共1条
How to replace the vxWorks network stack with a third party TCP/IP stack
This article cannot be a step-by-step guide for a network stack
porting job. FAE consulting and/or source code for at least some of
the network initialization libraries may be required. Below are some
files that may be needed for understanding/debugging problems:
netLib.c
sockLib.c
bsdSockLib.c
The Network Protocol Toolkit, available from Sales, is one resource.
Another is to study the way the vxworks network stack is initialized.
If vxWorks is built using the Tornado 101 way, namely defining macros
in config.h, then the place to look is in
target/src/config/usrNetwork.c
What are some of the hurdles?
1. Please note that even if you have the same BSD files, you still
have many hurdles to overcome. vxWorks is not UNIX. Some function
names may be the same, but the implementation has been
changed/optimized for embedded systems. Semaphores, timers, and
scheduling are different.
2. Replacing the vxWorks stack requires a good understanding of how
the network is initialized. You will have to look at bootConfig.c and
usrNetwork.c. Under Tornado 2.0, using the Tornado 1.0.1 Build
method, will use the initialization sequence defined in usrNetwork.c.
From the project facility:
Tools->Options->Project Click Show Tornado 1.0.1 Menu
items. Then under Build->Standard Build->
you can build images like vxWorks, or vxWorks.st.
NETWORK INITIALIZATION PROCESS
In Tornado/target/config/all/configAll.h you will find a complete
list of all the macros used to configure vxWorks with the
corresponding explanation of what they are for.
In the booting process, in usrRoot, target\config\all\usrConfig.c,
(bootConfig does something similar
for bootrom images) there is a section that calls usrNetInit if
INCLUDE_NET_INIT is defined. usrNetInit is in file
target\src\config\usrNetwork.c which does the following:
1. Pulls in header files based on the configuration macros defined in
Tornado/target/config/all/configAll.h, and Tornado/target/config/bsp
directory/config.h file.
2. Declares and initializes some global variables that control
default values for the protocols, and network memory pool.
3. Gets the boot prompt parameters left by the bootrom image.
4. Initializes the host library.
5. Initializes socket, mbufs, and protocol libraries.
6. Attaches and initializes network interface specified by the boot
device parameter. The selection of functions to call is different
based on whether the driver is an end driver, or not. BSD43 and
BSD44 drivers are a little bit different, but the differences are
inside the driver code. The external interface is the same. There is
support also for booting from floppy, or backplane interfaces.
7. Add routes to the host.
8. Creates network devices for remote file access.
9. Attaches loopback interface.
10. Initialize libraries that spawn server tasks for optional
components like telnet server, ftp server, and tftp server.
SOCKET LAYER - I/O INTERFACE
In usrNetInit from target/src/config/usrNetwork.c, the following
calls are made:
sockLibInit (NUM_FILES) which allocates an array of SOCK_FUNC
pointers.
sockLibAdd ((FUNCPTR) bsdSockLibInit, AF_INET_BSD, AF_INET) which
adds the bsd socket library backend.
sockLibInit, and sockLibAdd, from sockLib.c, install a socket
backend. This is the interface between the I/O system and the socket
layer. This is where, for example, the translation between a write,
issued on a socket file descriptor, is mapped to the socket
function "write", which eventually results in a call to sendto.
All of the routines in the sockLib library are simply entry points to
installed backends. Each backend has a unique domain value provided
by the second parameter to the sockLibAdd() routine. Currently, the
only backends available are the standard BSD sockets (AF_INET_BSD [=
101]) and STREAMS sockets (AF_INET_STREAMS [= 102]).
The current settings are defined in the ./target/h/sys/socket.h
include file. Internally, those protocols can still be referenced
with a specific (not necessarily unique) domain value provided by the
parameter.
The first parameter to the sockLibAdd() routine is a FUNCPTR to an
initialization routine which provides access to the parallel versions
of the sockLib routines. The prototype is:
SOCK_FUNC * mySockLibInit (void);
The structure to which it returns a pointer must be supplied by each
backend. It provides pointers to the domain-specific implementations
of the sockLib routines and is defined in the ./target/h/sockFunc.h
include file.
Besides providing unique implementations for each address family,
that structure also allows the new domain's socket API to duplicate
the existing function names from sockLib.c to indicate their
dependence. The prototypes for each routine match the sockLib
entries.
When a socket() call is issued, the sockLib routine searches for a
backend with a parameter that matches the given domain.
If found, the equivalent socket creation routine from the
SOCK_FUNC structure is called, substituting the
argument for the original domain value and leaving the and
entries unchanged. This is the only routine in sockLib
which does not relay the provided arguments directly to the backend counterpart.
