电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » ping VxWorks target 没响应
共3条 1/1 1 跳转至
2005-06-15 20:40:23     打赏
VxWorks Target in VMware: 192.168.0.221
Windows 2000: 192.168.0.2
I have 2 question:
1. I can't get the response of ping from Win2000 to VxWorks Target, ping is always timeout in Win2000 dos box. why?
2. how to use ping in VxWorks Target? (target shell does not understan ping commend.)
pls help me, thanks
Notes:
in tornoda environment, I can use WindView & other Tornado tools connect with VxWorks, so the network connection is OK.
关键词: VxWorks     target     响应
2005-06-16 17:09:00     打赏
你的vxWorks target中ping client组件选上了吗?如果没选上是ping不通的
2005-06-16 17:17:00     打赏
如果要从目标机上ping其它机器,那么应该加上ping client组件。
正常情况下,只要vxworks的网络组件正常工作,网口正常初始化,网线没有问题,那么从windows机器上应该可以ping通目标机的。
共3条 1/1 1 跳转至
