选择FTP BOOT 模式,出现以下现象,有可能是什么引起的?
target boot line:
boot device : End
unit number : 0
processor number : 0
host name : host
file name : vxWorks
inet on ethernet (e) : 198.87.0.11 :ffff0000
host inet (h) : 198.87.0.10
gateway inet (g) : 198.87.0.1
user (u) : xx
ftp password (pw) : xx
flags (f) : 0x0
target name (tn) : s3c2410
Attached TCP/IP interface to sng0.
Warning: no netmask specified.
Attaching network interface lo0... done.
Loading... 655386
WFTP log Infomation:
Connection accepted from 198.87.0.11
Command "USER xx" received
PASSword accepted
User xx logged in
Command "TYPE I"received
TYPE set to I N
Command "PASV"received
Entering Passive Mode[198.87.0.10,12,64]
Command "RETR vxWorks"received
RETRieve start on file vxWorks
Transfer aborted
Got file ....\vxWorks unsuccessfully
Socket error 10054 while sengding data
QUIT or close -user xx logged out
从本地连接中能看到,每次启动,PC机大约发了300多帧,接收到80多帧,然后就出现以上情况,死在那儿了,按说如果网络驱动有问题,前面那些发送接收应该也会有问题,偏偏到了要下传image时出问题,因此怀疑是不是config里有没设对的地方,在baidu和google上也搜到过类似现象的帖子,但都没有一个合理的解释,希望有人指教,谢谢!
附类似问题帖子的地址:
http://bbs.cedn.cn/viewthread.php?tid=6093
http://csg.lbl.gov/vxworks/vxwexplo/2001/archive0102
http://groups.google.com/group/c ... f9/c637191a2e5b86a7
http://groups.google.com/group/c ... 4b#ea9c22ad7bd7514b
