电子产品世界 » 论坛首页 » 嵌入式开发 » 软件与操作系统 » 移位寄存器:74164
移位寄存器:74164
2015-04-13 21:21:31     打赏
-- TTL164 Shift Register
library IEEE;
use IEEE.Std_logic_1164.all;
ENTITY dev164 IS
   PORT(a, b, nclr, clock : IN BIT;
         q : BUFFER BIT_VECTOR(0 TO 7));
END dev164;
ARCHITECTURE version1 OF dev164 IS
BEGIN
   PROCESS(a,b,nclr,clock)
   BEGIN
   IF nclr  = '0' THEN
      q <= "00000000";
   ELSE
      IF clock'EVENT AND clock = '1'
      THEN
         FOR i IN q'RANGE LOOP
            IF i = 0 THEN q(i) <= (a AND b);
            ELSE
               q(i) <= q(i-1);
            END IF;
         END LOOP;
      END IF;
   END IF;
   END PROCESS;
END version1;
