问
我自己用LPC2292做了一个板子,采用上海分公司提供的最新的底层驱动作实验,定时器中断计时1.25ms,但用秒表实测相差较多,大约是正常值的0.75。但我用试验教程的定时器中断测的结果很精确。我对比了两个底层驱动,没有发现本质的区别,只是新的驱动多了与系统相关的库函数的实现。我非常想弄清楚其中的原因。因为我作的产品要用定时器中断采样。请周工帮帮我,谢谢!
答 1:
那很明显是程序的问题,"库函数的实现"您指的是什么函数?
答 2:
库函数的实现
库函数的实现指的是以下的函数。在新的底层驱动里target.c里增加了以下的代码。不知以下代码如何更改?谢谢!
** 以下为一些与系统相关的库函数的实现
** 具体作用请ads的参考编译器与库函数手册
** 用户可以根据自己的要求修改
** The implementations for some library functions
** For more details, please refer to the ADS compiler handbook and The library
** function manual
** User could change it as needed
#include "rt_sys.h"
#include "stdio.h"
#pragma import(__use_no_semihosting_swi)
int __rt_div0(int a)
a = a;
return 0;
int fputc(int ch,FILE *f)
ch = ch;
f = f;
return 0;
int fgetc(FILE *f)
f = f;
return 0;
int _sys_close(FILEHANDLE fh)
fh = fh;
return 0;
int _sys_write(FILEHANDLE fh, const unsigned char * buf,
unsigned len, int mode)
fh = fh;
buf = buf;
len =len;
mode = mode;
return 0;
int _sys_read(FILEHANDLE fh, unsigned char * buf,
fh = fh;
buf = buf;
len =len;
mode = mode;
return 0;
void _ttywrch(int ch)
ch = ch;
int _sys_istty(FILEHANDLE fh)
fh = fh;
return 0;
int _sys_seek(FILEHANDLE fh, long pos)
fh = fh;
return 0;
int _sys_ensure(FILEHANDLE fh)
fh = fh;
return 0;
long _sys_flen(FILEHANDLE fh)
fh = fh;
return 0;
int _sys_tmpnam(char * name, int sig, unsigned maxlen)
name = name;
sig = sig;
maxlen = maxlen;
return 0;
void _sys_exit(int returncode)
returncode = returncode;
char *_sys_command_string(char * cmd, int len)
cmd = cmd;
len = len;
return 0;
** 用户可以根据自己的要求修改
** function manual
#include "rt_sys.h"
#include "stdio.h"
a = a;
return 0;
ch = ch;
f = f;
return 0;
int fgetc(FILE *f)
f = f;
return 0;
fh = fh;
return 0;
fh = fh;
buf = buf;
len =len;
mode = mode;
return 0;
fh = fh;
buf = buf;
len =len;
mode = mode;
return 0;
ch = ch;
fh = fh;
return 0;
fh = fh;
return 0;
fh = fh;
return 0;
fh = fh;
return 0;
name = name;
sig = sig;
maxlen = maxlen;
return 0;
cmd = cmd;
len = len;
return 0;
有奖活动 | |
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! | |
【有奖活动】伙伴们:您的“需求”解决了吗? |
打赏帖 | |
老胖子聊电路--分析一个反馈电路被打赏50分 | |
【换取手持数字示波器】+线性调整器理论知识分享被打赏40分 |
