Y5V贴片电容容量范围及规格表
Y5V贴片电容简述
Y5V贴片电容属于EIA规定的Class 2类材料的电容。它的电容量受温度、电压、时间变化影响大。
Y5V贴片电容特性
具有较差的电容量稳定性,在-25℃~85℃工作温度范围内,温度特性为+30%,-80%。
层叠独石结构,具有高可靠性。
优良的焊接性和和耐焊性,适用于回流炉和波峰焊。
应用于温度变化小的退耦、隔直等电路中。
厚度与符号对应表 符号 | A | C | E | G | J | K | M | N | P | Q | X | Y | Z | 最大厚度 毫米(英寸) | 0.33 (0.013) | 0.56 (0.022) | 0.71 (0.028) | 0.86 (0.034) | 0.94 (0.037) | 1.02 (0.040) | 1.27 (0.050) | 1.40 (0.055) | 1.52 (0.060) | 1.78 (0.070) | 2.29 (0.090) | 2.54 (0.100) | 2.79 (0.110) |
0201~1210 Y5V贴片电容选型表封装尺寸 | 0201 | 0402 | 0603 | 0805 | 1206 | 1210 | 工作电压 | 6.3 | 10 | 6.3 | 10 | 16 | 25 | 50 | 6.3 | 10 | 16 | 25 | 50 | 6.3 | 10 | 16 | 25 | 50 | 6.3 | 10 | 16 | 25 | 50 | 6.3 | 10 | 16 | 25 | 50 | 电容量 (pF) | 820 1000 2200 4700 | | A A A | | | | |
C | | | | | | | | | | | | | | | | | | | | | 电容量 (uF) | 0.010 0.022 0.047 | A A A | A
| | | C C | C C
| C
G | G G G | | | | | | | | | | | | | | | | 0.10 0.15 0.22 | | | | C C C | C
| | | | G |
G | G
G | | | | | J
K | K
N | | | | | | | | | | | 0.47 1.0 2.2 | | | C C
G | G G G | G G
| | | | N N | K N N | N N
M |
M |
M | M
| | | | | N
| 4.7 10.0 22.0 47.0 | | | | | | | | | | | | | N
| N N
| | | | M Q
| M Q Q
| M Q
X | X X
| Q
| N Q
| | 工作电压 | 6.3 | 10 | 6.3 | 10 | 16 | 25 | 50 | 6.3 | 10 | 16 | 25 | 50 | 6.3 | 10 | 16 | 25 | 50 | 6.3 | 10 | 16 | 25 | 50 | 6.3 | 10 | 16 | 25 | 50 | 封装尺寸 | 0201 | 0402 | 0603 | 0805 | 1206 | 1210 | |
