电子产品世界 » 论坛首页 » 企业专区 » Xilinx » Zynq-7000 All Programmable SoC (XC7Z030,
共22条 1/3 1 2 3 跳转至
Zynq-7000 All Programmable SoC (XC7Z030, XC7Z045, and XC7Z100): DC and AC Switch
2013-06-08 09:59:06     打赏
(英文文档,Xilinx公司2013年4月新鲜出炉)
Zynq.-7000 All Programmable SoCs are available in -3, -2, and -1 speed grades, with -3 having the highest performance. Zynq-7000 device DC and AC characteristics are specified in commercial, extended, and industrial temperature ranges. Except the operating temperature range or unless otherwise noted, all the DC and AC electrical parameters are the same for a particular speed grade (that is, the timing characteristics of a -1 speed grade industrial device are the same as for a -1 speed grade commercial device). However, only selected speed grades and/or devices are available in the commercial, extended, or industrial temperature ranges.——回复可见内容——
关键词: Zynq-7000     Programmable     XC
2014-08-02 14:26:38     打赏
好好学习一下
2014-08-29 11:00:33     打赏
2017-07-14 15:17:05     打赏
2017-12-12 19:53:24     打赏
感谢分享~
2017-12-14 03:54:34     打赏
謝謝分享
2017-12-30 10:58:53     打赏
楼主辛苦,看看
2018-01-27 15:21:34     打赏
谢谢
2018-02-02 18:02:41     打赏
2018-02-03 20:26:52     打赏
学习一下
共22条 1/3 1 2 3 跳转至
