电子产品世界 » 论坛首页 » 企业专区 » TI » 【技术应用】为TMS320VC5503/06/07/09A DSP的电路板和系统
【技术应用】为TMS320VC5503/06/07/09A DSP的电路板和系统设计注意事项
2012-04-17 22:25:16     打赏
摘要:
An effective system-level board design requires termination of specific pins and taking advantage of idle and power-down modes on these low power VC5503/5506/5507/5509A digital signal processors (DSPs). This can be achieved by controlling unused pins and dynamically turning off all peripherals and internal functional units when not in use. The benefit is that the DSP and application consume only as much power as needed, which also helps reduce heat, component density, and the cost of the product. This document also provides pointers to valuable information about how to terminate some of the VC5503/5506/5507/5509A peripherals’ and core DSPs unused pins.
文档:sprab14.pdf
链接:http://www.ti.com.cn/general/cn/docs/litabsmultiplefilelist.tsp?literatureNumber=sprab14
关键词: 技术应用     TMS320VC5503     电路板     系统
