电子产品世界 » 论坛首页 » 休闲专区 » 我爱工作 » 北京/上海/西安/成都/深圳10个名企热招职位!
2011-04-07 17:14:57     打赏
1.欧洲名企招聘:(Senior) BB HW Engineer
本职位系统编号:223104039437
工作地点:北京
联系顾问:邮箱melody-shi@kthr.com,MSN: shixiaoyun11@hotmail.com
岗位描述:
Key Responsibilities: Be responsible for the BB development in wireless telecommunication system, including: · BB sub-system design · BB component selection and evaluation · SI/EMC/ESD design and test · BB sub-system debug and test · Draft related document including design document, test document, etc · Customer support in HW domain
职位要求:
Job Specifications: § BA/MA degree or above in telecommunication or electronic engineering(master degree is preferred) § At least 5 years BBHW R&D and test experience (the candidate with experience of mobile phone BB HW design is preferred) § Can implement BB system/sub-system design, debug and test independently § Familiar with BB HW development tool and testers, including high-speed scope, JTAG tool, ETM tool, etc. § Have experience in high-speed data bus design and test. § Have experience in EMI/ESD/EMC design, trouble shooting and verification. § Good background in circuit theory including analog circuit and digital circuit. § Familiar with some EDA software, such as Mentor, Cadence, Power PCB, etc. § Have experience in design and application of connectivity HW units design, such as FM/BT, AGPS, WLAN, etc. § Good team-working capability § Fluent in written and spoken English
2.美资跨国公司诚招Manager STB Design In
本职位系统编号:22317284703
工作地点:深圳
岗位描述:
RESPONSIBILITY: STB software manager for STB Shenzhen team, customer project Design-in, and customer technical support
职位要求:
QUALIFICATION: 1.Bachelor or Master degree of Electrical engineering or Computer Engineering. 2.More than 5 years experience in embedded system software, focusing on applications like STB, Digital TV and Media player box. 3.Familiar with C/C++ programming language and Linux/Nucleus operating system, also DVB/MPEG protocol. 4.Good communication and program management skills.
3.日企急招Algorithm and the chip development - the audio/video
本职位系统编号:228133217125
工作地点:成都
联系顾问:邮箱jane-wu@kthr.com,MSN:merrill.04@hotmail.com
岗位描述:
1、负责研究图像编解码,图像处理,音频编解码,音频处理及通信系统或子系统的算法、保证性能指标满足设计要求;
2、参与确定以上算法的结构设计及硬件实现;
职位要求:
1、硕士及以上学历,电子、通信类专业;
2、熟悉图像编解码,或图像处理,或音频编解码,或音频处理,或通信系统的相关知识、及相关产品知识;
3、熟悉Matlab,HDL硬件描述语言和C语言;
4、有较好的沟通能力、技术分析判断力、创新能力;
5、责任心强,团队意识强,事业心较强,心理承受力较强。
4.美资诚招System Hardware Designer
本职位系统编号:31111059656
工作地点:上海
联系顾问:邮箱effie-huang@kthr.com,MSN:euphemia1031@hotmail.com
岗位描述:
Responsibilities: 1. Participate on the discussion of system requirements, specifications, architecture, algorithms of DTV PHYs, such as ISDB-T, CMMB 2. Build fixed point cycle accurate C Model according to algorithm and floating point Matlab system model. 3. Work with digital designers to ensure efficient implementation and verification 4. Lab test, performance evaluation and field trials of DTV PHYs based on both FPGA and silicon. 5. Other duties as assigned
职位要求:
Qualifications: 1. PhD/MS degree in telecommunication or signal processing 2. Enthusiasm for algorithm design, open-minded, dedicated and easy-going 3. Solid theory and mathematical foundation, strong Digital Signal Processing knowledge in the area of wireless communication 4. More than 2 years work experience in signal processing or the communication field are necessary 5. Strong background and experience in ISDB-T/CMMB/DVB-T is much preferred 6. Proficiency in one or more of the following areas is preferred, e.g., OFDM, equalizer, channel coding/decoding, Channel estimation, timing/frequency synchronization, Filtering, AGC 7. Excellent programming skill is really good plus 8. Work experience in FPGA or DSP implementation is a plus 9. Good English skills
5.美资业内领先公司急聘:Layout Engineering Specialist
本职位系统编号:34114519905
工作地点:西安
联系顾问:邮箱lincy-cao@kthr.com,MSN:caoqilan_8@hotmail.com
岗位描述:
