电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » X7R贴片电容容量范围及规格表
X7R贴片电容容量范围及规格表
2014-06-12 10:37:21     打赏
X7R贴片电容简述
X7R贴片电容属于EIA规定的Class 2类材料的电容。它的容量相对稳定。
X7R贴片电容特性
具有较高的电容量稳定性,在-55℃~125℃工作温度范围内,温度特性为±15%。
层叠独石结构,具有高可靠性。
优良的焊接性和和耐焊性,适用于回流炉和波峰焊。
应用于隔直、耦合、旁路、鉴频等电路中。
X7R贴片电容容量范围
厚度与符号对应表
符号ACEGJKMNPQXYZ
最大厚度
毫米(英寸)
0.33
(0.013)
0.56
(0.022)
0.71
(0.028)
0.86
(0.034)
0.94
(0.037)
1.02
(0.040)
1.27
(0.050)
1.40
(0.055)
1.52
(0.060)
1.78
(0.070)
2.29
(0.090)
2.54
(0.100)
2.79
(0.110)
0201~1206 X7R贴片电容选型表
封装尺寸 02010402060308051206
工作电压 16162550101625501001016255010020010162550100200500
电容量
(pF)
100
150
220
A
A
A
C
330
470
680
A
A
A
C
C
C
G
G
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
K
K
K
1000
1500
2200
A
C
C
C
G
G
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
K
M
M
3300
4700
6800
C
C
C
C
C
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
M
M
P
电容量
(uF)
0.010
0.015
0.022
C
C
C
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
M
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
M
M
P
0.033
0.047
0.068
G
G
G
G
J
J
J
J
J
J
J
J
J
J
J
J
M
M
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
M
M
P
0.10
0.15
0.22
G
G
G
G
G
J
J
J
J
J
J
J
J
M
J
J
J
J
J
J
J
J
J
J
J
J
J
M
0.33
0.47
0.68
M
N
N
M
M
J
M
M
J
M
M
M
M
M
1.0
1.5
2.2
N
M
P
Q
M
Q
1210~2225 X7R贴片电容选型表
封装尺寸 12101812182522202225
工作电压 1016255010020050050100200500501006.35010020050100
电容量
(pF)
1000
1500
2200
J
J
J
J
J
J
J
J
J
J
J
J
M
M
3300
4700
6800
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
M
M
M
电容量
(uF)
0.010
0.015
0.022
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
M
P
Q
K
K
K
K
K
K
K
K
K
K
P
P
M
M
M
M
M
M
X
X
X
X
X
X
X
X
X
X
X
X
M
M
M
P
P
P
0.033
0.047
0.068
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
J
M
K
K
K
K
K
K
K
K
K
X
Z
M
M
M
M
M
M
X
X
X
X
X
X
X
X
X
X
X
X
M
M
M
P
P
P
0.10
0.15
0.22
J
J
J
J
J
J
J
J
J
J
J
J
J
M
P
M
K
K
K
K
K
K
K
P
P
M
M
M
M
M
M
X
X
X
X
X
X
X
X
X
X
X
M
M
M
P
P
P
0.33
0.47
0.68
J
M
M
J
M
M
J
M
P
J
M
X
Z
Z
Z
K
K
M
M
P
Q
M
M
M
M
M
X
X
X
X
X
X
X
X
X
M
M
M
P
P
P
1.0
1.5
2.2
N
N
N
N
P
X
X
Z
M
Z
X
M
M
Z
M
M
M
P
X
3.3
4.7
10
Q
Z
Z
关键词: X7R     贴片电容     (
