// // Copyright (c) 1992,1993,1994, Exemplar Logic Inc. All rights reserved. // // // Description : // This Verilog HDL description implements a UART. // // Version 1.1 : Original Creation // 2.1 : added comments // // Download from: http://www.fpga.com.cn // module uart (clkx16, read, write, rx, reset, tx, rxrdy, txrdy, parityerr, framingerr, overrun, data); input clkx16; // Input clock. 16x bit clock input read; // Received data read strobe input write; // Transmit data write strobe input rx; // Receive data line input reset; // clear dependencies output tx; // Transmit data line output rxrdy; // Received data ready to be read output txrdy; // Transmitter ready for next byte output parityerr; // Receiver parity error output framingerr; // Receiver framing error output overrun; // Receiver overrun error inout [0:7] data; // Bidirectional data bus reg tx; // Transmit data line reg overrun; // Receiver overrun error reg framingerr; // Receiver framing error reg parityerr; // Receiver parity error // Transmit data holding register wire [0:7] txhold ; // Transmit shift register bits reg [0:7] txreg; reg txtag2 ; // tag bits for detecting reg txtag1 ; // empty shift reg reg txparity ; // Parity generation register // Transmit clock and control signals reg txclk ; // Transmit clock: 1/16th of clkx16 wire txdone ; // 1'b1 when shifting of byte is done wire paritycycle ; // 1'b1 on next to last shift cycle reg txdatardy ; // 1'b1 when data is ready in txhold // Receive shift register bits reg [0:7] rxhold; // Holds received data for read reg [0:7] rxreg; // Receive data shift register reg rxparity ; // Parity bit of received data reg paritygen ; // Generated parity of received data reg rxstop ; // Stop bit of received data // Receive clock and control signals reg rxclk ; // Receive data shift clock reg rxidle ; // 1'b1 when receiver is idling reg rxdatardy ; // 1'b1 when data is ready to be read reg [2:0] cnt; // Toggle txclk every 8 counts, which divides the clock by 16 always @(posedge clkx16) begin if (reset) txclk = 1'b0; else if (cnt == 3'b000) txclk = !txclk; if (reset) cnt = 3'b000; else cnt = cnt + 1; end reg [0:3] rxcnt; // Count of clock cycles reg rx1, hunt; //rx delayed one cycle, Hunting for start bit always @(posedge clkx16) begin // rxclk = clkx16 divided by 16 rxclk = rxcnt[0]; // Hunt=1 when we are looking for a start bit: // A start bit is eight clock times with rx=0 after a falling edge if (reset) hunt = 1'b0; else if (rxidle && !rx && rx1 ) // Start hunting when idle and falling edge is found hunt = 1'b1; else if (!rxidle || rx ) // Stop hunting when shifting in data or a 1 is found on rx hunt = 1'b0; rx1 = rx; // rx delayed by one clock for edge detection // (Must be assigned AFTER reference) // Increment count when not idling or when hunting if (!rxidle || hunt) // Count clocks when not rxidle or hunting for start bit rxcnt = rxcnt + 1; else // hold at 1 when rxidle and waiting for falling edge rxcnt = 4'b0001; end always @(posedge txclk) begin if (txdone && txdatardy) begin // Initialize registers and load next byte of data txreg = txhold; // Load tx register from txhold txtag2 = 1'b1; // Tag bits for detecting txtag1 = 1'b1; // when shifting is done txparity = 1'b1; // Parity bit. Initializing to 1 = odd parity tx = 1'b0; // Start bit end else begin // Shift data // bug in assigning to slices // txreg(0 TO 6) = txreg(1 TO 7); // txreg(7) = txtag1; txreg = {txreg[1 : 7], txtag1}; txtag1 = txtag2; txtag2 = 1'b0; // Form parity as each bit goes by txparity = txparity ^ txreg[0]; // Shift out data or parity bit or stop/idle bit if (txdone ) tx = 1'b1; // stop/idle bit else if (paritycycle) tx = txparity; // Parity bit else tx = txreg[0]; //Shift data bit end end // paritycycle = 1 on next to last cycle (When txtag2 has reached txreg(1)) // (Enables putting the parity bit out on tx) assign paritycycle = txreg[1] && !