电子产品世界 » 论坛首页 » 综合技术 » 测试测量 » MIPI测试方案
共3条 1/1 1 跳转至
MIPI测试方案
2012-04-13 22:01:09     打赏
力科提供符合MIPI联盟D-PHY v1.00.00规范要求的发送器物理层测试方案。
QPHY-MIPI-DPHY
Test Solution provides automated control for LeCroy oscilloscopes for performing transmitter physical layer tests as described by the MIPI Alliance Specification for D-PHY version 1.00.00
Key Features
  • Compliant with the MIPI Alliance Specification for D-PHY version 1.00.00
  • Fastest way to gain confidence in your D-PHY interface by measuring a large number of cycles and reporting statistical results
  • Support for both systems with continuous and noncontinuous clocking
  • Integrated D-PHY, CSI-2 and DSI decoders
  • Debug compliance failures easily using the MIPI D-PHY debug utility included in the software
  • Fully annotated worst case measurement screenshot captured and displayed in report
  • QualiPHY automated test framework provides connection diagrams, automated oscilloscope operation and report generation
The LeCroy QPHY-MIPI-DPHY
QPHY-MIPI-DPHY enables the user to obtain the highest level of confidence in their D-PHY interface. Due to the high level of variability in D-PHY measurements it is important to measure a large number of cycles. By measuring a large number of cycles in a very short period of time the user can be more confident that they are catching the true maximum and minimum points for their measurement.
The LeCroy QualiPHY platform provides an easy to configure user interface, allows for custom test and limit selection, displays connection diagrams to the user to ensure proper connectivity, and generates a comprehensive test report. In addition, all of the waveforms tested by QPHY-MIPI-DPHY can be saved to easily share information or rerun the tests at a later time.
Additionally, QPHY-MIPI-DPHY will display and record the worst case instance of the test that is being performed. This worst case instance will be zoomed and captured in the compliance report.
In addition to automated characterization of MIPI D-PHY signals, QPHY-MIPI-DPHY also enables powerful debug capability for MIPI D-PHY signals inside the oscilloscope. The integrated MIPI D-PHY Debug utility and decoders are the perfect combination for identifying the root cause of compliance failures.
Although there is currently no official compliance program for MIPI D-PHY signals, it is highly recommended that devices are tested against the limits specified in the MIPI Alliance Specification for D-PHY.
For debug purposes QPHY-MIPI-DPHY will create the single-ended and differential eye diagrams for the clock and data high-speed signals. Although there is no formal eye diagram test required by the specification, these eye diagrams make it possible to gain quick insight into signal quality of the clock and data lines.
The LP tests verify that the low-power signals' electrical and timing characteristics fall within the required compliance limits. These tests are performed on an Escape Mode sequence. Typically an Ultra Low Power State (ULPS) entry command is used but other sequences can be used also.
The HS tests verify that the high-speed signals' electrical and timing characteristics fall within the required compliance limits. These tests are performed on any data capture that contains multiple high-speed bursts. These include tests performed on the data signals, the clock signals and also tests performed that validate timing parameters between the clock and data lines.
Tools For Debugging MIPI D-PHY
  • Decodes MIPI D-PHY, CSI-2, and DSI signals
  • Correlate analog waveforms with protocol decode on one screen
  • Decode up to 4 differential data lanes using the CDR feature
  • View decoded data in hexadecimal format
  • Decode information expands as the time base is adjusted or zoomed
  • Convenient table display with quick "Zoom to byte" capability
  • Quick search capability for specific message packets
  • Supports decode for LP & HS, HS only and LP only
  • Supports single-ended and differential probing for Data and Clock
The MIPI D-PHY decode is the ideal tool for powerful system level protocol debug as well as problem solving for signal quality issues. The D-PHY decode solution adds a unique set of tools to your oscilloscope, simplifying how you design and debug MIPI D-PHY, CSI-2 and DSI signals.
The Most Intuitive Decode
MIPI D-PHY decode uses color-coded overlays on various sections of the protocol for an easy-to-understand visual display. Depending on the time base or the amount of zoom, the decode information is condensed or expanded to better assist in understanding events during short or long acquisitions.
