电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 18号的作业
共27条 1/3 1 2 3 跳转至
18号的作业
2014-10-21 23:05:11     打赏
2014-10-22 23:45:57     打赏
2014-10-23 10:57:44     打赏
#include "stm32f10x.h"
#include "stm32_eval.h"
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void) //RCC时钟配置函数
  RCC_DeInit(); //将RCC寄存器重新设置为默认值
  RCC_HSICmd(ENABLE);   //打开HSI
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);//等待HSI工作
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);  //设置系统时钟函数
  RCC_HSEConfig(RCC_HSE_OFF);  //HSE晶振关闭
  RCC_LSEConfig(RCC_LSE_OFF);  //LSh晶振关闭
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);   //打开PLL
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);  //等待PLL工作
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);  //ADC???RCC_PCLK2/4
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);   //关闭蜂鸣器
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|
RCC_APB2Periph_AFIO, ENABLE);
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;  //GPIO频率
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //GPIO输出
  GPIO_Init(GPIOD, &GPIO_InitStructure);
	GPIO_ResetBits(GPIOD,GPIO_Pin_2);  //重置GPIO
void GPIO_INIT()
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);  //使能APB2外
设
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;  //设
置GPIO管脚
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_4|GPIO_Pin_5|
GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//GPIO输出
  GPIO_Init(GPIOA, &GPIO_InitStructure);   //初始化PA
    GPIO_Init(GPIOC, &GPIO_InitStructure);
void delay_us(u32 n) //延时函数32位,延时1us
	u8 j;
	while(n--)
	for(j=0;j<10;j++);
void  delay_ms(u32 n) //延时1ms
	while(n--)
	delay_us(1000);
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)  //主函数开始
	GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|
GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); //LED灯全灭
	RCC_Configuration(); //调用时钟RCC函数
 GPIO_INIT(); //调用GPiO函数
	while(1){
	GPIO_ResetBits(GPIOC,GPIO_Pin_0); //灯亮
		delay_ms(50);
		GPIO_SetBits(GPIOC,GPIO_Pin_0); //灯灭
		delay_ms(50);
    GPIO_ResetBits(GPIOC,GPIO_Pin_1); //灯亮
		delay_ms(50);
    GPIO_SetBits(GPIOC,GPIO_Pin_1); //灯灭
		delay_ms(50);
    GPIO_ResetBits(GPIOC,GPIO_Pin_2); //灯亮
		delay_ms(50);
    GPIO_SetBits(GPIOC,GPIO_Pin_2); //灯灭
		delay_ms(50);
    GPIO_ResetBits(GPIOC,GPIO_Pin_3); //灯亮
		delay_ms(50);
    GPIO_SetBits(GPIOC,GPIO_Pin_3); //灯灭
		delay_ms(50);
    GPIO_ResetBits(GPIOC,GPIO_Pin_4); //灯亮
		delay_ms(50);
    GPIO_SetBits(GPIOC,GPIO_Pin_4); //灯灭
		delay_ms(50);
    GPIO_ResetBits(GPIOC,GPIO_Pin_5); //灯亮
		delay_ms(50);
    GPIO_SetBits(GPIOC,GPIO_Pin_5); //灯灭
		delay_ms(50);
    GPIO_ResetBits(GPIOC,GPIO_Pin_6); //灯亮
		delay_ms(50);
    GPIO_SetBits(GPIOC,GPIO_Pin_6); //灯灭
		delay_ms(50);
    GPIO_ResetBits(GPIOC,GPIO_Pin_7); //灯亮
		delay_ms(50);
    GPIO_SetBits(GPIOC,GPIO_Pin_7); // 灯灭
		delay_ms(50);
	//RGB亮灭
		GPIO_ResetBits(GPIOA,GPIO_Pin_2); //红灯亮
    delay_ms(200);
    GPIO_SetBits(GPIOA,GPIO_Pin_2); //红灯灭
		GPIO_ResetBits(GPIOA,GPIO_Pin_3); //绿灯亮
    delay_ms(200);
    GPIO_SetBits(GPIOA,GPIO_Pin_3); //绿灯灭
2014-10-23 11:59:48     打赏
2014-10-30 23:31:19     打赏
  * @file    GPIO/IOToggle/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body.
