电子产品世界 » 论坛首页 » 企业专区 » Renesas » 【问题已解决】1602LCD 显示不了了!请高手先帮看一下问题在哪?
共10条 1/1 1 跳转至
2012-10-08 02:14:21     打赏
贴代码:
/*LCD Driver*/
/*port define*/
/*-LCD Port--------------G13 Port--*/
/*--DB0~DB7---------------P1-----*/
/*---RS-------------------P41----*/
/*---RW-------------------P42----*/
/*---E--------------------P43----*/
/*Port define end*/
//unsigned char table1[] = "E";
//unsigned char num;
void delay_1us(void)
  unsigned int i;
  for(i=0; i<100; i++);
void delay_nus(unsigned int n)
  unsigned int i;
  for(i=0; i<n; i++)
    delay_1us();
void delay_1ms(void)
  unsigned int i;
  for(i=0; i<1000; i++);
void delay_nms(unsigned int n)
  unsigned int i;
  for(i=0; i<n; i++)
    delay_1ms();
void write_lcd_com(unsigned int com)
  P1 = 0x00;
  //RS_H;
  P4_bit.no1 = 1;
  //RW_H;
  P4_bit.no2 = 1;
  //EN_L;
  P4_bit.no3 = 0;
  P1 = com;
  //RS_L;
  P4_bit.no1 = 0;
  //RW_L;
  P4_bit.no2 = 0;
  //EN_H;
  P4_bit.no3 = 1;
  //EN_L;
  P4_bit.no3 = 0;
  delay_nus(20);
void write_lcd_data(unsigned int data)
  P1 &= 0x00;
  //RS_L;
  P4_bit.no1 = 0;
  //RW_H;
  P4_bit.no2 = 1;
  //EN_L;
  P4_bit.no3 = 0;
  P1 = data;
  //RS_H;
  P4_bit.no1 = 1;
  //RW_L;
  P4_bit.no2 = 0;
  //EN_H;
  P4_bit.no3 = 1;
  //EN_L;
  P4_bit.no3 = 0;
  delay_nus(20);
void init_LCD(void)
    write_lcd_com(0x38);//设置8位格式,2行,5x7点阵字符 0011 1000
    delay_nms(5);
    write_lcd_com(0x08);//关闭显示                      0000 1000
    delay_nms(5);
    write_lcd_com(0x01);//清除屏幕显示                  0000 0001
    delay_nms(5);
    write_lcd_com(0x06);//设定输入方式,增量不移位      0000 0110
    delay_nms(5);
    write_lcd_com(0x02);//光标归位                      0000 0010
    delay_nms(5);
    write_lcd_com(0x0F);//开显示,关光标,不闪烁        0000 1100
    delay_nms(50);
void lcd_write_char(unsigned char x, unsigned char y, unsigned char data)
  unsigned char address;
  if(y==1)
    address = 0x80 + x;
  else
     address = 0xc0 +x;
  write_lcd_com(address);
  write_lcd_data(data);
/*LCD Driver End*/
/* End user code. Do not edit comment generated here */
**  Abstract:
** This function implements main function.
**  Parameters:
** None
**  Returns:
** None
/* Start user code for adding. Do not edit comment generated here */
void  main(void)
 /* Start user code. Do not edit comment generated here */
        delay_nms(5);
        init_LCD();
        delay_nms(5);
        //RTC_Init();
        lcd_write_char(0, 1, 'A');
//        while(1u)
关键词: 问题     解决     1602LCD     显示     了了     高手     先帮
2012-10-08 11:44:45     打赏
出现什么现象??
2012-10-08 11:46:47     打赏
注意時序~~
2012-10-08 13:15:05     打赏
屏上面的点都被点亮了!
现在怀疑两方面问题:
第一个是P1口是不是一些引脚被复用成其它功能了!所以输出数据有问题;
第二个是时钟设置有问题,造成状态问题,代码和配置方式都是对的(在MSP430上验证过);
2012-10-08 17:51:18     打赏
要怀疑口被复用可换个口 (P0,P7..)验证一下
个人认为:初始化,延时,应该是检查的重点
2012-10-08 20:35:49     打赏
应该是你说的第一种情况,把数据口换到P7口吧。我的是P7口,,可以点亮。
2012-10-11 09:41:05     打赏
关注中
2012-10-11 22:14:47     打赏
终于解决了!就是上面怀疑的第一种情况!P1口的输出被别的功能复用了!
改到P7口后,加大write com的延时,显示正常,上图!
2012-10-12 08:43:09     打赏
恭喜
2012-10-12 09:38:50     打赏
恭喜啊~~~
共10条 1/1 1 跳转至
