挥泪奉献——关键技术网站
Designing An Embedded Web Server
http://www.computer.org/internet/v2n3/w3design.htm
Embedded Web Server and Internet Application Software
http://www.allegrosoft.com/
Embedded Web Server - Hydra
http://portolano.cs.washington.edu/projects/hydra/
Boa: An Embedded Web Server
http://embedded.linuxjournal.com/magazine/issue04/4773/?sid=f77814ed988fb40334fc334c1148766a
Tini Server Resources Home
http://www.apms.com.au/tini/
Boolean Search Server
http://www.limit-point.com/BooleanSearch.html
IPic - A Match Head Sized Web-Server
http://www-ccs.cs.umass.edu/~shri/iPic.html
World Smallest Web Server
http://wearables.stanford.edu/
Building The World Smallest Web Server
http://www.realtime-info.be/magazine/98q1/1998q1_p070.pdf
ETS Micro Web Server
http://www.monkey.org/geeks/archive/9808/msg00036.html
The Real Time for Java Expert Group
http://www.rtj.org/
The Real Time Specification for Java V.1.0 Final
http://www.rtj.org/rtsj-V1.0.pdf
PERC - An Embedded Java Virtual Machine
http://www.newmonics.com/
The Simple Real-Time Java
http://www.rtjcom.com/home.html
JSR (Java Specification Request) JSR 1 Real Time Specification for Java
http://jcp.org/jsr/detail/1.jsp
NIST Requirements for Real Time Java
http://www.itl.nist.gov/div897/ctg/real-time/intro.html
Embedded and Real-Time Systems Links
http://www.ifi.unizh.ch/groups/ailab/links/embedded.html
J Consortium Accelerating Java Technology Into Real Time
http://www.j-consortium.org/
First Java Specification JEFF Submitted To ISO
http://www.j-consortium.org/press.releases/pr040901.pdf
JEFF Specification 1.0 Makes Java Technology Dramatically Less Costly for Devices with Small
Memory
http://www.j-consortium.org/press.releases/pr031301.pdf
The OMG and J Consortium Form Strategic Alliance Collaboration On Real-Time and Object-Oriented Systems Standards
http://www.j-consortium.org/press.releases/pr012501.shtml
Draft International J Consortium Specification Real Time Data Access for The Java Platform m Revision 1.8, February 10, 2001
http://rtawg.khe.siemens.de/rtaccess18.pdf
Jini (Java Intelligence Network Infrastructure) Network Technology White Papers
http://www.sun.com/jini/whitepapers/
Jini Network Technology An Executive Overview
http://www.sun.com/jini/whitepapers/jini-execoverview.pdf
Jini Architectural Overview
http://www.sun.com/jini/whitepapers/architecture.pdf
Why Jini Technology Now ?
http://www.sun.com/jini/whitepapers/whyjininow.pdf
Virtual Organizations, Pervasive Computing, and an Infrastructure for Networking at the Edge
http://www.sun.com/jini/whitepapers/jiniEDGEwp052501.pdf
Java[tm] Technology Powers E-Manufacturing
http://www.sun.com/jini/whitepapers/java_emanufacturing.pdf
Enterprise Jini Architecture -- Where Will Your Network Be Tomorrow ?
http://www.softwaresummit.com/2001/speakers/petkar.htm
Jini Architecture Specification
http://www.cs.princeton.edu/courses/archive/fall99/cs597b/docs/jcpdoc1_0/specs/jini-spec/jini-spec.pdf
The Jini Specification (Book) 1999
http://www.amazon.com/exec/obidos/ASIN/0201616343/104-4538233-0435914
Jini: A Pathway for Intelligent Network Storage The Growing Need for Intelligent Storage
http://www.seagate.com/newsinfo/newsroom/papers/D2c1.html
Moving Toward Effortless Networking
http://research.microsoft.com/~bahl/papers/pdf/ieee_Computer.pdf
http://www.computer.org/computer/co1998/ry012abs.htm
Universal Plug and Play (UPnP)
http://www.upnp.org/
http://www.microsoft.com/hwdev/tech/nonpc/UPnP/default.asp
Understanding UPnP White Paper
http://www.upnp.org/download/UPNP_understandingUPNP.doc
Devices That Play Together, Work Together
http://www.e-insite.net/ednmag/index.asp?layout=article&articleId=CA154802
Universal Plug and Play Forum Creates UPnP? Implementers Corp. (UIC) and Completes First Certification Standard: Internet Gateways
http://www.upnp.org/news/pr_fcsig.asp
Internet Gateway Device (IGD) Standardized Device Control Protocol V1.0
http://www.upnp.org/resources/standards.asp
Flexible XML Processing Profile (FXPP)
http://www.upnp.org/download/draft-goland-fxpp-01.txt
Dynamic Configuration of IPv4 link-local addresses
http://www.upnp.org/download/draft-ietf-zeroconf-ipv4-linklocal-01-Apr.txt
Simple Service Discovery Protocol/1.0 Operating without an Arbiter
http://www.upnp.org/download/draft_cai_ssdp_v1_03.txt
Multicast and Unicast UDP HTTP Messages
http://www.upnp.org/download/draft-goland-http-udp-04.txt
General Event Notification Architecture Base: Client to Arbiter
http://www.upnp.org/download/draft-cohen-gena-client-01.txt
UPnP SDKs
http://www.upnp.org/resources/sdks.asp
Home Audio/Video Interoperability (HAVi) 标准之争,来自国际信息家电
http://www.nandamen.com/new_page_10.htm
