电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » 18号的作业
共22条 1/3 1 2 3 跳转至
18号的作业
2014-10-21 23:05:11     打赏
2014-10-22 23:45:57     打赏
2014-10-23 10:57:44     打赏
#include "stm32f10x.h"
#include "stm32_eval.h"
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void) //RCC时钟配置函数
  RCC_DeInit(); //将RCC寄存器重新设置为默认值
  RCC_HSICmd(ENABLE);   //打开HSI
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);//等待HSI工作
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);  //设置系统时钟函数
  RCC_HSEConfig(RCC_HSE_OFF);  //HSE晶振关闭
  RCC_LSEConfig(RCC_LSE_OFF);  //LSh晶振关闭
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);   //打开PLL
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);  //等待PLL工作
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);  //ADC???RCC_PCLK2/4
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);   //关闭蜂鸣器
	RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|
RCC_APB2Periph_AFIO, ENABLE);
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;  //GPIO频率
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //GPIO输出
  GPIO_Init(GPIOD, &GPIO_InitStructure);
	GPIO_ResetBits(GPIOD,GPIO_Pin_2);  //重置GPIO
void GPIO_INIT()
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);  //使能APB2外
设
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;  //设
置GPIO管脚
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_4|GPIO_Pin_5|
GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//GPIO输出
  GPIO_Init(GPIOA, &GPIO_InitStructure);   //初始化PA
    GPIO_Init(GPIOC, &GPIO_InitStructure);
void delay_us(u32 n) //延时函数32位,延时1us
	u8 j;
	while(n--)
	for(j=0;j<10;j++);
void  delay_ms(u32 n) //延时1ms
	while(n--)
	delay_us(1000);
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)  //主函数开始
	GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|
GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7); //LED灯全灭
	RCC_Configuration(); //调用时钟RCC函数
 GPIO_INIT(); //调用GPiO函数
	while(1){
	GPIO_ResetBits(GPIOC,GPIO_Pin_0); //灯亮
		delay_ms(50);
		GPIO_SetBits(GPIOC,GPIO_Pin_0); //灯灭
		delay_ms(50);
    GPIO_ResetBits(GPIOC,GPIO_Pin_1); //灯亮
		delay_ms(50);
    GPIO_SetBits(GPIOC,GPIO_Pin_1); //灯灭
		delay_ms(50);
    GPIO_ResetBits(GPIOC,GPIO_Pin_2); //灯亮
		delay_ms(50);
    GPIO_SetBits(GPIOC,GPIO_Pin_2); //灯灭
		delay_ms(50);
    GPIO_ResetBits(GPIOC,GPIO_Pin_3); //灯亮
		delay_ms(50);
    GPIO_SetBits(GPIOC,GPIO_Pin_3); //灯灭
		delay_ms(50);
    GPIO_ResetBits(GPIOC,GPIO_Pin_4); //灯亮
		delay_ms(50);
    GPIO_SetBits(GPIOC,GPIO_Pin_4); //灯灭
		delay_ms(50);
    GPIO_ResetBits(GPIOC,GPIO_Pin_5); //灯亮
		delay_ms(50);
    GPIO_SetBits(GPIOC,GPIO_Pin_5); //灯灭
		delay_ms(50);
    GPIO_ResetBits(GPIOC,GPIO_Pin_6); //灯亮
		delay_ms(50);
    GPIO_SetBits(GPIOC,GPIO_Pin_6); //灯灭
		delay_ms(50);
    GPIO_ResetBits(GPIOC,GPIO_Pin_7); //灯亮
		delay_ms(50);
    GPIO_SetBits(GPIOC,GPIO_Pin_7); // 灯灭
		delay_ms(50);
	//RGB亮灭
		GPIO_ResetBits(GPIOA,GPIO_Pin_2); //红灯亮
    delay_ms(200);
    GPIO_SetBits(GPIOA,GPIO_Pin_2); //红灯灭
		GPIO_ResetBits(GPIOA,GPIO_Pin_3); //绿灯亮
    delay_ms(200);
    GPIO_SetBits(GPIOA,GPIO_Pin_3); //绿灯灭
2014-10-23 11:59:48     打赏
2014-10-30 23:31:19     打赏
  * @file    GPIO/IOToggle/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body.
