电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » C语言试玩RSA加密解密
共5条 1/1 1 跳转至
C语言试玩RSA加密解密
2017-10-10 12:13:58     打赏
RSA的原理这篇文章介绍的比较好:
RSA算法原理
根据介绍写了下面的代码:
#include "stdio.h"
#include "stdlib.h"
#include "string.h"
static int rsa_check_prime_number(unsigned int n)
	unsigned int i = 0;
	if(n < 1)
		return -1;
	for(i = 2;i < n;i++)
		if((n % i) == 0)
			return -1;
	return 0;
int rsa_create_key()
	unsigned int prime_number1, prime_number2;
	unsigned int euler_n;
	unsigned int prime_number_e, prime_number_d, multiply_n;
	unsigned int i = 0;
	printf("enter two prime numbers: number1,number2\n\r");
	scanf("%d,%d", &prime_number1, &prime_number2);
	if(0 != rsa_check_prime_number(prime_number1) || 0 != rsa_check_prime_number(prime_number2))
		printf("number invalid...\n\r");
		return -1;
	multiply_n = prime_number1 * prime_number2;
	euler_n = (prime_number1 - 1) * (prime_number2 - 1);
	printf("two prime numbers:%d , %d, %d , %d\n\r", prime_number1, prime_number2, multiply_n, euler_n);
	printf("select a prime number between 1 and %d :\n\r", euler_n);
	scanf("%d", &prime_number_e);
	for(i = 0;i < euler_n;i++)
		if((i * prime_number_e - 1) % euler_n == 0)
			break;
	if(i >= euler_n)
		return -1;
	prime_number_d = i;
	printf("public: %d, %d\n\r",multiply_n, prime_number_e);
	printf("private: %d, %d\n\r",multiply_n, prime_number_d);
	return 0;
typedef struct
	unsigned int rsa_p;
	unsigned int rsa_e;
	unsigned int rsa_d;
}rsa_factor_t;
static rsa_factor_t rsa_factor;
int rsa_set_public_key(unsigned int common_p, unsigned int public_e)
	rsa_factor.rsa_p = common_p;
	rsa_factor.rsa_e = public_e;
	printf("rsa_p:%d, rsa_e:%d\n\r", rsa_factor.rsa_p, rsa_factor.rsa_e);
	return 0;
int rsa_set_private_key(unsigned int common_p, unsigned int private_d)
	rsa_factor.rsa_d = private_d;
	printf("rsa_p:%d, rsa_d:%d\n\r", rsa_factor.rsa_p, rsa_factor.rsa_d);
	return 0;
int rsa_encrypt(unsigned char *text , unsigned char *buff, unsigned int len)
	unsigned int i = 0, j = 0, c = 0, tmp_c = 0;
	if(buff == NULL)
		printf("buff invalid !\n\r");
		return -1;
	for(i = 0;i < len;i++)
		tmp_c = text[i];
		c = text[i];
		for(j = 1; j < rsa_factor.rsa_e; j++)
			tmp_c = (tmp_c * c) % rsa_factor.rsa_p;
		((unsigned int *)buff)[i] = tmp_c;
	return (i * sizeof(unsigned int));
int rsa_decrypt(unsigned char *text, unsigned char *buff, unsigned int len)
	unsigned int i = 0, j = 0;
	unsigned long long int c = 0, tmp_c = 0;
	if(buff == NULL)
		return -1;
	for(i = 0;i < (len / sizeof(int));i++)
		tmp_c = ((unsigned int *)text)[i];
		for(j = 1; j < rsa_factor.rsa_d; j++)
		buff[i] = (unsigned char)(tmp_c & 0xff);
	return i;
int main()
	unsigned char sel = 1;
	unsigned int key_1, key_2;
	unsigned char tmp_buf[128];
	unsigned char rsa_buf[128];
	unsigned int i = 0, count = 0;
	printf("*********************************************\n\r");
	printf("******RSA encryption and decryption *********\n\r");
	while(1)
		printf("***1. create public and private key \n\r");
		printf("***2. data encryption \n\r");
		printf("***3. data decryption \n\r");
		printf("***enter number : \n\r");
		scanf("%d", &sel);
		if(sel < 1 || sel > 3)
			continue;
		switch(sel)
			case 1:
				if(0 != rsa_create_key())
					printf("fail to create key ... \n\r");
				break;
			case 2:
				printf("set public key: common_p,rsa_e\n\r");
				scanf("%d,%d", &key_1, &key_2);
				rsa_set_public_key(key_1, key_2);
				printf("enter your information: \n\r");
				scanf("%s", (char *)tmp_buf);
				count = strlen((char *)tmp_buf);
				count = rsa_encrypt(tmp_buf, rsa_buf, count);
				printf("::::\n\r");
				for(i = 0;i < count;i++)
					printf("%d ", rsa_buf[i]);
				printf("\n\r");
				break;
			case 3:
				printf("set private key: common_p,rsa_d\n\r");
				rsa_set_private_key(key_1, key_2);
				printf("enter your data len: \n\r");
				scanf("%d", &count);
				printf("please enter %d numbers: \n\r", count);
				for(i = 0;i < count; i++)
					scanf("%d", &rsa_buf[i]);
				printf("::::\n\r");
				count = rsa_decrypt(rsa_buf, tmp_buf, count);
				for(i = 0;i <= count;i++)
					printf("%c", tmp_buf[i]);
				printf("\n\r");
				break;
			default:
				break;
试了运行了一下,好像是可以的:
创建密钥:
用公共密钥加密"EEPW"
得到16个数据然后用私有密钥解密:
大家可以玩玩
关键词: 加密解密     RSA     C
管理员
2017-10-11 09:01:43     打赏
 收藏!收藏!
2017-10-11 10:45:33     打赏
学习了,向大神致敬。
2017-10-11 15:31:59     打赏
 收藏!收藏!
2017-10-17 17:47:24     打赏
果断收藏
共5条 1/1 1 跳转至