DESCRIPTION Develop challenging and innovative analog, and mixed-signal IC layout. See your creative work result in commercially successful products. Design with best sub-micron, mixed signal process technologies in the industry; Responsibilities include the development and preparation of multi dimensional layouts and detailed drawings of the semiconductor devices from schematics and related geometry provided by design engineering. Work may be completed through use of CAD equipment. Checks dimensions, writes specifications, and verifies completed drawings, artwork or digitized plots. May check design layouts and detailed drawings. QUALIFICATIONS Successful candidates will have 2+ years of experience in analog IC layout. Experience in analog and mixed signal layout skills like: bandgap voltage reference, analog and digital circuit interactions, and ESD restrictions. Experience with Cadence CAD tools; Be proficient in written and spoken English
6.美企招聘System Engineer-EBU(switch)
本职位系统编号:3915810984
工作地点:上海
联系顾问:jane-wu@kthr.com,MSN:merrill.04@hotmail.com
岗位描述:
EDUCATION: > MSEE required, PhD preferred > > EXPERIENCE: > The Senior Systems Engineer role requires: > MSEE required, PhD preferred > Development and test experience including high speed digital and analog design > Development and test experience of baseband signal processing algorithms > Understanding of system level performance issues > Experience in analog and digital integration > Experience in board level design > Broad knowledge of industry standards and analog and digital design techniques > Working knowledge and design experience with embedded systems, firmware, development tools, microcontrollers, digital signal processing, mixed signal, analog, and power management.
职位要求:
DESCRIPTION OF FUNCTION & RESPONSIBILITY: > The Sr. Systems Engineer will be responsible for Ethernet switch chip definition and bring up. In this role the Sr. Systems Integration engineer will engage with the algorithms, analog, and digital design teams, to prepare for initial silicon bring up and performance evaluation. Feedback of chipset strengths and weaknesses in early silicon bring up to prepare for production silicon is also a key aspect of this role. This role includes ownership of chip initialization parameters and procedures, integration of hardware and software, and conducting system level performance tests on Ethernet switch platforms. In addition, the engineer will provide product related technical services and support, including: product specification assistance, debugging and testing of customer platforms, and product training for customers and internal development groups. The Sr. Systems Integration Engineer will also generate system architecture and application notes detailing system solutions for current and future products. > > In this position, you will be responsible for: > Participating in definition and specification of system architectures. > Review of test coverage for silicon characterization, board-level reference design characterization, and software performance testing. > Integration of hardware, software, and chips into a system. > Proving design through system-level acceptance testing. > Independent review of optimal switch system parameters and configurations and identification of performance bottlenecks. > System level analysis of customers' designs. > Providing technical assistance to AE and production personnel related to the use and application of products.
7.英资诚聘RF engineer
本职位系统编号:314101348281
工作地点:上海
联系顾问:effie-huang@kthr.com,MSN:euphemia1031@hotmail.com
岗位描述:
Responsibilities
1. RF system design on schematic and PCB layout review, including critical component specification and part selection, RF chain margin calculation, device interconnection check, PCB EMI analysis and cross interference check.
2. Perform board level debug and testing including impedance matching (noise figure and gain for RX, power and efficiency for TX), device operating point optimization, RF calibration, 3GPP non-signaling/signaling testing target for GCF compliance.
3. Collaborate with core team engineers for specific issue logging, feedback, debugging and problem solving.
4. Provide technical support to customers and work with technical team and/or FAE for customer R&D projects.
职位要求:
Required skills and experience
1. 5~10 years experience in cellular radio system design or testing
2. Understanding of general RF and microwave principles including Smith Chart, multi-port S-parameter calculation, transmission line theory and impedance matching etc.
3. Knowledge of RF circuit analysis including filter design, noise figure calculation, amplifier (LNA/PA) design, oscillators and mixers, phase lock loop design etc.