(txtag2 || txtag1 || txreg[7] || txreg[6] || txreg[5] || txreg[4] || txreg[3] || txreg[2]); // txdone = 1 when done shifting [When txtag2 has reached tx] assign txdone = !(txtag2 || txtag1 || txreg[7] || txreg[6] || txreg[5] || txreg[4] || txreg[3] || txreg[2] || txreg[1] || txreg[0]); // Shift data on each rxclk when not idling always @(posedge rxclk) begin if (rxidle) // Load all ones when idling begin rxreg = 8'b11111111; rxparity = 1'b1; paritygen = 1'b1; // Odd parity rxstop = 1'b0; end else // Shift data when not idling // bug in assigning to slices // rxreg (0 TO 6) = rxreg (1 TO 7); // rxreg(7) = rxparity; begin rxreg = {rxreg [1 : 7], rxparity}; rxparity = rxstop; paritygen = paritygen ^ rxstop; // Form parity as data shifts by rxstop = rx; end end // rxidle requires async preset since it is clocked by rxclk and // its value determines whether rxclk gets generated always @(posedge rxclk or posedge reset) begin if (reset) rxidle = 1'b0; else rxidle = !rxidle && !rxreg[0]; end // Load txhold and set txdatardy on falling edge of write // Clear txdatardy on falling edge of txdone reg wr1,wr2; // write signal delayed 1 and 2 cycles reg txdone1; // txdone signal delayed one cycle always @(posedge clkx16) begin if (reset) txdatardy = 1'b0; else if (!wr1 && wr2) // Falling edge on write signal. New data in txhold latches txdatardy = 1'b1; else if (!txdone && txdone1) // Falling edge on txdone signal. Txhold has been read. txdatardy = 1'b0; // Delayed versions of write and txdone signals for edge detection wr2 = wr1; wr1 = write; txdone1 = txdone; end reg rd1, rd2 ; // Read input delayed 1 and 2 cycles reg rxidle1 ; // rxidle signal delayed 1 cycle always @(posedge clkx16) begin // Look for rising edge on idle and update output registers if (rxidle && !rxidle1) begin if (rxdatardy) // Overrun error if previous data is still there overrun = 1'b1; else begin // No overrun error since holding register is empty overrun = 1'b0; // Update holding register rxhold = rxreg; // paritygen = 1 if parity error parityerr = paritygen; // Framingerror if stop bit is not 1 framingerr = !rxstop; // Signal that data is ready for reading rxdatardy = 1'b1; end end rxidle1 = rxidle; // rxidle delayed 1 cycle for edge detect // Clear error and data registers when data is read if (!rd2 && rd1) begin rxdatardy = 1'b0; parityerr = 1'b0; framingerr = 1'b0; overrun = 1'b0; end rd2 = rd1; // Edge detect for read rd1 = read; // (Must be assigned AFTER reference) if (reset) rxdatardy = 1'b0; end // Drive data bus only during read assign data = read ? rxhold : 8'bzzzzzzzz; // Latch data bus during write assign txhold = write ? data : txhold; // Receive data ready output signal assign rxrdy = rxdatardy; // Transmitter ready for write when no data is in txhold assign txrdy = !txdatardy; endmodule
Verilog HDL 程序举例--数据接口:
关键词: Verilog 程序 举例 数据 接口 write
有奖活动 | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! | |
【有奖活动】伙伴们:您的“需求”解决了吗? |
打赏帖 | |
老胖子聊电路--分析一个反馈电路被打赏50分 | |
放大↔震荡被打赏50分 | |
【换取手持数字示波器】+DFR0216全彩灯带WS2812示例分享被打赏50分 | |
【换取手持数字示波器】安装雅特力国产IDE-AT32IDE被打赏30分 | |
【换取手持数字示波器】+DFR0654板卡驱动数码管和串口功能分享被打赏50分 | |
【换取手持数字示波器】+DFPlayerMini模块推喇叭示例分享被打赏50分 |
