president董事長
operator作業員
position職務
general manager總經理
special assistant 特助
deputy manager |\'depjuti| =vice manager副理
deputy supervisor =vice supervisor副課長
group leader組長
line leader線長
supervisor 課長
responsible department負責單位
Human Resources Department
人力資源部
Head count 人頭數
production department生產部門
planning department企劃部
QC Section品管課
stamping factory沖壓廠
painting factory烤漆廠
molding factory成型廠
administration/general affairs dept./總務部
production unit生產單位
meeting minutes會議記錄
distribution department分發單位
subject主題
conclusion結論
decision items決議事項
pre-fixed finishing date預定完成日
Color management 顏色管理
Visual management 目視管理
production capacity生產力
first count初盤
first check初盤復櫂
second count 復盤
second check復盤復核
quantity of physical inventory second count 復盤點數量
physical inventory盤點數量
physical count quantity帳面數量
difference quantity差異量
spare parts physical inventory list備品盤點清單
cause analysis原因分析
waste materials廢料
description品名
specification 規格
model機種
work order工令
revision版次
remark備注registration登記
registration card登記卡
to control管制
application form for purchase請購單
consume, consumption消耗
to notify通知
to fill in填寫
to collect, to gather收集
statistics統計
cosmetic inspection standard 外觀檢驗規範
computer case 電腦外殼(組件)
personal computer enclosure 電腦機箱產品
front plate前板
rear plate后板
chassis |\'∫鎠i| 基座
bezel panel面板
Hood 上蓋
base pan 基座
bezel 面板
riser card 擴充卡
flat cable 排線
TOP driver cage 上磁架
bottom driver cage 下磁架
resin film 樹脂膜
raw materials原料
materials物料
steel plate鋼板
roll/coil material捲料
spare parts =buffer備品
plastic parts塑膠件
sheet metal parts/stamping parts 沖件
material check list物料檢查表
finished product成品
semi-finished product半成品
good product/accepted goods/ accepted parts/good parts良品
defective product/non-good parts不良品
disposed goods處理品
warehouse/hub倉庫
packing material包材
basket蝴蝶竺
plastic basket膠筐
flow chart流程表單
production tempo生產進度現狀
lots of production生產批量
manufacture procedure制程
to revise, modify修訂
to switch over to, switch—to, switching over切換
engineering bottleneck, project difficulty工程瓶頸
glove(s)手套
glove(s) with exposed fingers割手套
Band-Aid創可貼
Industrial alcohol工業酒精
broom掃把
mop拖把
vacuum cleaner吸塵器
rag 抹布
garbage container灰箕
garbage can垃圾箱
garbage bag垃圾袋
liaison聯絡單
rags抹布
lamp holder燈架
to mop the floor拖地
to clean a table擦桌子
air pipe 氣管
delivery deadline交貨期
die worker模工
production, to produce生產
equipment設備
resistance電阻
beacon警示燈
coolant冷卻液
crusher破碎機
club car高爾夫球車
plate電鍍
power button電源按鍵
reset button重置鍵
forklift叉車
Workshop traveler 天車
trailer =long vehicle拖板車
Hydraulic trolley手壓車
hydraulic hand jack油壓板車
casing = containerization裝箱velocity速度
patent專利
coordinate座標
supply and demand供求
career card履歷卡
barricade隔板
carton box紙箱
to pull and stretch拉深
work cell/work shop工作間
sub-line支線
品質人員名稱類
QC quality control 品質管理人員
FQC final quality control 終點品質管制人員
IPQC in process quality control 制程中的品質管制人員
OQC output quality control 最終出貨品質管制人員
IQC incoming quality control 進料品質管制人員
TQC total quality control 全面質量管理
POC passage quality control 段檢人員
QA quality assurance 質量保證人員
OQA output quality assurance 出貨質量保證人員
QE quality engineering 品質工程人員
品質保證類
FAI first article inspection 新品首件檢查
FAA first article assurance 首件確認
CP capability index 能力指數
CPK capability process index 模具製程能力參數
SSQA standardized supplier quality audit 合格供應商品質評估
FMEA failure model effectiveness analysis 失效模式分析
FQC運\作類
AQL Acceptable Quality Level 運\作類允收品質水準
S/S Sample size 抽樣檢驗樣本大小
ACC Accept 允收
REE Reject 拒收
CR Critical 極嚴重的
MAJ Major 主要的
MIN Minor 輕微的
Q/R/S Quality/Reliability/Service 品質/可靠度/服務
P/N Part Number 料號
L/N Lot Number 批號
AOD Accept On Deviation 特采
UAI Use As It 特采
FPIR First Piece Inspection Report 首件檢查報告
PPM Percent Per Million 百萬分之一
制程統計品管專類
SPC Statistical Process Control 統計製程管制
SQC Statistical Quality Control 統計品質管制
GRR Gauge Reproductiveness & Repeatability 量具之再制性及重測性判斷量可靠與否
DIM Dimension 尺寸
DIA Diameter 直徑
N Number 樣品數
其它品質術語類
QIT Quality Improvement Team 品質改善小組
ZD Zero Defect 零缺點
QI Quality Improvement 品質改善
QP Quality Policy 目標方針
TQM Total Quality Management 全面品質管理
RMA Return Material Audit 退料認可
7QCTools 7 Quality Control Tools 品管七大手法
通用之件類
ECN Engineering Change Notice 工程變更通知(供應商)
ECO Engineering Change Order 工程改動要求(客戶)
PCN Process Change Notice 工序改動通知
PMP Product Management Plan 生產管制計劃
SIP Standard Inspection Procedure 製程檢驗標準程序