The Single Tool Enhances Productivity
The D-PHY D solution concentrates all your information in one place. Viewing the application layer of D-PHY signals on top of the physical layer provides a unique view that bus analyzers cannot. A full suite of amplitude and timing measurements can be applied to debug physical layer issues that may not be apparent in a protocol view.
关键词: 测试     方案     D-PHY
2012-04-13 22:02:33     打赏
D-PHY D
Key Features
The D-PHY decode solution concentrates all your information in one place. Viewing the application layer of D-PHY signals on top of the physical layer provides a unique view that bus analyzers cannot. A full suite of amplitude and timing measurements can be applied to debug physical layer issues that may not be apparent in a protocol view.
Complete Compliance and Debug
For a complete MIPI toolset, LeCroy offers a D-PHY compliance package as well as a decode package for DigRF 3G signals. QPHY-MIPI-DPHY provides automated compliance testing to the MIPI Alliance specification for D-PHY version 1.00.00. The DigRF 3G decode package offers a quick and powerful way to debug the DigRG 3G design challenges.
Quick and Easy Setup
Configure your MIPI D-PHY decode setup with flexibility to support any probing and lane combination. First select signal type, then data and clock probing configuration.
Convenient Table Display Summarizes Results
Turn your oscilloscope into a protocol analyzer with the table display of protocol information. Custom configure the table to display the information you want, and export table data into an Excel file. Touch the message in the table and automatically zoom for detail. In all cases, the table never obscures your waveform.
Search and Zoom
Search through a long record of decoded data by entering any of the 28 available search criteria by entering a value or simply finding the next occurrence.
Search on:
IDX TLPX-CLK DT
Time TLP01-CLK WC
TLPX-DATA TCLK-PREPARE ECC
TPL01-DATA TCLK-ZERO Msg
THS-Prepare TCLK-HS Data
THS-ZERO TCLK-TRAIL HSO
THS-SYNC TCLK-REOT HS1
THS-TRAIL DI Bitrate/Byte
TREOT VC Status
Attributes
2012-04-13 22:04:21     打赏
DigRF 3G Bus
The DigRF 3G decode is the ideal tool for powerful system level protocol debug as well as problem solving for signal quality issues. The DigRF 3G decode adds a unique set of tools to your oscilloscope, simplifying how you design and debug MIPI digital RF systems.
Key Features
  • Decodes Low-speed (6.5 Mb/s), Medium-speed (26 Mb/s) and High-speed (312 Mb/s)
  • Convert DigRF 3G I and Q digital data to corresponding analog waveforms
DigRF 3G decode uses color-coded overlays on various sections of the protocol for an easy-to-understand visual display. Depending on the time base or the amount of zoom, the decode information is condensed or expanded to better assist in understanding events during short or long acquisitions.
The DigRF 3G decode solution concentrates all your information in one place. Viewing the application layer of DigRF 3G signals on top of the physical layer provides a unique view that bus analyzers cannot. Measurements such as amplitude and rise time help to debug physical layer that may not be apparent in a protocol view.
For a complete MIPI toolset, LeCroy offers a D-PHY compliance and decode package. QPHY-MIPI-DPHY provides automated compliance testing to the MIPI Alliance specification for D-PHY version 1.00.00. The D-PHY decode solution provides a simple and powerful debug solution for D-PHY, CSI-2 and DSI signals.
Convert Digital RF Signal to RF View
With the addition of the PROTObus MAG Serial Debug Tookit, DigRF 3G I and Q digital data payload fields may be quickly converted into a corresponding I and Q analog waveform representation for easy analysis and debug. View the I, Q or both waveforms in the time domain, and perform time / delay measurements on I and Q signals.
Search and Zoom
Search through a long record of decoded data by entering any of the 14 available search criteria by entering a value or simply finding the next occurrence.
Search on:
Message Comment
Time Payload
Sync Payload Size
LCTS Idata
CTS/RTI Q Data
TxRx Frame
Word Name Attributes
共3条 1/1 1 跳转至
