Bluetooth to 1-Wire® Communication Using the DS9097U
关键词: bluetooth, wireless, mobile, 1-Wire, alternative, Wi-Fi, radio, exchange, range, communication, SPP, serial, profile, phone, DS1920, DS1922, DS1923, temperature, COM
Abstract: This application note explains how to enable communication between a Bluetooth® serial and Maxim 1-Wire adapters. Topics discussed are: selecting the proper Bluetooth adapter, setup instructions, and sample code to enable the communication. The DS9097U 1-Wire COM Port Adapter is used to receive the Bluetooth commands.
Bluetooth to 1-Wire® Communication Using the DS9097U.pdf
