电子产品世界 » 论坛首页 » 综合技术 » 电源与模拟 » 51单片机进行​LED数码管扫描,程序如何减少代码量?
2020-03-16 17:12:21     打赏
最近弄LED段式数码管程序(采用扫描段码方式),但是编写后发现代码多,不知如何可以减少代码量。
//===          显示扫描函数          ===//
void display_scan(void)
    unsigned char i;
    P1 &= Bin(11111110);
    P1 |= Bin(11111000);
    P2 &= Bin(00000000);
    P3 &= Bin(01100111);
    P3 |= Bin(01100110);  //关闭段码和位码,如共阳数码管(公共脚置低,段码置高)
    for(i = 0;i < 4;i ++)
        r_dis_data[i] = table_seg[r_dis_buff[i]];    //查LED段码表
    switch (r_dig_bit)                                      //在公共端接限流电阻,在数码管位数少时布线时有优势
        case 1:
            p_seg_a = 0;                                    //扫描a段
            if(r_dis_data[0] & 0x01) p_dig_1 = 1;  //如果r_dis_data[0]第0位为高,则需要点亮,反之则不点亮
            if(r_dis_data[1] & 0x01) p_dig_2 = 1;
            if(r_dis_data[2] & 0x01) p_dig_3 = 1;
            if(r_dis_data[3] & 0x01) p_dig_4 = 1;
            if(r_dis_buff[4] & 0x01) p_dig_5 = 1;
            if(r_dis_buff[5] & 0x01) p_dig_6 = 1;
            break;
        case 2:
            p_seg_b = 0;
            if(r_dis_data[0] & 0x02) p_dig_1 = 1;
            if(r_dis_data[1] & 0x02) p_dig_2 = 1;
            if(r_dis_data[2] & 0x02) p_dig_3 = 1;
            if(r_dis_data[3] & 0x02) p_dig_4 = 1;
            if(r_dis_buff[4] & 0x02) p_dig_5 = 1;
            if(r_dis_buff[5] & 0x02) p_dig_6 = 1;
            break;
        case 3:
            p_seg_c = 0;
            if(r_dis_data[0] & 0x04) p_dig_1 = 1;
            if(r_dis_data[1] & 0x04) p_dig_2 = 1;
            if(r_dis_data[2] & 0x04) p_dig_3 = 1;
            if(r_dis_data[3] & 0x04) p_dig_4 = 1;
            if(r_dis_buff[4] & 0x04) p_dig_5 = 1;
            if(r_dis_buff[5] & 0x04) p_dig_6 = 1;
            break;
        case 4:
            p_seg_d = 0;
            if(r_dis_data[0] & 0x08) p_dig_1 = 1;
            if(r_dis_data[1] & 0x08) p_dig_2 = 1;
            if(r_dis_data[2] & 0x08) p_dig_3 = 1;
            if(r_dis_data[3] & 0x08) p_dig_4 = 1;
            if(r_dis_buff[4] & 0x08) p_dig_5 = 1;
            if(r_dis_buff[5] & 0x08) p_dig_6 = 1;
            break;
        case 5:
            p_seg_e = 0;
            if(r_dis_data[0] & 0x10) p_dig_1 = 1;
            if(r_dis_data[1] & 0x10) p_dig_2 = 1;
            if(r_dis_data[2] & 0x10) p_dig_3 = 1;
            if(r_dis_data[3] & 0x10) p_dig_4 = 1;
            if(r_dis_buff[4] & 0x10) p_dig_5 = 1;
            if(r_dis_buff[5] & 0x10) p_dig_6 = 1;
            break;
        case 6:
            p_seg_f = 0;
            if(r_dis_data[0] & 0x20) p_dig_1 = 1;
            if(r_dis_data[1] & 0x20) p_dig_2 = 1;
            if(r_dis_data[2] & 0x20) p_dig_3 = 1;
            if(r_dis_data[3] & 0x20) p_dig_4 = 1;
            if(r_dis_buff[4] & 0x20) p_dig_5 = 1;
            if(r_dis_buff[5] & 0x20) p_dig_6 = 1;
            break;
        case 7:
            p_seg_g = 0;
            if(r_dis_data[0] & 0x40) p_dig_1 = 1;
            if(r_dis_data[1] & 0x40) p_dig_2 = 1;
            if(r_dis_data[2] & 0x40) p_dig_3 = 1;
            if(r_dis_data[3] & 0x40) p_dig_4 = 1;
            if(r_dis_buff[4] & 0x40) p_dig_5 = 1;
            if(r_dis_buff[5] & 0x40) p_dig_6 = 1;
            break;
        case 8:
            p_seg_h = 0;
            if(r_dis_data[0] & 0x80) p_dig_1 = 1;
            if(r_dis_data[1] & 0x80) p_dig_2 = 1;
            if(r_dis_data[2] & 0x80) p_dig_3 = 1;
            if(r_dis_data[3] & 0x80) p_dig_4 = 1;
            if(r_dis_buff[4] & 0x80) p_dig_5 = 1;
            if(r_dis_buff[5] & 0x80) p_dig_6 = 1;
            break;
        default:
            keyscan_process();      //按键扫描
            break;
    r_dig_bit ++;
    if(r_dig_bit >= 9)    //扫描时基
    r_dig_bit = 0;
    电路图如下:
    LED数码管驱动控制电路.pdf
    关键词: 数码管     LED     扫描     程序     驱动
