电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » uClinux添加usb Philips Cameras支持,编译出错
2004-10-29 18:52:41     打赏
请教高手:
我在编译uClinux内核的时候,添加了USB philips Camersa, 结果在编译make时出现以下错误
arm-elf-gcc -D_KERNEL__ -I/home/fli/uClinux/uClinux-Sumsung/linux-2.4.x/include -Wall -Wstrict-prototypes -Wno-trigraphs -O2 -fno-strict-aliasing -fno-common -fnocommon -pipe -fno-builtin -D__linux__ -g DNO_MM -mapcs-32 -mtune=arm7tmdi -mshort-load-bytes -msoft-float -c -o pwc-if.o pwc-if.c pwc-if.c: In function 'kvirt_to_pa': pwc-if.c:215: structure has no member named 'pgd' make[4]: *** [pwc.o] Error 1 make[4]: Leaving directory '/home/fli/uClinux/uClinux-Sumsung/linux-2.4.x/drivers/usb' make[3]: *** [first_rule] Error 2 make[3]: Leaving directory '/home/fli/uClinux/uClinux-Sumsung/linux-2.4.x/drivers/usb' make[2]: *** [_subdir_usb] Error 2 make[2]: Leaving directory '/home/fli/uClinux/uClinux-Sumsung/linux-2.4.x/drivers' make[2]: *** [_dir_drivers] Error 2 make[2]: Leaving directory '/home/fli/uClinux/uClinux-Sumsung/linux-2.4.x' make: *** [linux] Error 1
我的内核是uClinux-Samsung-20020318.tar.gz, 交叉工具链是arm-elf-20030314.sh
不知道那位高手知道问题出现在哪里?
关键词: uClinux     添加     Philips     Camera
