#include "reg52.h"
#define uchar unsigned char
#define uint unsigned int
void delay1ms (uint t)
uint i;
while (t--)
{for (i=0;i<125;i++){}}
void uart_init( void )
SCON = 0xe0 ; //SCON: serail mode 3, 11-bit UART, enable ucvr
TMOD |= 0x20 ; //TMOD: timer 1, mode 2, 8-bit reload
PCON |= 0x00 ; //SMOD=0;
TH1 = 0xFD ; //Baud:9600 fosc=11.0592MHz
IE |= 0x90 ; //Enable Serial Interrupt
TR1 = 1 ; // timer 1 run
delay1ms (1);
bit ecc_test (uchar dat)
uchar i,count;
bit ecc;
for (i=0;i<8;i++)
if ((dat>>i)&0x01)
count=count+1;
if (count&0x01)
{ecc=0;}
else
{ecc=1;}
return ecc;
void uart_send( uchar ch)
TB8=ecc_test (ch);
SBUF=ch;
while (TI== 0 );
TI= 0 ;
void uart_com (uchar add,dat)
uchar com;
delay1ms (4);
uart_send (add);
delay1ms (4);
uart_send (dat);
void main ()
复制来自:
http://89c51.5d6d.com/viewthread.php?tid=1367&extra=