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
void GPIO()
    RCC_Configuration();    //GPIO的初始化
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
    GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
void delay_us(u32 n)   //延时微秒
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
void  delay_ms(u32 n)    //延时毫秒
    while(n--)
    delay_us(1000);
int main (void)
    char i,j,num;   //定义变量
          GPIO();
        while(1){
            if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10))    //s3键按下
           {delay_ms(80);    //延时,防抖
           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_10)){j++;}}   //s3自加1
        if(j%2==0){      // 如果j是偶数
             if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))      //s1键按下
           {delay_ms(80);
           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8)){i++;}    //s1键按下i自加1
							if(i>30){i=0;}   //30个循环
        GPIO_ResetBits(GPIOB,GPIO_Pin_1);    //关闭PB1
        GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);  //关闭数码管管脚
        switch(i)
         case 0 :
             GPIO_SetBits(GPIOB,GPIO_Pin_1);
             GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
         break;
         case 1 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
         break;
            case 2 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
            break;
            case 3 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
            break;
            case 4 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);
            break;
            case 5 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);
            break;
            case 6 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
            break;
            case 7 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
            break;
            case 8 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
            break;
            case 9 :
             GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
            break;
            case 10 :
             delay_ms(1);
             GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
                  GPIO_SetBits(GPIOB,GPIO_Pin_15);
                  delay_ms(1);
                  GPIO_ResetBits(GPIOB,GPIO_Pin_15);
                  GPIO_SetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);
            break;
            case 11 :
             delay_ms(1);
                  delay_ms(1);
            break;
            case 12 :
             delay_ms(1);
             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);
                  delay_ms(1);
            break;
            case 13 :
             delay_ms(1);
             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
                  delay_ms(1);
            break;
            case 14 :
             delay_ms(1);
             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);
                  delay_ms(1);
            break;
            case 15 :
             delay_ms(80);
             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);
                  delay_ms(100);
            break;
            case 16 :
             delay_ms(80);
             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
                  delay_ms(100);
            break;
            case 17 :
             delay_ms(80);
            GPIO_SetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
                  delay_ms(100);
            break;
            case 18 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 19 :
             delay_ms(80);
             GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);
                  delay_ms(100);
            break;
            case 20 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 21 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 22 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 23 :
             delay_ms(80);
                  delay_ms(100);
						break;
            case 24 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 25 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 26 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 27 :
             GPIO_ResetBits (GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
             delay_ms(80);
            GPIO_SetBits (GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);
                  delay_ms(100);
            break;
            case 28 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 29 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 30 :
             delay_ms(80);
                  delay_ms(100);
            break;
                else{
                              if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9))     //s2键按下
           {delay_ms(80);
           if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_9)){num++;}}
           if(num>30){num=0;}
        switch(num)
         case 0 :
         break;
         case 1 :
         break;
            case 2 :
            break;
            case 3 :
            break;
            case 4 :
            break;
            case 5 :
            break;
            case 6 :
            break;
            case 7 :
            break;
            case 8 :
            break;
            case 9 :
            break;
            case 10 :
             delay_ms(1);
                  delay_ms(1);
            break;
            case 11 :
             delay_ms(1);
                  delay_ms(1);
            break;
            case 12 :
             delay_ms(1);
                  delay_ms(1);
            break;
            case 13 :
             delay_ms(1);
                  delay_ms(1);
            break;
            case 14 :
             delay_ms(1);
                  delay_ms(1);
            break;
