电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » One-Wire Network Controls Remote SPI Per
One-Wire Network Controls Remote SPI Peripherals
2012-04-04 08:41:54     打赏
关键词: 1-wire networks, 1-wire switches, SPI peripherals, edge detector, one shot
Abstract: To produce the 3-wire SPI™ interface required by a MAX7221 display controller (active-low CS, DIN, and CLK), this 1-Wire® network serially addresses three 1-Wire switches (DS2413). The first switch creates Chip Select directly (active-low CS), the second creates the serial-data line directly (DIN), and the third switch—with the help of three exclusive-OR gates—creates the serial clock (CLK).
 One-Wire Network Controls Remote SPI Peripherals.pdf
关键词: One-Wire     Network     Controls
