电子产品世界 » 论坛首页 » 企业专区 » Microchip » pic32串口通信问题
共6条 1/1 1 跳转至
pic32串口通信问题
2014-03-24 14:38:30     打赏
第一次玩pic32的mcu,MIPS内核
串口通信发送还是比较顺利
但是死活接收不到串口调试助手发送过来的数据
串口重映射比较坑爹,折腾一上午才有点头绪
代码:
 * File:   newmain.c
 * Author: Liao
 * Created on 2014.3.23, 11:39
#include <stdio.h>
#include <stdlib.h>
#include <plib.h>
// Configuration Bit settings
// SYSCLK = 40 MHz (8MHz Crystal/ FPLLIDIV * FPLLMUL / FPLLODIV)
// PBCLK = 40 MHz
// Primary Osc w/PLL (XT+,HS+,EC+PLL)
// WDT OFF
// Other options are don't care
#pragma config FPLLMUL = MUL_20, FPLLIDIV = DIV_2, FPLLODIV = DIV_1, FWDTEN = OFF
#pragma config POSCMOD = HS, FNOSC = PRIPLL, FPBDIV = DIV_1
#define SYS_FREQ                 (40000000L)
#define DESIRED_BAUDRATE        (9600)      // The desired BaudRate
int main(void)
    int    pbClk;
   unsigned char data;
 RPB3R = 1;//U1TX---RPB3 caution
//    U1RXR = 0;//U1RX---RPA2
    // Configure the device for maximum performance but do not change the PBDIV
    // Given the options, this function will change the flash wait states, RAM
    // wait state and enable prefetch cache but will not change the PBDIV.
    // The PBDIV value is already set via the pragma FPBDIV option above..
    pbClk=SYSTEMConfig(SYS_FREQ, SYS_CFG_WAIT_STATES | SYS_CFG_PCACHE);
    // Open UART2 with Receive and Transmitter enable.
   OpenUART1(UART_EN, UART_RX_ENABLE | UART_TX_ENABLE, pbClk/16/DESIRED_BAUDRATE/5-1);    // calculate actual BAUD generate value.
 mPORTASetPinsDigitalOut(BIT_0);    // Make RPA0 as output.
    mPORTASetBits(BIT_0);         // Set RPA0.
   putsUART1("*** UART Simple Application Example ***\r\n");
   putsUART1("*** Type some characters and observe echo and RA7 LED toggle  ***\r\n");
   while(1)
      while(!DataRdyUART1()); /* Wait for data in the UARTRx. */
      data = (char)ReadUART1(); /* Read data from Rx. */
      while(BusyUART1()); /* Wait till the UART transmitter is free. */
      putcUART1(data); /* Write data into Tx. */
   return 0;
 程序执行到
 while(!DataRdyUART1()); 这里就无法进行下一步了
似乎是等待不到接收的数据。
请大神帮看看。
2014-03-24 14:47:13     打赏
应该放在中断里处理串口的数据比较好
2014-03-24 14:50:32     打赏
有没有开接收中断?
2014-03-24 15:04:38     打赏
没用中断,查的
2014-03-24 15:05:03     打赏
直接在查......
2014-03-24 22:18:38     打赏
我之前遇到过同样的问题,倒腾了一上午
共6条 1/1 1 跳转至