            case 15 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 16 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 17 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 18 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 19 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 20 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 21 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 22 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 23 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 24 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 25 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 26 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 27 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 28 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 29 :
             delay_ms(80);
                  delay_ms(100);
            break;
            case 30 :
             delay_ms(80);
                  delay_ms(100);
            break;
2014-11-14 11:17:16     打赏
#include    "stdio.h"
#include "math.h"
#define buff_size  16;
char rx_buff[], rx_buff_count=0;
USART_InitTypeDef  USART_InitStructure;
NVIC_InitTypeDef  NVIC_InitStructure;
USART_ClockInitTypeDef  USART_ClockInitStructure;
    RCC_DeInit();
    RCC_HSICmd(ENABLE);
    RCC_PLLCmd(ENABLE);
    GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
    GPIO_ResetBits(GPIOD,GPIO_Pin_2);//关闭蜂鸣器
void GPIO_INIT()
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);//使能PC时钟
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;//PC0-PC7
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;//推挽输出
    GPIO_Init(GPIOC, &GPIO_InitStructure);//初始化PC
void USART_int(long BaudRate)
     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);//使能PA USART1
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;//TX位于PA9
   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //推挽输出
   GPIO_Init(GPIOA, &GPIO_InitStructure);//TX初始化 PA9
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;//RX位于PA10
   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//悬空输入
   GPIO_Init(GPIOA, &GPIO_InitStructure);//RX初始化 PA10
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
    USART_InitStructure.USART_BaudRate = BaudRate;//传输速率
    USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长8比特
    USART_InitStructure.USART_StopBits = USART_StopBits_1;//停止位1
    USART_InitStructure.USART_Parity = USART_Parity_No;//
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//流控位none
    USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//接收和发送模式
    USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
    USART_ClockInit(USART1, &USART_ClockInitStructure);//初始化USART1时钟
    USART_Init(USART1, &USART_InitStructure);//初始化USART1
    USART_Cmd(USART1, ENABLE);
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  /* Configure four bit for preemption priority */
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_4);//优先级
  /* Enable the USART1 Interrupt */
    NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn; //选择USART1中断通道
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 15;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);//初始化中断
/*delay_us*/
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
/*delay_ms*/
    while(n--)
    delay_us(1000);
void USART_SendStr(char *str)//发送字符串
   while((*str)!='\0')//到字符串的末尾才停止发送数据
        USART_SendData(USART1,*str++);
        while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET);
unsigned int translate(char *S,char j)//将字符串组成的数字转换成整型数据
    unsigned int a[4],sum=0;
    char i;
    for(i=0;i<j;i++)
        a[i]=S[5+j-1-i]-48;//将字符转成整型数据
        sum+=a[i]*pow(10,i);//按照每一位的权值相乘再相加,还原data=n的本来面貌
    return sum;//sum保存目标整型数据
void func(char *S,char LEN)
    char count;//
    unsigned int sum,i,j,k;
    if((LEN!=6)&(LEN!=7)&(LEN!=8)&(LEN!=9))//data=1~999
    {USART_SendStr("\r\n Erro input!!!\r\n");}//如果输入格式错误,发送提示
    else
        count=LEN-5;//从“=”后面开始是目标数据
        sum = translate(S,count);//count记录“=”后有多少位,传递到translate中
        GPIO_SetBits(GPIOC,0x000000ff);//all LED off
        for(k=0;k<3;k++)//循环点亮D8-D1 3次
            i=0x00000100;
            for(j=1;j<=8;j++)//LED D8-D1
                i>>=1;
                GPIO_ResetBits(GPIOC,i);    // on PC7-PC0 D8-D1
                delay_ms(50);
                GPIO_SetBits(GPIOC,i);
                delay_ms(sum);//每两盏灯发光,间隔时间sum
void input_ASK()
    char j;
    func(rx_buff,rx_buff_count);
    rx_buff_count=0;
    for (j=0;j<rx_buff_count;j++)
    {rx_buff[j]='\0';}//判断读入信息是否结束,如果结束则准备下一次读入
    USART_SendStr("\n>");
int main(void)
    GPIO_INIT();
    USART_int(9600);
    GPIO_ResetBits(GPIOC,0x000000ff);//led全亮,提示程序开始
    delay_ms(200);
    GPIO_SetBits(GPIOC,0x000000ff);//led全灭
    USART_SendStr("SyStem booting......\r\n");//
    USART_SendStr("\n>");//
    while(1)
void USART1_IRQHandler(void)
  while(USART_GetFlagStatus(USART1, USART_FLAG_RXNE) == RESET)
    if(USART_ReceiveData(USART1)==0x0d)//如果输入完毕,按下了回车
    {input_ASK();}
    else
        USART_SendData(USART1,USART_ReceiveData(USART1));
        rx_buff[rx_buff_count]= USART_ReceiveData(USART1);
        rx_buff_count++;
    USART_ClearFlag(USART1, USART_FLAG_RXNE);
2014-11-27 22:09:40     打赏
2014-11-27 23:12:18     打赏
  * @file    EXTI/EXTI_Config/main.c
  * @version V3.5.0
  * @attention
#include <stdio.h>
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup EXTI_Config
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
EXTI_InitTypeDef   EXTI_InitStructure;
/* Private function prototypes -----------------------------------------------*/
void EXTIkeyS1_Config(void);
void EXTIkeyS2_Config(void);
void EXTIkeyS3_Config(void);
void EXTIkeyS4_Config(void);
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
    GPIO_ResetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
    /* PA10 USART1_Rx  */
        - One Stop Bit
        - No parity
  USART_InitStructure.USART_BaudRate = BaudRate;//??????
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
  USART_InitStructure.USART_Parity = USART_Parity_No;//????