That socket routine must obtain and return a unique file descriptor
which is not in use by any other backends. Any later calls to the
other sockLib routines will use that value to access the entries in
the returned SOCK_FUNC structure directly so that the search for the
correct backend is not repeated. The parameters to those routines are
passed directly through to the backend.
Below are snippets of code from sockLib.c, and bsdSockLib.c.
Please contact your FAE or sales representative for source code.
From sockLib.c:
/* globals */
SOCK_FUNC ** pSockFdMap = NULL;
* sockLibInit - initialize a socket library back-end library.
* RETURNS: OK, or ERROR if the back-end could not be initialized.
* NOMANUAL
STATUS sockLibInit
int fdMax /* maximum file descriptors */
/* allocate fd-to-pSockFunc mapping array */
if ((pSockFdMap = (SOCK_FUNC **) calloc (1, fdMax *
sizeof (SOCK_FUNC **))) == NULL)
return (ERROR);
From target/h/sockFunc.h:
typedef struct sockFunc /* SOCK_FUNC */
FUNCPTR libInitRtn; /* sockLibInit() */
FUNCPTR acceptRtn; /* accept() */
FUNCPTR bindRtn; /* bind() */
FUNCPTR connectRtn; /* connect() */
FUNCPTR connectWithTimeoutRtn; /* connectWithTimeout() */
FUNCPTR getpeernameRtn; /* getpeername() */
FUNCPTR getsocknameRtn; /* getsockname() */
FUNCPTR listenRtn; /* listen() */
FUNCPTR recvRtn; /* recv() */
FUNCPTR recvfromRtn; /* recvfrom() */
FUNCPTR recvmsgRtn; /* recvmsg() */
FUNCPTR sendRtn; /* send() */
FUNCPTR sendtoRtn; /* sendto() */
FUNCPTR sendmsgRtn; /* sendmsg() */
FUNCPTR shutdownRtn; /* shutdown() */
FUNCPTR socketRtn; /* socket() */
FUNCPTR getsockoptRtn; /* getsockopt() */
FUNCPTR setsockoptRtn; /* setsockopt() */
} SOCK_FUNC;
* sockLibAdd - add a socket library back-end
* RETURNS: OK, or ERROR if the socket back-end could not be added.
* NOMANUAL
STATUS sockLibAdd
FUNCPTR sockLibInitRtn, /* back-end init routine */
int domainMap, /* address family */
int domainReal /* address family */
SOCK_LIB_MAP * pSockLibMap; /* back-end mapping entry ptr */
if ((pSockLibMap = (SOCK_LIB_MAP *) malloc (sizeof (SOCK_LIB_MAP))) == NULL)
return (ERROR);
/* init socket back-end */
if ((sockLibInitRtn == NULL) ||
((pSockLibMap->pSockFunc = (SOCK_FUNC *) (sockLibInitRtn) ()) == NULL))
free (pSockLibMap); /* back-end error */
return (ERROR);
pSockLibMap->domainMap = domainMap; /* stuff mapping address family */
pSockLibMap->domainReal = domainReal; /* stuff real address family */
* bsdSockLibInit - install the BSD "socket driver" into the I/O system
* bsdSockLibInit must be called once at configuration time before any socket
* operations are performed.
* RETURNS: a pointer to the BSD socket table, or NULL.
* NOMANUAL
SOCK_FUNC * sockLibInit (void)
if (bsdSockDrvNum >; 0)
return (&bsdSockFunc);
if ((bsdSockDrvNum = iosDrvInstall ((FUNCPTR) NULL, (FUNCPTR) NULL,
(FUNCPTR) NULL, (FUNCPTR) bsdSockClose, (FUNCPTR) bsdSockRead,
(FUNCPTR) bsdSockWrite, (FUNCPTR) soo_ioctl)) == ERROR)
return (NULL);
bsdSockDev.drvNum = bsdSockDrvNum; /* to please I/O system */
bsdSockDev.name = bsdSockName; /* for iosFdSet name optimiz. */
From bsdSockMap.h:
#define sockLibInit bsdSockLibInit #define accept bsdAccept
From bsdSockLib.c:
/* locals */
LOCAL DEV_HDR bsdSockDev; /* BSD-specific device header */
LOCAL int bsdSockDrvNum; /* BSD socket driver number */
LOCAL char * bsdSockName = "(socket)" /* file name of BSD sockets */
/* declare BSD socket interface function table */
SOCK_FUNC bsdSockFunc =
(FUNCPTR) sockLibInit,
(FUNCPTR) accept,
(FUNCPTR) bind,
(FUNCPTR) connect,
(FUNCPTR) connectWithTimeout,
(FUNCPTR) getpeername,
(FUNCPTR) getsockname,
(FUNCPTR) listen,
(FUNCPTR) recv,
(FUNCPTR) recvfrom,
(FUNCPTR) recvmsg,
(FUNCPTR) send,
(FUNCPTR) sendto,
(FUNCPTR) sendmsg,
(*FUNCPTR) shutdown,
(FUNCPTR) socket,
(FUNCPTR) getsockopt,
(FUNCPTR) setsockopt
* socket - open a socket
* This routine opens a socket and returns a socket descriptor.
