电子产品世界 » 论坛首页 » 综合技术 » 基础知识 » SALI-IMX6Q的uboot启动时默认选择LCD屏幕显示
2019-11-01 14:44:46     打赏
在uboot启动时默认选择LCD屏幕显示这个问题我一直在想如何去实现,在经过不断地实验过后,我找到了解决办法,我是以电鱼电子公司SALI-IMX6Q开发板为例下面就分享给有需要的朋友们吧!
修改/uboot/board/freescale/mx6sabresd/mx6sabresd.c文件,如图所示:
修改如下部分:
struct display_info_t const displays[] = {{
       .bus = -1,
       .addr      = 0,
       .pixfmt    = IPU_PIX_FMT_RGB24,
       .detect    = NULL,
       .enable   = enable_lvds,
       .mode     = {
              .name           = "Hannstar-XGA",
              .refresh        = 60,
              .xres           = 1920,
              .yres           = 1080,
              .pixclock       = 6734,
              .left_margin    = 90,
              .right_margin   = 50,
              .upper_margin   = 30,
              .lower_margin   = 6,
              .hsync_len      = 24,
              .vsync_len      = 3,
              .sync           = FB_SYNC_EXT,
              .vmode          = FB_VMODE_NONINTERLACED
       .bus = -1,
       .addr      = 0,
       .detect    = NULL,
       .enable   = do_enable_hdmi,
       .mode     = {
              .name           = "HDMI",
              .refresh        = 60,
              .xres           = 640,
              .yres           = 480,
              .pixclock       = 39721,
              .left_margin    = 48,
              .right_margin   = 16,
              .upper_margin   = 33,
              .lower_margin   = 10,
              .hsync_len      = 96,
              .vsync_len      = 2,
              .sync           = 0,
       .bus = 0,
       .addr      = 0,
       .detect    = NULL,
       .enable   = enable_rgb,
       .mode     = {
              .name           = "SEIKO-WVGA",
              .refresh        = 60,
              .xres           = 800,
              .yres           = 480,
              .pixclock       = 29850,
              .left_margin    = 89,
              .right_margin   = 164,
              .upper_margin   = 23,
              .lower_margin   = 10,
              .hsync_len      = 10,
              .vsync_len      = 10,
              .sync           = 0,
size_t display_count = ARRAY_SIZE(displays);
修改完成后如下图所示:
       .bus = 0,
       .addr      = 0,
       .detect    = NULL,
       .mode     = {
              .name           = "CLAA-WVGA",
              .refresh        = 57,
              .xres           = 800,
              .yres           = 480,
              .pixclock       = 37037,
              .left_margin    = 40,
              .right_margin   = 60,
              .upper_margin   = 10,
              .lower_margin   = 10,
              .hsync_len      = 20,
              .vsync_len      = 10,
              .sync           = 0,
       .bus = -1,
       .addr      = 0,
       .pixfmt    = IPU_PIX_FMT_RGB666,
       .detect    = NULL,
       .mode     = {
              .refresh        = 60,
              .xres           = 1024,
              .yres           = 768,
              .pixclock       = 15385,
              .left_margin    = 220,
              .right_margin   = 40,
              .upper_margin   = 21,
              .lower_margin   = 7,
              .hsync_len      = 60,
              .vsync_len      = 10,
       .bus = -1,
       .addr      = 0,
       .detect    = NULL,
       .mode     = {
              .name           = "HDMI",
              .refresh        = 60,
              .xres           = 640,
              .yres           = 480,
              .pixclock       = 39721,
              .left_margin    = 48,
              .right_margin   = 16,
              .upper_margin   = 33,
              .lower_margin   = 10,
              .hsync_len      = 96,
              .vsync_len      = 2,
              .sync           = 0,
 这样就实现了我们的目的,被这个问题所困扰的朋友们可以去试试啦,希望能够帮助到大家!
关键词: uboot