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
/* Private functions ---------------------------------------------------------*/
  * @param  None
  * @retval None
int main(void)
{RCC_Configuration();
  /* Configure PA.00 in interrupt mode */
  EXTIkeyS1_Config();
  /* Configure PB.09 or PG.08 in interrupt mode */
  EXTIkeyS2_Config();
    EXTIkeyS3_Config();
    EXTIkeyS4_Config();
    USART_int(115200);
    printf("Config done,waiting for interrupt......\r\n");
  while (1)
  * @brief  Configure PA.00 in interrupt mode
  * @param  None
  * @retval None
  /* Enable GPIOA clock */
  /* Configure PA.00 pin as input floating */
  /* Enable AFIO clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  /* Connect EXTI0 Line to PA.00 pin */
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource8);
  /* Configure EXTI0 line */
  EXTI_InitStructure.EXTI_Line = EXTI_Line8;
  EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Falling;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  /* Enable and set EXTI0 Interrupt to the lowest priority */
  NVIC_InitStructure.NVIC_IRQChannel = EXTI9_5_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
  * @brief  Configure PB.09 or PG.08 in interrupt mode
  * @param  None
  * @retval None
  /* Enable GPIOB clock */
  /* Configure PB.09 pin as input floating */
  /* Connect EXTI9 Line to PB.09 pin */
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource9);
  /* Configure EXTI9 line */
  EXTI_InitStructure.EXTI_Line = EXTI_Line9;
  /* Enable and set EXTI9_5 Interrupt to the lowest priority */
  /* Configure PB.10 pin as input floating */
  /* Connect EXTI10 Line to PB.09 pin */
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource10);
  /* Configure EXTI10 line */
  EXTI_InitStructure.EXTI_Line = EXTI_Line10;
  /* Enable and set EXTI15_10 Interrupt to the lowest priority */
  NVIC_InitStructure.NVIC_IRQChannel = EXTI15_10_IRQn;
  /* Configure PB.11 pin as input floating */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  /* Connect EXTI11 Line to PB.09 pin */
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOC, GPIO_PinSource11);
  /* Configure EXTI11 line */
  EXTI_InitStructure.EXTI_Line = EXTI_Line11;
/*            STM32F10x Peripherals Interrupt Handlers                        */
  * @brief  This function handles External lines 9 to 5 interrupt request.
  * @param  None
  * @retval None
void EXTI9_5_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line8) != RESET)
    /* Toggle LED2 */
     GPIO_SetBits(GPIOC,GPIO_Pin_3|GPIO_Pin_7);
printf("S1 interrupt ......\r\n");
    /* Clear the  EXTI line 9 pending bit */
    EXTI_ClearITPendingBit(EXTI_Line8);
    if(EXTI_GetITStatus(EXTI_Line9) != RESET)
    /* Toggle LED1 */
     GPIO_SetBits(GPIOC,GPIO_Pin_2|GPIO_Pin_6);
printf("S2 interrupt ......\r\n");
    /* Clear the  EXTI line 0 pending bit */
    EXTI_ClearITPendingBit(EXTI_Line9);
void EXTI15_10_IRQHandler(void)
  if(EXTI_GetITStatus(EXTI_Line10) != RESET)
    /* Toggle LED2 */
     GPIO_ResetBits(GPIOC,GPIO_Pin_1|GPIO_Pin_5);
printf("S3 interrupt ......\r\n");
    /* Clear the  EXTI line 10 pending bit */
    EXTI_ClearITPendingBit(EXTI_Line10);
    if(EXTI_GetITStatus(EXTI_Line11) != RESET)
    /* Toggle LED1 */
     GPIO_ResetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_4);
printf("S4 interrupt ......\r\n");
    /* Clear the  EXTI line 11 pending bit */
    EXTI_ClearITPendingBit(EXTI_Line11);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
  #define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
  #define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
  * @brief  Retargets the C library printf function to the USART.
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
2014-11-27 23:31:37     打赏
  * @version V3.5.0
  * @attention
#include <stdio.h>
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
long flag,temp,num;
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
	SystemInit();
	GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
	  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
		RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
			RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM7, ENABLE);
        - One Stop Bit
        - No parity
void NVIC_Configuration(void)
  /* Enable the TIM2 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
	  NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;
	  NVIC_InitStructure.NVIC_IRQChannel = TIM7_IRQn;
	/* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 24000;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
	/*NVIC_InitStructure.NVIC_IRQChannel =TIM8_CC_IRQn;
	  NVIC_Init(&NVIC_InitStructure);*/
  * @param  None
  * @retval None
	u8 j;
	while(n--)
	for(j=0;j<10;j++);
	while(n--)
	delay_us(1000);
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System Clocks Configuration */
NVIC_Configuration();
USART_int(115200);
	printf(" config done...\r\n");
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE );
	 TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure);
  TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE );
	 TIM_TimeBaseInit(TIM7, &TIM_TimeBaseStructure);
  TIM_ITConfig(TIM7,TIM_IT_Update,ENABLE );
  /* TIM2 enable counter */
  TIM_Cmd(TIM2, ENABLE);
	 TIM_Cmd(TIM3, ENABLE);
	 	 TIM_Cmd(TIM7, ENABLE);
  while (1){
		if(flag == 2000)
		{printf("TIM2 interrupt......\r\n");
 GPIO_ResetBits(GPIOC,GPIO_Pin_1|GPIO_Pin_0);
		delay_ms(150);
		  flag = 0;
		if(temp == 3000)
		{printf("TIM3 interrupt......\r\n");
			GPIO_ResetBits(GPIOC,GPIO_Pin_6|GPIO_Pin_7);
		delay_ms(150);
		 temp = 0;
void TIM2_IRQHandler(void) //TIM3 ??
