电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Current-Limit Switch Is Digitally Progra
Current-Limit Switch Is Digitally Programmable
2012-04-13 17:22:54     打赏
关键词: current limited, current-limit, switch, digital potentiometer, digital pots, P channel switch, switches
Abstract: Current-limit switches are virtually ubiquitous in system controls. They provide a safe means for regulating the current delivered to a load circuit. The switches allow the load current to increase to a programmed limit but no higher. This application note illustrates the implementation of a digitally programmable current-limit switch using MAX890L a current-limited, high-side P-channel switch and MAX5160 digital potentiometer
 Current-Limit Switch Is Digitally Programmable.pdf
关键词: Current-Limit     Switch     Digi
