电子产品世界 » 论坛首页 » 企业专区 » Xilinx » 有知道这是什么原因吗?在zedboard开发版上运行qt出现移动鼠标有两个光标,
共5条 1/1 1 跳转至
有知道这是什么原因吗?在zedboard开发版上运行qt出现移动鼠标有两个光标,并且画面也很凌乱
2014-10-27 10:02:19     打赏
【村长】北京-某人
你把framebuffer console关了试一试
framebuffer console和qt framebuffer叠加了
【干部】陈玉生
[    1.100000] Registering SWP/SWPB emulation handler
[    1.110000] new mode: 1440x900 1904x934 106500
[    1.110000] composite sync not supported
[    1.110000] new mode: 1280x1024 1688x1066 108000
[    1.110000] new mode: 800x600 1056x628 40000
[    1.110000] new mode: 640x480 840x500 31500
[    1.110000] new mode: 640x480 800x525 25200
[    1.110000] new mode: 720x400 900x449 28320
[    1.110000] new mode: 1280x1024 1688x1066 135000
[    1.110000] new mode: 1024x768 1312x800 78800
[    1.110000] new mode: 1024x768 1328x806 75000
[    1.110000] new mode: 1024x768 1344x806 65000
[    1.110000] new mode: 800x600 1056x625 49500
[    1.110000] new mode: 640x480 832x520 31500
[    1.110000] new mode: 800x600 1024x625 36000
[    1.110000] new mode: 800x600 1040x666 50000
[    1.110000] new mode: 848x480 1088x517 33750
[    1.110000] new mode: 1152x864 1600x900 108000
[    1.110000] new mode: 1280x768 1440x790 68250
[    1.110000] new mode: 1280x768 1696x805 102250
[    1.110000] new mode: 1280x800 1440x823 71000
[    1.110000] new mode: 1280x800 1696x838 106500
[    1.110000] new mode: 1280x960 1800x1000 108000
[    1.110000] new mode: 1360x768 1792x795 85500
[    1.110000] new mode: 1440x900 1936x942 136750
[    1.110000] new mode: 1024x576 1312x597 46970
[    1.110000] new mode: 1366x768 1800x795 85885
[    1.110000] new mode: 640x480 800x525 25175
[    1.110000] new mode: 1920x1080 2200x1125 148500
[    1.110000] new mode: 1280x720 1650x750 74250
[    1.110000] new mode: 1400x1050 1560x1080 101000
[    1.110000] new mode: 1680x1050 1840x1080 119000
[    1.110000] new mode: 1600x900 2128x932 118963
[    1.110000] new mode: 1680x945 2240x978 131481
[    1.120000] mmc0: new high speed SDHC card at address 0007
[    1.320000] mmcblk0: mmc0:0007 SD04G 3.70 GiB
[    1.320000] registered taskstats version 1
[    1.320000] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[    1.320000] ALSA device list:
[    1.320000]   #0: HDMI monitor
[    1.320000] setting clock to: 106500
[    1.320000] raw_edid: d8128a80 3
[    1.320000] Using RGB output
[    1.320000]  mmcblk0: p1 p2
[    1.360000] Console: switching to colour frame buffer device 180x56
[    1.420000] fb0:  frame buffer device
[    1.420000] drm: registered panic notifier
[    1.420000] [drm] Initialized analog_drm 1.0.0 20110530 on minor 0
[    1.450000] usb 1-1: new full-speed USB device number 2 using xusbps-ehci
[    1.600000] usb 1-1: New USB device found, idVendor=0a05, idProduct=7211
[    1.610000] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
给分析一下是不是我选择的显示器的分辨率不对呢?
framebuffer console这个是在哪个地方操作呢?
显示器的设置?
【村长】北京-某人
内核配置
2014-10-27 13:40:30     打赏
貌似程序溢出的结果。bug.
2014-10-27 16:11:45     打赏
问题已经解决,参考http://blog.csdn.net/liebergott/article/details/7793408
一、查看文件/etc/init/rc-sysinit.conf,在第14行附近:确认“env DEFAULT_RUNLEVEL=2”。2是新装系统默认的,确保不被修改。
二、编辑文件 /etc/init/lightdm.conf,在第12行附近,原句“ and runlevel [!06]” 改为“ and runlevel [!026]”。
2015-04-25 16:06:26     打赏
你好,请问现在你这个问题解决了吗?我现在也遇到跟你一样的问题了,有解决办法希望回复.
2016-01-08 15:19:55     打赏
兄弟,这个问题怎么解决的?我也是同样的问题
共5条 1/1 1 跳转至