Sun, Sony, Philips wiring homes Jini/HAVi
http://news.com.com/2100-1040-220315.html?tag=bplst
PHILIPS, SONY AND SUN TO JOIN IN INTERNET LINK FOR APPLIANCES
http://industry.java.sun.com/javanews/stories/story2/0,1072,10992,00.html
About HAVi
http://www.havi.org/about/index.html
HAVi FAQs
http://www.havi.org/about/faq.html
HAVi Specification V1.1 Download
http://www.havi.org/techinfo/index.html
Jini Technology: Impromptu Networking and Its Impact on Telecommunications
http://198.11.21.25/capstoneTest/Students/Papers/docs/Jini_Proceedings35119.pdf
Lucent InfernoSpaces Technology
http://www.lucent.com/press/0399/990303.nsa.html
Distributed Application Development With Inferno
Distributed Application Development with Inferno Across OSs & Architectures
http://www.lucent.com/inferno/
IBM TSpaces Intelligent Connectionware
http://www.almaden.ibm.com/cs/TSpaces/
Operating System Directions for the Next Millennium
http://research.microsoft.com/sn/Millennium/mgoals.html
Microsoft Releases Millennium (WinMe) Beta 2
http://content.techweb.com/wire/story/TWB19991125S0003
HP Embedded Software ChaiAppliance Plug and Play White Paper
http://www.hp.com/products1/embedded/infolibrary/whitepapers/chaiplug_play_whitepaper.pdf
HP ChaiServer Guide Overview
http://user.devnet.external.hp.com/site/chai/csguide/chaiserverguide/Overview.html
A Comparative Analysis of Internetworking Technologies for Net-Centric Computing
http://198.11.21.25/capstoneTest/Students/Papers/docs/3180.pdf
Self-Organizing Network (Virtual BUS) - Toward the Networking-Computation Collaboration World
http://www.onlab.ntt.co.jp/en/mn/msho/
HomePNA (for Home Phoneline Networking Alliance) network
http://www.homepna.org/news/industry_quotes.html
HomePNA 2.0 Networking Standard and Products
http://www.zdnet.com/products/stories/reviews/0,4161,2625930,00.html
Wireless PCMCIA Card
http://www.milestek.com/wireless_pcmcia.htm
OSEK/VDX Standard for In-Cars Embedded Systems
http://www-iiit.etec.uni-karlsruhe.de/~osek/
OSEK/VDX Operating System Specification V2.1
http://www-iiit.etec.uni-karlsruhe.de/~osek/mirror/os21r1.pdf
OSEK/VDX Communications V2.2.2
http://www-iiit.etec.uni-karlsruhe.de/~osek/mirror/com2-2-2.pdf
OIL (OSEK Implementation Language) V2.1
http://www-iiit.etec.uni-karlsruhe.de/~osek/mirror/oil21os.pdf
Mobility Support in Middleware for Virtual Home Environments
http://www.cs.arizona.edu/mmc/23%20Eikerling.pdf
Trends in Home Networking
http://www.elec.qmul.ac.uk/torrent/pubs/NGNi_home_networking.pdf
PVN: Parallel Virtual Machine
http://www.csm.ornl.gov/pvm/pvm_home.html
Array Message-Passing Standards: VPM and MPI
http://archive.ncsa.uiuc.edu/Pubs/UserGuides/Power/PCABook2_32.html
A Universal Communication Model for An Automotive System Integration Platform
http://www.sigda.org/Archives/ProceedingArchives/Date/Date2001/papers/2001/date01/pdffiles/02a_2.pdf
Networking Embedded Agents
http://www.computer.org/internet/ic1999/w1091abs.htm
The Cognitive Disappearance of the Computer: Intelligent Artefacts and Embedded Agents
http://cswww.essex.ac.uk/intelligent-uildings/publications/cognitive_disappearance_summary.pdf
Information Agents for Mobile and Embedded Devices
http://citeseer.nj.nec.com/460588.html
Thinking Small Using SNMP and Java agents can alleviate the problems of managing small, networked devices
http://www.devx.com/premier/mgznarch/javapro/2001/05may01/f_br0105/f_br0105-1.asp
Agents On the Web: Inside An Agent
http://www.computer.org/internet/ic2001/w1082abs.htm?SMSESSION=NO
Ihome: Intelligent Home Project
http://mas.cs.umass.edu/research/IHome/index.html
Agent-Oriented Software Engineering
http://dblp.uni-trier.de/db/conf/atal/atal1999.html#BussmannCDHW99
Autonomous Networked Tactical Sentries (ANTS)
http://www.cse.sc.edu/research/cit/projects/ants/ANTS.html
http://www.capsl.udel.edu/conferences/cases99/papers/paper22/paper22.htm
WINS - Wireless Integrated Network Sensors
http://www.janet.ucla.edu/WINS/
http://www.esscirc.org/esscirc98/Kaiser.htm
Low Power Wireless MEMS
http://www.janet.ucla.edu/WINS/mems_pi_jan00.htm
WINS: Low Power System On a Chip
http://citeseer.nj.nec.com/278712.html
WINS: Towards Low Cost and Robust Self-Organizing Security Networks
http://wins.rsc.rockwell.com/publications/spie3577-12.pdf
Sensor Network and Embedded Systems
http://www.isi.edu/~xuanc/links/sensornet.html
Medium Access Control (MAC)
http://www.erg.abdn.ac.uk/users/gorry/course/lan-pages/mac.html
Wireless LAN Medium Access Control (MAC) and Physical Layer (PHY) Specifications
http://standards.ieee.org/reading/ieee/updates/errata/802.11a-errata.pdf
What Is MEMS (Micro Electro Mechanical Systems) Technology ?