if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET) //?? TIM3 ????????
TIM_ClearITPendingBit(TIM2, TIM_IT_Update ); //?? TIM3 ??????
	flag++;
void TIM3_IRQHandler(void) //TIM3 ??
if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET) //?? TIM3 ????????
TIM_ClearITPendingBit(TIM3, TIM_IT_Update ); //?? TIM3 ??????
	temp++;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
#else
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
/******************* (C) COPYRIGHT 2011 STMicroelectronics *****END OF FILE****/
2014-12-11 21:50:08     打赏
  * @version V3.5.0
  * @attention
#include <stdio.h>
#define VREF 3.3
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
    SystemInit();
        - One Stop Bit
        - No parity
void PWM_Config()
{uint16_t PrescalerValue = 0;
    /* TIM2 clock enable */
  /* GPIOA  enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO  , ENABLE);
      /* Compute the prescaler value */
  PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
  TIM_TimeBaseStructure.TIM_Period = 0x07FF;
  TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  /* PWM1 Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 0xFFFF;
  TIM_OC2Init(TIM2, &TIM_OCInitStructure);
    /* PWM1 Mode configuration: Channel3 */
  TIM_OC3Init(TIM2, &TIM_OCInitStructure);
    /* PWM1 Mode configuration: Channel4 */
  TIM_OC4Init(TIM2, &TIM_OCInitStructure);
  TIM_ARRPreloadConfig(TIM2, ENABLE);
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
    while(n--)
    delay_us(1000);
void PWM_TEST()
{ unsigned int temp0,temp1,temp2,i;
    printf("PWM-RGB TEST......\r\n");
    while(1)
        for(i=1;i<9;i++)
      TIM_SetCompare2(TIM2, temp0);
        TIM_SetCompare3(TIM2, temp1);
        TIM_SetCompare4(TIM2, temp2);
     if(i==1)
         { temp0=400,temp1=100,temp2=2047;
             printf("PWM-RGB ...11...\r\n");
             delay_ms(500);
     if(i==2)
         { temp0=2047,temp1=600,temp2=100;
             printf("PWM-RGB ...22...\r\n");
             delay_ms(500);
     if(i==3)
         { temp0=1200,temp1=600,temp2=2047;
             printf("PWM-RGB ...33...\r\n");
             delay_ms(500);
     if(i==4)
         { temp0=300,temp1=2047,temp2=500;
             printf("PWM-RGB ...44...\r\n");
             delay_ms(500);
     if(i==5)
         { temp0=1400,temp1=100,temp2=380;
             printf("PWM-RGB ...55...\r\n");
             delay_ms(500);
     if(i==6)
         { temp0=750,temp1=240,temp2=990;
             printf("PWM-RGB ...66...\r\n");
             delay_ms(500);
     if(i==7)
         { temp0=1680,temp1=1800,temp2=300;
             printf("PWM-RGB ...77...\r\n");
             delay_ms(500);
    /*while(1)
    if (temp0>=2047)
        delay_ms(2000);
        temp0=0;
        break;
    else {temp0++;delay_us(1000);}
        while(1)
    if (temp1>=2047)
        delay_ms(2000);
        temp1=0;
        break;
    else {temp1++;delay_us(1000);}
        while(1)
    if (temp2>=2047)
        delay_ms(2000);
        temp2=0;
        break;
    else {temp2++;delay_us(1000);}
  * @param  None
  * @retval None
int main(void)
USART_int(115200);
    PWM_Config();
    delay_ms(1000);
    while(1)
        PWM_TEST();
  * @retval None
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
#else
  * @param  None
  * @retval None
PUTCHAR_PROTOTYPE
  return ch;
  * @retval None
  /* Infinite loop */
  while (1)
#endif
共22条 1/3 1 2 3 跳转至
