IO不能输入,已解决。
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; //PB1ÉèÖÃΪÊäÈë
GPIO_InitStructure.GPIO_Mode =GPIO_Mode_IN_FLOATING;
GPIO_Init(GPIOB, &GPIO_InitStructure);
/* Configure IO connected to D3,D4 *********************/
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11 | GPIO_Pin_12;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
while (1)
if(GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_1)==0) //Èç¹ûPA0 = 0
GPIO_ResetBits(GPIOB, GPIO_Pin_11); //D1ÁÁ
GPIO_SetBits(GPIOB, GPIO_Pin_12);
//for(i=0;i<100;i++)Delay(1000);Delay(1000);
else
GPIO_ResetBits(GPIOB, GPIO_Pin_12); //D1ÁÁ
GPIO_SetBits(GPIOB, GPIO_Pin_11);
关键词: STM 输入
将IO的输入设置改为上拉输入就可以了。
原因是我设置为浮空输入了,但我没有外部上拉.
void GPIO_Configuration(void)
GPIO_InitTypeDef GPIO_InitStructure; //定义了一个初始化的结构体变量,其中包括端口引脚,速度,模式,
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3 | GPIO_Pin_4 ;
//GPIO_Pin_None; //无管脚被选中
//GPIO_Pin_0 - GPIO_Pin_15;//选中管脚 0-15
//GPIO_Pin_All; //选中全部管脚
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//推挽输出
//GPIO_Mode_AIN; //模拟输入
//GPIO_Mode_IN_FLOATING ;//浮空输入
//GPIO_Mode_IPD; //下拉输入
//GPIO_Mode_IPU; //上拉输入
//GPIO_Mode_Out_OD; //开漏输出
//GPIO_Mode_Out_PP; //推挽输出
//GPIO_Mode_AF_OD; //复用开漏输出
//GPIO_Mode_AF_PP; //复用推挽输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
//GPIO_Speed_10MHz; //最高输出速率 10MHz
//GPIO_Speed_2MHz; //最高输出速率 2 MHz
//GPIO_Speed_50MHz; //最高输出速率 50MHz
GPIO_Init(GPIOD, &GPIO_InitStructure);
有奖活动 | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! | |
【有奖活动】伙伴们:您的“需求”解决了吗? |
打赏帖 | |
老胖子聊电路--分析一个反馈电路被打赏50分 | |
