电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » SINLINX-H3启航ARMBIAN
SINLINX-H3启航ARMBIAN
2019-04-29 22:06:19     打赏
    千找万找终于找到了一个USB转串口的小工具~~~~
    安卓的限制实在太多了,查询了小半天的armbian系统,觉得应该也是极好的。晚上吃饱后,找到了串口工具,参考芯灵思给的镜像直接烧录armbian系统。
Password:
You are required to change your password immediately (root enforced)
Changing password for root.
(current) UNIX password:
Enter new UNIX password:
Retype new UNIX password:
Linux sinlinx 4.14.53-sunxi #30 SMP Sat Jul 7 00:07:52 PDT 2018 armv7l
 ____ ___ _   _ _     ___ _   ___  __  ____ ___ _   _       _   _ _____
/ ___|_ _| \ | | |   |_ _| \ | \ \/ / / ___|_ _| \ | |     | | | |___ /
\___ \| ||  \| | |    | ||  \| |\  /  \___ \| ||  \| |_____| |_| | |_ \
 ___) | || |\  | |___ | || |\  |/  \   ___) | || |\  |_____|  _  |___) |
|____/___|_| \_|_____|___|_| \_/_/\_\ |____/___|_| \_|     |_| |_|____/
Welcome to ARMBIAN 5.46 user-built Debian GNU/Linux 8 (jessie) 4.14.53-sunxi
System load:   1.39 0.85 0.37      Up time:       3 min
Memory usage:  5 % of 1000MB     IP:
CPU temp:      35°C
Usage of /:    7% of 15G
New to Armbian? Check the documentation first: https://docs.armbian.com
Thank you for choosing Armbian! Support: www.armbian.com
Creating a new user account. Press <Ctrl-C> to abort
Please provide a username (eg. your forename): jobs
Trying to add user jobs
Adding user `jobs' ...
Adding new group `jobs' (1000) ...
Adding new user `jobs' (1000) with group `jobs' ...
Creating home directory `/home/jobs' ...
Copying files from `/etc/skel' ...
passwd: password updated successfully
Changing the user information for jobs
Enter the new value, or press ENTER for the default
    Full Name []: jobs zheng
    Room Number []: 906
    Work Phone []: 01088886666
    Home Phone []: 01088668866
    Other []:
Is the information correct? [Y/n] y
Dear jobs zheng, your account jobs has been created and is sudo enabled.
Please use this account for your daily work from now on.
root@sinlinx:~#
    烧录过程还是非常简单的——主要按照官方的参考手册执行。
    接下来,将TF卡的镜像烧录进入eMMC,之后就可以轻松畅游Armbian了
关键词: SINLINX-H3     ARMBIAN