SOP Standard Operation Procedure 製造作業規範
IS Inspection Specification 成品檢驗規範
BOM Bill Of Material 物料清單
PS Package Specification 包裝規範
SPEC Specification 規格
DWG Drawing 圖面
系統文件類
ES Engineering Standard 工程標準
CGOO China General PCE龍華廠文件
IWS International Workman Standard 工藝標準
ISO International Standard Organization 國際標準化組織
GS General Specification 一般規格
部類
PMC Production & Material Control 生產和物料控制
PCC Product control center 生產管制中心
PPC Production Plan Control 生產計劃控制
MC Material Control 物料控制
DC Document Center 資料中心
QE Quality Engineering 品質工程(部)
QA Quality Assurance 品質保證(處)
QC Quality Control 品質管制(課)
PD Product Department 生產部
LAB Laboratory 實驗室
IE Industrial Engineering 工業工程
R&D Research & Design 設計開發部
生產類
PCs Pieces 個(根,塊等)
PRS Pairs 雙(對等)
CTN Carton 卡通箱
PAL Pallet/skid 棧板
PO Purchasing Order 采購訂單
MO Manufacture Order 生產單
D/C Date Code 生產日期碼
ID/C Identification Code (供應商)識別碼
SWR Special Work Request 特殊工作需求
L/N Lot Number 批號
P/N Part Number 料號
OEM Original Equipment Manufacture 原設備製造
PC Personal Computer 個人電腦
CPU Central Processing Unit 中央處理器
A.S.A.P As Soon As Possible 盡可能快的
E-MAIL Electrical-Mail 電子郵件
N/A Not Applicable 不適用
QTY Quantity 數量
I/O input/output 輸入/輸出
NG Not Good 不行,不合格
C=0 Critical=0 極嚴重不允許
APP Approve 核準,認可,承認
CHK Check 確認
ASS\'Y Assembly 裝配,組裝
T/P True Position 真位度
5WIH When, Where, Who, What, Why, How to
6M Man, Machine, Material, Method, Measurement, Message
4MTH Man, Material, Money, Method, Time, How 人力,物力,財務,技術,時間(資源)
SQA Strategy Quality Assurance 策略品質保證
DQA Design Quality Assurance 設計品質保證
MQA Manufacture Quality Assurance 製造品質保證
SSQA Sales and service Quality Assurance 銷售及服務品質保證
LRR Lot Reject Rate 批退率
SPS Switching power supply 電源箱
DT Desk Top 臥式(機箱)
MT Mini-Tower 立式(機箱)
DVD Digital Video Disk
VCD Video Compact Disk
LCD Liquid Crystal Display
CAD Computer Aided Design
CAM Computer Aided Manufacturing
CAE Computer Aided Engineering
PCB Printed Circuit Board 印刷電路板
CAR Correction Action Report 改善報告
NG Not Good 不良
WDR Weekly Delivery Requirement 周出貨要求
TPM Total Production Maintenance 全面生產保養
MRP Material Requirement Planning 物料需計劃
OS Operation System 作業系統
TBA To Be Assured 待定,定缺
D/C Drawing Change
P/P Plans & Procedure
EMI Electrical-Music Industry 電子音樂工業
Electrical Magnetic Interference 電子干扰
RFI Read Frequency Input 讀頻輸入
MMC Maximum Material Condition
MMS Maximum Material Size
LMC Least Material Condition
LMS Least Material Size
LED lighting-emitting diode 發光二极管
QBR Quarter Business Record
CIP Continuous improvement process
FGI Forecasted Goal Inventory
CNC Computerized numeral controller
B2C Business to customer
B2B Business to business
AVL Approved vendor list
POP Procedure of packaging
EOL End of life
VDCS Vender defect correcting sheet
PDCS Process defect correcting sheet
GRN Goods receiving note
A/R Accounting receivable
A/P Accounting payable
一:常用術語
PCEG Personal Computer Enclosure group 個人電腦外設事業群(FOXTEQ)
CCBG Connector&cable business group
CPBG Competition business group
ESBG Enterprise system business group 鴻富錦\事業群
SABG system assembly business group 系統組裝事業群
NWE Net Work Enclosure
NSE Network system enclosure
NSG Network system group
NFE Network flexible enclosure
Foxcavity = HZ = Hong Zhun 鴻準
Stamping tool shop I 沖模一廠
Stamping tool shop II 沖模二廠
Prototype workshop 樣品中心
Steel factory 裁剪廠
PCE molding tooling workshop PCE塑模廠
Hua Nan test and measurement center 華南檢測中心
MPE mobile phone enclosure MPE
MBE mobile phone and notebook enclosure 明塑厂
MGE Alloy magnesium alloy enclosure 鎂合金
Engineer standard 工標
Document center (database center)資料中心
Design Center 設計中心
Painting 烤漆(廠) Assembly組裝(廠)
Stamping 沖壓(廠)
Education and Training教育訓練
proposal improvement/creative suggestion提案改善
Technological exchange and study 技術交流研習會
Technology and Development Committee 技術發展委員會
BS Brain Storming 腦力激蕩
QCC Quality Control Circle 品質圈
PDCA Plan Do Check Action 計劃 執行 檢查 總結
DCC delivery control center 交貨管制中心
3C
Computer 電腦類產品
Consumer electronics 消費性電子產品
Communication 通訊類產品
Core value(核心价值)
Love 愛心
Confidence 信心
Decision 決心
3T STRATEGY
Time to market 及時切入生產
Time to volume 及時大量生產
Time to money 及時大量交貨
FOUR CONTROL YSTEM 四大管制系統
Engineering control system 工程管制系統
Quality control system品質管制系統
Manufacturing control system生產管制系統
Management control system經營管制系統
