OpenVINOTM,给你看得见的未来!>>
电子产品世界 » 论坛首页 » 论坛服务 » 论坛公告 » Macraigor.Systems.Flash.Programmer.v2.2.
Macraigor.Systems.Flash.Programmer.v2.2.3-Lz0
2004-03-23 00:22:00    评分
| "LZ0 is 100% vagina free and loving it!" |
苣 哪 哪哪?哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪哪? 哪 能
圮.赏屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯突.苒
|郾?Macraigor.Systems.Flash.Programmer.v2.2.3-Lz0 罕踻
鄄掏屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯屯凸槽
圹? Cracked By : s! Release Date : 14.03.2004 痕?
圹? Packed By : Team Lz0 Num. Disks : xx/07 痕?
圹酆 Supplied By : Team Lz0 OSYS : WinALL 痕圹
圹? Protection : Dongle NFO Time : 16:01:48 痕?
酆 Publisher : Macraigor NFO Date : 14.03.2004 痕
酆 Rating : 8/10 [########--] Release type : Application 痕
酆 URL : www.macraigor.com
|? [ ] Keyfile [ ] Patch [X] Cracked .EXE 簗
苘? [ ] Keygen [ ] Loader [ ] Serial 很?
圻屯屯屯屯屯屯屯屯屯捅屯屯屯屯屯屯屯屯屯屯屯屯屯屯蓖屯屯屯屯屯屯屯屯屯咣
哌咣哌哌哌哌哌哌哌哌圹槽 RELEASE INFORMATION! 鄄圹哌哌哌哌哌哌哌哌圻哌
咣 圻 This application lets you program your Flash EEPROM devices
via the On-Chip Debug connector (BDM or JTAG) on your
target system using a Macraigor hardware device. Download
the demo version which will allow you to test the ERASE,
FILL, BLANK CHECK, CHECKSUM, UPLOAD flash content, and VIEW
MEMORY functions of the software with your flash devices.
Purchasing this license will turn the DEMO into a full
working application that will allow you to program and
verify your flash device using Motorola(.s19), Intel(.hex),
and ELF(.elf) format files in addition to the functionality
provided in the demo. The demo version will provide you
with a COMPUTER ID which you MUST have when you purchase
this license.
LINUX demo version is here.
The Flash Programmer is supported under Windows 98/ME, NT,
2000, and XP operating systems, as well as under Red Hat
Linux versions 7.2 and 9.0. The softare may work with other
operating systems and versions but has not been verified
against such and is not guaranteed to work.
关键词: Macraigor.Systems.Flash.P