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
void GPIO()
    RCC_Configuration();    //GPIO的初始化
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
    GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
void delay_us(u32 n)   //延时微秒
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
void  delay_ms(u32 n)    //延时毫秒
    while(n--)
    delay_us(1000);
int main (void)
    char i,j,num;   //定义变量
          GPIO();
        while(1){
            if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10))    //s3键按下
           {delay_ms(80);    //延时,防抖
           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10)){j++;}}   //s3自加1
        if(j%2==0){      // 如果j是偶数
             if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))      //s1键按下
           {delay_ms(80);
           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)){i++;}    //s1键按下i自加1
							if(i>30){i=0;}   //30个循环
        GPIO_ResetBits(GPIOB,GPIO_Pin_1);    //关闭PB1
        GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);  //关闭数码管管脚
        switch(i)
         case 0 :
             GPIO_SetBits(GPIOB,GPIO_Pin_1);
             GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
         break;
         case 1 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
         break;
            case 2 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
            break;
            case 3 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
            break;
            case 4 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);
            break;
            case 5 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);
            break;
            case 6 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
            break;
            case 7 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
            break;
            case 8 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
            break;
            case 9 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
            break;
            case 10 :
             delay_ms(1);
             GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
                  GPIO_SetBits(GPIOB,GPIO_Pin_15);
                  delay_ms(1);
                  GPIO_ResetBits(GPIOB,GPIO_Pin_15);
                  GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
            break;
            case 11 :
             delay_ms(1);
                  delay_ms(1);
            break;
            case 12 :
             delay_ms(1);
             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
                  delay_ms(1);
            break;
            case 13 :
             delay_ms(1);
             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
                  delay_ms(1);
            break;
            case 14 :
             delay_ms(1);
             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);
                  delay_ms(1);
            break;
            case 15 :
             delay_ms(80);
             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);
                  delay_ms(100);
            break;
            case 16 :
             delay_ms(80);
             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
                  delay_ms(100);
            break;
            case 17 :
             delay_ms(80);
            GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
                  delay_ms(100);
            break;
            case 18 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 19 :
             delay_ms(80);
             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
                  delay_ms(100);
            break;
            case 20 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 21 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 22 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 23 :
             delay_ms(80);
                  delay_ms(100);
						break;
            case 24 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 25 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 26 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 27 :
             GPIO_ResetBits (GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
             delay_ms(80);
            GPIO_SetBits (GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
                  delay_ms(100);
            break;
            case 28 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 29 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 30 :
             delay_ms(80);
                  delay_ms(100);
            break;
                else{
                              if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9))     //s2键按下
           {delay_ms(80);
           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9)){num++;}}
           if(num>30){num=0;}
        switch(num)
         case 0 :
         break;
         case 1 :
         break;
            case 2 :
            break;
            case 3 :
            break;
            case 4 :
            break;
            case 5 :
            break;
            case 6 :
            break;
            case 7 :
            break;
            case 8 :
            break;
            case 9 :
            break;
            case 10 :
             delay_ms(1);
                  delay_ms(1);
            break;
            case 11 :
             delay_ms(1);
                  delay_ms(1);
            break;
            case 12 :
