIR.DataNum < (UartIR.Buf[9]+12))
IRB = UartIR.Buf[UartIR.DataNum++];
IRBits = 1;//start bit
IRParity = 0;
CMP01 = 103;
TMHE1 = 1;
TMHE0 = 1;//start bit
else
FUartIR_Ting = 0;
FUartIR_RStart = 0;
PIF3 = 0;
PMK3 = 0;//enable P5 interrupt
TMHE1 = 0;//stop TMH1
#endif
/*-----receive state------------------------------------------------------*/
else
if (IRBits == 0) //the first judge is 0.416ms
if (P3.1 == 1)//start bit is error
PMK3 = 0;
TMHE1 = 0;//end the receive
else
IRBits = 1;//++;
else if (IRBits < 9)//data bits
IRB >>= 1;
if (P3.1 == 1)
IRB |= 0x80;
IRParity++;
IRBits++;
if (((P3.1==0)&&(IRParity.0==0)) ||
((P3.1==1)&&(IRParity.0==1))) //even check right
IRBits++;
else
PMK3 = 0;
TMHE1 = 0; //stop receive
IRBits = 0;
else//end bit
PMK3 = 0;//enable receive last byte
TMHE1 = 0;//because priority of TMH1 higher than P5
if (P3.1 == 1)//stop bit
UartIR.Monit5s = 0;
if (FUartIR_RStart == 0)
if (IRB == 0x68)
FUartCom = 1;
UartIR.Buf[0] = 0x68;
UartIR.DataNum = 1;
FUartIR_RStart = 1;
else
if (UartIR.DataNum < MAXNUM_UART)
UartIR.Buf[UartIR.DataNum] = IRB;
if (UartIR.DataNum == 7)
if (IRB != 0x68)
FUartIR_RStart = 0;
else if (UartIR.DataNum >= (UartIR.Buf[9]+11))
if (IRB == 0x16)
PMK3 = 1; //end the receive
FUartIR_REnd = 1;
FUartIR_RStart = 0;
UartIR.DataNum++;
else
FUartIR_RStart = 0;
有奖活动 | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! | |
【有奖活动】伙伴们:您的“需求”解决了吗? | |
抽奖了,抽奖了,金升阳医疗电源 |
打赏帖 | |
【换取手持数字示波器】+与同事对定时器输出相位可调PWM移相全桥控制分享被打赏50分 | |
【换取手持数字示波器】+LP-MSPM0L1306开发板试用体验+串口被打赏40分 | |
CC-RL编译器相关问题求助被打赏10分 | |
【换取手持数字示波器】+与同事对ESP-12开发调试经验分享被打赏50分 | |
【换取手持数字示波器】+同事tek示波器调试spi解析被打赏50分 | |
【换取手持数字示波器】+2.6寸墨水屏调试经验被打赏50分 | |
换取手持数字示波器+个人开关电源的设计经验被打赏50分 | |
【换取手持数字示波器】+【APT32F173测评】+URAT被打赏20分 | |
【换取手持数字示波器】CH32X035的定时器以及外部中断体验被打赏50分 | |
【换取手持数字示波器】CH32X035搭建开发环境(RISC-V)被打赏50分 |
