电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 拆个传说中的slc颗粒工业宽温SD卡
拆个传说中的slc颗粒工业宽温SD卡
2013-09-05 14:47:19     打赏
     一直想知道工业用的SD卡和普通的SD卡有什么区别,这次搞到一些台湾INNODISK的工业用宽温SD卡,slc颗粒4G容量,工作温度-55°C ~ +95°C,带ECC数据校验,版权保护,30u”镀金手指等等,拆一片看看到底是不是真的这么神!
个人也不是专业人员,有些内容需要请大家指教
The Innodisk Industrial SD card is a slim, SLC-based storage solution designed for portable devices. With a built-in ECC function, it can help detect and correct errors during data transfer. It is also compatible with SD 1.1 and SD 2.0 standards, and supports SDHC Class 10 and SPI modes. Innodisk’s Industrial SD card consumes little power and is available in capacities ranging from 128MB to 16GB.
      Features
  • Support static and global wear leveling
  • S.M.A.R.T Supported
  • Intelligent system for error recovery
  • Excellent data transfer speed
  • Enhanced power cycling
  • Golden finger 30u”
Model Name:Industrial SLC SD Card
Interface:SD 1.01/2.00
Type:Standard
Flash Type:SLC
Capacity:128MB~32GB
Max. Channels:1
Sequential R/W (MB/sec, max.):20/16
Max. Power consumption:0.2W (3.3V x 60mA)
H/W Write Protect:Y
S.M.A.R.T.:Y
Dimension (WxLxH/mm):24 x 32 x 2.1
Vibration:5G@7~2000Hz
Shock:50G@0.5ms
MTBF:3 million hours
Storage Temperature:-55°C ~ +95°C
Operation Temperature
Standard Grade: 0°C ~ +70°C;
Industrial Grade. OP: -40°C ~ +85°C
关键词: 拆个     传说     中的     颗粒     工业     宽温
