电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » Battery/Charger Load Switch Approximates
Battery/Charger Load Switch Approximates Ideal Diode
2012-04-22 14:39:02     打赏
关键词: load switching, rechargeable battery-powered systems, Li+ battery chargers, power OK (POK) outputs
Abstract: Two circuits are described. The first uses external MOSFETs driven by the Power OK (POK) output of a Li-cell charger IC (MAX8814), to switch a load between battery and charging source without intervention from a microcontroller or system software. For charger ICs without a POK output (such as the MAX1507), the second circuit does the same switching using MOSFETs and a comparator (MAX920).
 Battery Charger Load Switch Approximates Ideal Diode.pdf
关键词: Battery     Charger     Switch     Ap