http://www.memsnet.org/mems/what-is.html
http://www.people.cornell.edu/pages/akt1/what.html
About MEMS
http://mems.sandia.gov/scripts/index.asp
Microsensors, MEMS and Smart Devices (Book) 2001
http://www.wileyeurope.com/cda/product/0,,047186109X,00.html
Best Manufacturing Practices for MEMS
http://www.bmpcoe.org/bestpractices/pdf/arlps.pdf
TI Digital Light Processing (DLP) Technology
http://www.dlp.com/dlp/resources/resources_results.asp?PR=34
TI宣布提前提供TABLE-TOP DLPTM器件组
http://www.ti.com.cn/news/2001/12/1226_02.asp
TI Digital Micromirror Device Technology
http://www.siliconstrategies.com/story/OEG20010305S0048
Digital Displays With Micromirror Devices
http://www.aip.org/tip/INPHFA/vol-3/iss-2/p9.pdf
Polysilicon Surface Micromachine Technology and Devices (Course)
http://www.spie.org/web/meetings/programs/mf00/courses/SC236.html
MEMS Technology Emerges
http://kroeker.net/published/mems_tech.htm
Planar Surface-Micromachined Pressure Sensor With a Sub-Surface, Embedded Reference Presuure Cavity
http://mems.sandia.gov/search/micromachine/docs/Mm96pres.pdf
A List of the Available Phar Lap Technical Articles and White Papers
http://www.hitex.demon.co.uk/x86/Phar%20Lap%20White%20Papers.html
Embedded and Small Internet Server Links
http://www.quasar.org/memes/intellimedcom/internetable-intelligence/thinserver/
Jini Technology Community Resources
http://www.jini.org/resources/
UPnP Forum
UPnP Resources
http://www.upnp.org/resources/default.asp
SNMP Links
http://www.snmplink.org/Others.html
Agents On the Web
http://www.kdel.info.eng.osaka-cu.ac.jp/~kitamura/projects/internet-agents.html
CMU MEMS Laboratory
http://www.ece.cmu.edu/~mems/
IDA MEMS Technology Transition
http://mems.ida.org/
NIST MEMS Project
http://mems.nist.gov/
MEMS Industry Group
http://www.memsindustrygroup.org/
MEMS Links
http://home.earthlink.net/~trimmerw/mems/Links_All.html
MEMS Resources
http://www.trimmer.net/
http://mems.cwru.edu/
MEMS Virtual Learning Cybercenter
http://www.people.cornell.edu/pages/akt1/memsmain.html
关键词: 挥泪 奉献 关键 技术网站 Embedded Se
有奖活动 | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! | |
【有奖活动】伙伴们:您的“需求”解决了吗? | |
抽奖了,抽奖了,金升阳医疗电源 |
打赏帖 | |
【换取手持数字示波器】+与同事对定时器输出相位可调PWM移相全桥控制分享被打赏50分 | |
【换取手持数字示波器】+LP-MSPM0L1306开发板试用体验+串口被打赏40分 | |
CC-RL编译器相关问题求助被打赏10分 | |
【换取手持数字示波器】+与同事对ESP-12开发调试经验分享被打赏50分 | |
【换取手持数字示波器】+同事tek示波器调试spi解析被打赏50分 | |
【换取手持数字示波器】+2.6寸墨水屏调试经验被打赏50分 | |
换取手持数字示波器+个人开关电源的设计经验被打赏50分 | |
【换取手持数字示波器】+【APT32F173测评】+URAT被打赏20分 | |
【换取手持数字示波器】CH32X035的定时器以及外部中断体验被打赏50分 | |
【换取手持数字示波器】CH32X035搭建开发环境(RISC-V)被打赏50分 |
