The MST43XXA series is a high input voltage (40V), low quiescent current, High PSRR linear regulator (LDO) able to provide 150mA load current.
The LDO features very fast response against line voltage transient and load current transient, and ensures no overshoot voltage during the LDO start up and short circuit recovery.
The device features integrated short-circuit and thermal shutdown protection.
The device is available with fixed output voltages of 3.0V, 3.3V, 3.6V and 5.0V, and available in SOT23 and SOT89 packages.
Application
Ø Battery-powered equipment
Ø Smoke detector and sensor
Ø Micro controller Applications
Ø Home Appliance
Features
Ø Low Quiescent Current:2uA
Ø High Input Voltage Rating:Up to 45V
Ø Output Current:150mA
Ø High PSRR:70dB at 1kHZ
Ø Dropout Voltage:70mV@10mA700mV@100mA
Ø Fixed Output Voltages:3.0V, 3.3V, 3.6V and 5.0V
Ø High VOUT accuracy : ±1%
Ø Good Transient Response
Ø Integrated Short-Circuit Protection
Ø Integrated Thermal Protection
Available Packages:
MST43XXATE MST43XXATE-A MST43XXATE-B MST43XXATE-C SOT23-3 MST43XXATS MST43XXATS-A MST43XXATS-B MST43XXATS-C SOT89-3 MST43XXATG SOT23-5
共1条
高输入电压(40V)、低静电流、高PSRR线性稳压器(LDO)MST43XXA
只看楼主 1楼
关键词: MST43XXA 稳压器 高输入 电压 电流 线性
共1条
有奖活动 | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! | |
【有奖活动】伙伴们:您的“需求”解决了吗? | |
抽奖了,抽奖了,金升阳医疗电源 |
打赏帖 | |
【换取手持数字示波器】+与同事对定时器输出相位可调PWM移相全桥控制分享被打赏50分 | |
【换取手持数字示波器】+LP-MSPM0L1306开发板试用体验+串口被打赏40分 | |
CC-RL编译器相关问题求助被打赏10分 | |
【换取手持数字示波器】+与同事对ESP-12开发调试经验分享被打赏50分 | |
【换取手持数字示波器】+同事tek示波器调试spi解析被打赏50分 | |
【换取手持数字示波器】+2.6寸墨水屏调试经验被打赏50分 | |
换取手持数字示波器+个人开关电源的设计经验被打赏50分 | |
【换取手持数字示波器】+【APT32F173测评】+URAT被打赏20分 | |
【换取手持数字示波器】CH32X035的定时器以及外部中断体验被打赏50分 | |
【换取手持数字示波器】CH32X035搭建开发环境(RISC-V)被打赏50分 |
