【应用笔记】Stratix II, Stratix和Stratix GX器件和RLDRAM II的接口(Interfacing RLDRAM II with Stratix II, Stratix,& Stratix GX Devices)
低延迟DRAM II(reduced latency DRAM II,RLDRAM II)是一种基于DRAM的点对点存储器器件,为通信、图像、服务器系统等要求高密度、高带宽和低延迟而设计。
Reduced latency DRAM II (RLDRAM II) is a DRAM-based point-to-point
memory device designed for communications, imaging, and server
systems requiring high density, high memory bandwidth, and low
latency. The fast random access speeds in RLDRAM II devices make them
a viable alternative to SRAM devices at a lower cost.an325.pdf
共1条
共1条
有奖活动 | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! | |
【有奖活动】伙伴们:您的“需求”解决了吗? |
打赏帖 | |
老胖子聊电路--分析一个反馈电路被打赏50分 | |
【换取手持数字示波器】+线性调整器理论知识分享被打赏40分 |