4. A good knowledge in RF components, such as RF transceiver, SAW, duplexer, LNA and RF switch.
5. Experienced in lab hands-on test fixture and prototype making and impedance matching and tuning
6. Knowledge and experience in RFIC characterization and test, understand principles of RF calibrations and device optimization.
7. Experience and knowledge of GSM/GPRS/EDGE/WCDMA phone development process and RF performance DVT steps. Familiar with compliance tests for GCF/PTCRB
8. Familiar with RF testing equipments, CMU200, Agilent 8960, network analyzer, spectrum analyzer, and signal generator.
9. A good working attitude.
10. Excellent oral and written communications and interpersonal skills' able to function effectively in a team environment.
11. Master degree in Electrical Engineering with a specialization in telecommunications
12. Knowledge of RF system link budget calculation, wave propagation, antenna modeling and design is a plus.
8.高成长期民营急聘:RF IC design engineer
本职位系统编号:31411421862
工作地点:上海
联系顾问:Email&MSN:       Digital1@kthr.com
岗位描述:
1、设计基于CMOS工艺的无线接收、发射系统,实现一个或多个射频模块如LNA, Mixer, PGA, PA,ADC,DAC等设计。
2、进行后端版图开发,参数提取并后仿验证。
3、使用实验室测试设备对工程样片进行特性评价、系统调试。
任职要求:
1、微电子、电子工程、通信等电子类相关专业,硕士或本科三年以上RF设计工作经验。
2、深入理解射频通信电路各种模块工作原理及性能指标,熟练掌握CMOS RF IC设计,如LNA、 Mixer、VGA、VCO、PLL中的一种电路等。
3、熟悉RF设计中的仿真、版图设计必需的EDA工具如ADS,Cadence,Matlab等。
4、良好的英文读、写能力。
5、具有良好人际沟通能力、主动性及团队合作精神。
9.美资跨国公司急聘:Senior system HW Engineer
本职位系统编号:3141723220
工作地点:上海
联系顾问:邮箱melody-shi@kthr.com,MSN:shixiaoyun11@hotmail.com
岗位描述:
Responsibilities (may include some of the following) Requirement Scoping, Development, Testing and Feature maintenance of Tv and Set box related SoCs, Back end, etc.
职位要求:
Skills Required familiar with the Linux OS and the MIPS, ARM structure. Experience in Ethernet, DDR, PCI, I2C, Flash, SPI, SATA, SDIO, USB, Modem, IR drivers Familiar with the hardware validation of the high speed circuit and the production process. Experience in bootloader (optional) Master is must to have. (Not including the “工程硕士”). Bachelor with about 8 year’s experience is fine. 985 program university is the first option. 211 program university is the bottom line Education and Industry Experience: ME / MTECH / BE / BTECH in Electronics/Computer etc. 4-8 years of industry experience
10.全球领先半导体公司急聘Verification Architect
工作地点:上海
岗位描述:
Job Responsibilities: Reporting to IC Design Director, the candidate is expected to be responsible for following tasks: Ø Champion department verification/emulation methodology, evaluate and integrate cutting edge solutions/platform into the tool flow Ø Apply specialist skills in both hardware and software to perform Pre-Silicon verification for complex Media Processor SOC devices Ø Perform co-verification of processor models and RTL including application software and firmware verification Ø Support the development of multi abstraction/views to enable a thorough SoC verification from unit level to system level Ø Work with other cross functional teams in China and oversea to specify, verify and improve SoC quality and timeliness to production
职位要求:
Job Requirements: Ø Bachelor or above degree in Electrical Engineering or related area, MSEE is preferred. Ø 10 years or above experience in ASIC/complex SoC design or verification. Ø Experience of SOC designs with embedded processor cores and their integration with other system components including memory subsystems and peripherals. Ø Familiar with Microprocessor and/or DSP instruction sets and how low level driver software integrates into SOC architecture. Ø Familiar with HDL languages, simulation tools and testbench design, low level assembler languages and C, or C++, scripting languages Ø Good English and communication skills; will need frequent communication with foreign team. Ø Experience on verification methodology development and project management is a plus
职位来源:胡说IC
关键词: 北京     上海     西安     成都     深圳     10个     名企     热招
