关键词: sensor compensation, integrated circuit, ic, compensation algorithm, piezoresistive, prt, pressure sensors, temperature
Abstract: A descriptive tutorial is presented for compensating pressure sensors using the MAX1463 Low-Power, Two-Channel Sensor Signal Processor. A mathematical description of the algorithm is given with an example of a pressure sensor compensation using real data. The low level transducer signal is amplified and temperature compensated to form a complete high signal level sensor.