* The socket descriptor is passed to the other socket routines to identify the
* socket. The socket descriptor is a standard I/O system file descriptor
* (fd) and can be used with the close(), read(), write(), and ioctl() routines.
* Available socket types include:
* .IP SOCK_STREAM 18
* Specifies a connection-based (stream) socket.
* .IP SOCK_DGRAM
* Specifies a datagram (UDP) socket.
* .IP SOCK_RAW
* Specifies a raw socket.
* .LP
* RETURNS: A socket descriptor, or ERROR.
int socket
int domain, /* address family (for example, AF_INET) */
int type, /* SOCK_STREAM, SOCK_DGRAM, or SOCK_RAW */
int protocol /* socket protocol (usually 0) */
int newFd;
/* search for a suitable back-end library entry */
for (pSockLibMap = pSockLibMapH; (pSockLibMap != NULL) &&
(pSockLibMap->domainMap != domain); pSockLibMap = pSockLibMap->pNext)
/* found library map entry ? */
if ((pSockLibMap == NULL) || (pSockLibMap->pSockFunc->socketRtn == NULL))
netErrnoSet (ENOTSUP);
return (ERROR);
/* call back-end to open a socket */
if ((newFd = (pSockLibMap->pSockFunc->socketRtn)
(pSockLibMap->domainReal, type, protocol)) == ERROR)
return (ERROR);
pSockFdMap[newFd] = pSockLibMap->;pSockFunc; /* stuff fd map array */
return (newFd);
HOST TABLE INITIALIZATION
hostTblInit (); /* initialize host table */
MBUF AND PROTOCOL INITIALIZATION
usrNetProtoInit (); /* SENS only: initialize various protocols */
netLibInit ();
In the SENS stack, some of the protocol parameters are set by the
user. usrNetProtoInit calls, for example, tcpLibInit to initialize
the values that will be used by TCP such as:
#ifdef INCLUDE_TCP
TCP_CFG_PARAMS tcpCfgParams = /* tcp configuration parameters */
TCP_FLAGS_DFLT, /* include rfc1323 support */
TCP_SND_SIZE_DFLT, /* default send buffer size */
TCP_RCV_SIZE_DFLT, /* default recv buffer size */
TCP_CON_TIMEO_DFLT, /* initial connection time out */
TCP_REXMT_THLD_DFLT, /* retransmit threshold */
TCP_MSS_DFLT, /* default maximum segment size */
TCP_RND_TRIP_DFLT, /* default round trip time */
TCP_IDLE_TIMEO_DFLT, /* idle timeouts before first probe */
TCP_MAX_PROBE_DFLT /* max no. probes before dropping */
#endif /* INCLUDE_TCP */
#ifdef INCLUDE_TCP
tcpLibInit (&tcpCfgParams); /* tcp protocol initialization */
#ifdef INCLUDE_NET_SHOW
tcpShowInit ();
#endif /* INCLUDE_NET_SHOW */
netLibInit, from netLib.c, initializes the mbuf pool, the watchdog
timers for the protocols, calls the init function for the internet
protocols, and spawns tNetTask.
tNetTask has a work queue, where drivers, or protocols can add
functions to be called at task level to do packet processing that
should not be done at interrupt level. tNetTask runs at priority 50,
which should be higher than the priority of any task that
uses the network. Application tasks usually run at priority 100.
关键词: replace vxWorks network s
共1条
有奖活动 | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! | |
【有奖活动】伙伴们:您的“需求”解决了吗? | |
抽奖了,抽奖了,金升阳医疗电源 |
打赏帖 | |
【换取手持数字示波器】+与同事对定时器输出相位可调PWM移相全桥控制分享被打赏50分 | |
【换取手持数字示波器】+LP-MSPM0L1306开发板试用体验+串口被打赏40分 | |
CC-RL编译器相关问题求助被打赏10分 | |
【换取手持数字示波器】+与同事对ESP-12开发调试经验分享被打赏50分 | |
【换取手持数字示波器】+同事tek示波器调试spi解析被打赏50分 | |
【换取手持数字示波器】+2.6寸墨水屏调试经验被打赏50分 | |
换取手持数字示波器+个人开关电源的设计经验被打赏50分 | |
【换取手持数字示波器】+【APT32F173测评】+URAT被打赏20分 | |
【换取手持数字示波器】CH32X035的定时器以及外部中断体验被打赏50分 | |
【换取手持数字示波器】CH32X035搭建开发环境(RISC-V)被打赏50分 |
