电子产品世界 » 论坛首页 » 企业专区 » Xilinx » 内核和文件系统移植出现的问题(Kernel panic - not syncin
内核和文件系统移植出现的问题(Kernel panic - not syncing)
2014-10-10 22:12:26     打赏
[    0.850000] mmc0: new high speed SDHC card at address 1234
[    0.860000] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[    0.870000]  mmcblk0: p1 p2
[    1.740000] EXT4-fs (mmcblk0p2): recovery complete
[    1.760000] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.770000] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.770000] Freeing init memory: 148K
[    1.780000] Kernel panic - not syncing: No init found.  Try passing init= option to kernel. See Linux Documentation/init.txt for guidance.
[    1.790000] CPU0: stopping
[    1.790000] [<c0012fa4>] (unwind_backtrace+0x0/0xe0) from [<c0011f7c>] (ipi_cpu_stop+0x3c/0x68)
[    1.790000] [<c0011f7c>] (ipi_cpu_stop+0x3c/0x68) from [<c00122fc>] (handle_IPI+0x68/0xb4)
[    1.790000] [<c00122fc>] (handle_IPI+0x68/0xb4) from [<c0008460>] (gic_handle_irq+0x54/0x5c)
[    1.790000] [<c0008460>] (gic_handle_irq+0x54/0x5c) from [<c000d340>] (__irq_svc+0x40/0x70)
出现这样的错误怎么解决呢?是内核配置出问题了吗?
关键词: Kernel panic - not syncin
