共1条
ARM的大端和小端 - 网上找到的
First thing I'd say is don't be confused by "Big Endian" on ARM. There
aren't 2 endian-nesses available with ARM, there's 4:
1. little endian with devices connected little endian
2. little endian with devices connected big endian
3. big endian with devices connected little endian
4. big endian with devices connected big endian
Only (1) and (4) are true little/big endian. (2) and (3) are fake.
Each one of these needs handling, since I believe most people refer to (3)
as big endian, which is, according to the ARM manuals, incorrect. In other
words, you can't just take as assabet, switch the endian bit in the control
register and say "I have a big endian machine".
Why do these have to be handled differently? Each one affects the way words
and bytes are accessed in peripherals, and may or may not result in a greater
amount of code to sort out the endian issues.
It is debatable whether the (3) is really worth the effort due to the code
that gets added into critical functions.
Ok, here's why. The following describe the layout of bytes that ARM
processors expect on the data bus. A word is always D31-D0 = bit 31 - bit 0.
关键词: 大端 小端 网上 找到
共1条
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! | |
【有奖活动】伙伴们:您的“需求”解决了吗? | |
抽奖了,抽奖了,金升阳医疗电源 |
打赏帖 | |
【换取手持数字示波器】+与同事对定时器输出相位可调PWM移相全桥控制分享被打赏50分 | |
【换取手持数字示波器】+LP-MSPM0L1306开发板试用体验+串口被打赏40分 | |
CC-RL编译器相关问题求助被打赏10分 | |
【换取手持数字示波器】+与同事对ESP-12开发调试经验分享被打赏50分 | |
【换取手持数字示波器】+同事tek示波器调试spi解析被打赏50分 | |
【换取手持数字示波器】+2.6寸墨水屏调试经验被打赏50分 | |
换取手持数字示波器+个人开关电源的设计经验被打赏50分 | |
【换取手持数字示波器】+【APT32F173测评】+URAT被打赏20分 | |
【换取手持数字示波器】CH32X035的定时器以及外部中断体验被打赏50分 | |
【换取手持数字示波器】CH32X035搭建开发环境(RISC-V)被打赏50分 |
