【应用手册】Implementing CRCCs in Altera Devices
Redundant encoding is a method of error detection that spreads the
information across more bits than the original data. The more redundant
bits you use, the greater the chance that you will detect transmission
errors. For example, a 16-bit increase in data record length misses 1 error
in 65,536, while a 32-bit increase misses only 1 error in over 4 billion.
Although these odds are favorable, undetectable errors can still occur.
The nature of common errors varies depending on the transmission and
storage medium, but undetectable errors can be caused by occasional
isolated-changed bits or short bursts of multiple-changed bits. To
minimize undetectable errors, you can distribute the data so that it is less
likely that transmission errors result in a valid encoding of an alternate set
of data.
Cyclic redundancy codes (CRCs) are a favored type of redundant
encoding. Cyclic redundancy code checkers (CRCCs) check for
differences between transmitted data and the original data. Data
transmission applications use CRCCs extensively. For example, the
Asynchronous Transfer Mode (ATM) specification requires a CRCC that
is implemented across the entire payload to ensure data integrity.
an049_01.pdf
共1条
关键词: 应用 手册 Implementing CRCCs
共1条
有奖活动 | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! | |
【有奖活动】伙伴们:您的“需求”解决了吗? | |
抽奖了,抽奖了,金升阳医疗电源 |
打赏帖 | |
【换取手持数字示波器】+与同事对定时器输出相位可调PWM移相全桥控制分享被打赏50分 | |
【换取手持数字示波器】+LP-MSPM0L1306开发板试用体验+串口被打赏40分 | |
CC-RL编译器相关问题求助被打赏10分 | |
【换取手持数字示波器】+与同事对ESP-12开发调试经验分享被打赏50分 | |
【换取手持数字示波器】+同事tek示波器调试spi解析被打赏50分 | |
【换取手持数字示波器】+2.6寸墨水屏调试经验被打赏50分 | |
换取手持数字示波器+个人开关电源的设计经验被打赏50分 | |
【换取手持数字示波器】+【APT32F173测评】+URAT被打赏20分 | |
【换取手持数字示波器】CH32X035的定时器以及外部中断体验被打赏50分 | |
【换取手持数字示波器】CH32X035搭建开发环境(RISC-V)被打赏50分 |