             delay_ms(1);
                  delay_ms(1);
            break;
            case 13 :
             delay_ms(1);
                  delay_ms(1);
            break;
            case 14 :
             delay_ms(1);
                  delay_ms(1);
            break;
            case 15 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 16 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 17 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 18 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 19 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 20 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 21 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 22 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 23 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 24 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 25 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 26 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 27 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 28 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 29 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 30 :
             delay_ms(80);
                  delay_ms(100);
            break;
2014-11-14 11:17:16     打赏
#include    "stdio.h"
#include "math.h"
#define buff_size  16;
char rx_buff[], rx_buff_count=0;
USART_InitTypeDef  USART_InitStructure;
NVIC_InitTypeDef  NVIC_InitStructure;
USART_ClockInitTypeDef  USART_ClockInitStructure;
    RCC_DeInit();
    RCC_HSICmd(ENABLE);
    RCC_PLLCmd(ENABLE);
    GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
    GPIO_ResetBits(GPIOD,GPIO_Pin_2);//关闭蜂鸣器
void GPIO_INIT()
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能PC时钟
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//PC0-PC7
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//推挽输出
    GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化PC
void USART_int(long BaudRate)
     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//使能PA USART1
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;//TX位于PA9
   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //推挽输出
   GPIO_Init(GPIOA, &GPIO_InitStructure);//TX初始化 PA9
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//RX位于PA10
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//悬空输入
   GPIO_Init(GPIOA, &GPIO_InitStructure);//RX初始化 PA10
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
    USART_InitStructure.USART_BaudRate = BaudRate;//传输速率
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长8比特
    USART_InitStructure.USART_StopBits = USART_StopBits_1;//停止位1
    USART_InitStructure.USART_Parity = USART_Parity_No;//
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//流控位none
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//接收和发送模式
    USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
    USART_ClockInit(USART1, &USART_ClockInitStructure);//初始化USART1时钟
    USART_Init(USART1, &USART_InitStructure);//初始化USART1
    USART_Cmd(USART1, ENABLE);
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  /* Configure four bit for preemption priority */
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);//优先级
  /* Enable the USART1 Interrupt */
    NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //选择USART1中断通道
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);//初始化中断
/*delay_us*/
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
/*delay_ms*/
    while(n--)
    delay_us(1000);
void USART_SendStr(char *str)//发送字符串
   while((*str)!='\0')//到字符串的末尾才停止发送数据
        USART_SendData(USART1,*str++);
        while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
unsigned int translate(char *S,char j)//将字符串组成的数字转换成整型数据
    unsigned int a[4],sum=0;
    char i;
    for(i=0;i<j;i++)
        a[i]=S[5+j-1-i]-48;//将字符转成整型数据
        sum+=a[i]*pow(10,i);//按照每一位的权值相乘再相加,还原data=n的本来面貌
    return sum;//sum保存目标整型数据
void func(char *S,char LEN)
    char count;//
    unsigned int sum,i,j,k;
    if((LEN!=6)&(LEN!=7)&(LEN!=8)&(LEN!=9))//data=1~999
    {USART_SendStr("\r\n Erro input!!!\r\n");}//如果输入格式错误,发送提示
    else
        count=LEN-5;//从“=”后面开始是目标数据
        sum = translate(S,count);//count记录“=”后有多少位,传递到translate中
        GPIO_SetBits(GPIOC,0x000000ff);//all LED off
        for(k=0;k<3;k++)//循环点亮D8-D1 3次
            i=0x00000100;
            for(j=1;j<=8;j++)//LED D8-D1
                i>>=1;
                GPIO_ResetBits(GPIOC,i);    // on PC7-PC0 D8-D1
                delay_ms(50);
                GPIO_SetBits(GPIOC,i);
                delay_ms(sum);//每两盏灯发光,间隔时间sum
void input_ASK()
    char j;
    func(rx_buff,rx_buff_count);
    rx_buff_count=0;
    for (j=0;j<rx_buff_count;j++)
    {rx_buff[j]='\0';}//判断读入信息是否结束,如果结束则准备下一次读入
    USART_SendStr("\n>");
int main(void)
    GPIO_INIT();
    USART_int(9600);
    GPIO_ResetBits(GPIOC,0x000000ff);//led全亮,提示程序开始
    delay_ms(200);
    GPIO_SetBits(GPIOC,0x000000ff);//led全灭
    USART_SendStr("SyStem booting......\r\n");//
    USART_SendStr("\n>");//
    while(1)
void USART1_IRQHandler(void)
  while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET)
    if(USART_ReceiveData(USART1)==0x0d)//如果输入完毕,按下了回车
    {input_ASK();}
    else
        USART_SendData(USART1,USART_ReceiveData(USART1));
        rx_buff[rx_buff_count]= USART_ReceiveData(USART1);
        rx_buff_count++;
    USART_ClearFlag(USART1, USART_FLAG_RXNE);
2014-11-14 13:48:08     打赏
焊接的好工整
2014-11-15 00:16:25     打赏
楼主贴了好多图和代码。
不多做点说明?
2014-11-27 22:09:40     打赏
2014-11-27 23:09:24     打赏
这是很久以前的了呀
共27条 1/3 1 2 3 跳转至
