电子产品世界 » 论坛首页 » 高校专区 » 周师电子设计创新社区 » EDA第4次
EDA第4次
2015-01-06 23:03:34     打赏
3-3 试分别用IF_THEN语句、WHEN_ELSECASE语句的表达方式写出4选一多路选择器的VHDL程序,选通控制端有4个输入:S0,S1,S2,S3。当且仅当S0=0时:Y=A;S1=0时:Y=B;S2=0Y=C;S3=0Y=D
1.IF_THEN语句:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY MUX41A IS
      PORT(
        A,B,C,D,S0,S1,S2,S3 :  IN  STD_LOGIC;
                       Y:  OUT  STD_LOGIC
END ENTITY MUX41A;
ARCHITECTURE BHV OF MUX41A IS
SIGNAL  S :  STD_LOGIC_VECTOR (3 DOWNTO 0);
BEGIN
S<=S3 & S2 & S1 & S0;
PROCESS(S3,S2,S1,S0)  BEGIN
     IF (S=1110) THEN Y<=A;
ELSIF (S=1101”) THEN Y<=B;
ELSIF (S=1011”) THEN Y<=C;
ELSIF (S=0111”) THEN Y<=D;
END IF;
END PROCESS;
END ARCHITECTURE BHV;
2.WHEN_ELSE语句:
LIBRARY IEEE;
ENTITY MUX41A IS
      PORT(
                       Y:  OUT  STD_LOGIC
END ENTITY MUX41A;
BEGIN
      S<= S<=S3 & S2 & S1 & S0;
      Y<=A WHEN  S=1110 ELSE;
      B WHEN  S=1101”  ELSE;
  C WHEN  S=1011”  ELSE
D WHEN S=0111”  ELSE
3.CASE语句
LIBRARY IEEE;
ENTITY MUX41A IS
      PORT(
                       Y:  OUT  STD_LOGIC
END ENTITY MUX41A;
BEGIN
CASE (S) IS
 WHEN1110 =>Y<=A;
WHEN1101 =>Y<=B;
WHEN1011 =>Y<=C;
WHEN0111 =>Y<=D;
WHEN  OTHERS => NULL;
END CASE;
END PROCESS;
4WITH SELECT语句:
LIBRARY IEEE;
ENTITY MUX41A IS
      PORT(
                       Y:  OUT  STD_LOGIC
END ENTITY MUX41A;
BEGIN
WITH S SELECT
Y<=A  WHEN 1110
Y<=B  WHEN 1101”;
Y<=C  WHEN 1011”;
Y<=D  WHEN 0111”;
UNAFFECTED WHEN OTHERS;
3-4 给出全减器的VHDL描述。要求:
(1)          首先设计半减器,然后用例化语句将它们连接起来,h_suber是半减器,diff是输出差,s_out是借位输出,
Sub_in是借位输入。
(2)          根据图设计全减器。以全减器为基本硬件,构成串行借位的8位减法器,要求用例化语句来完成此项目。(减法运算是 x-y-sub_in=diffr
答:半减器:
LIBRARY IEEE;
ENTITY h_suber IS
PORT (
          x, y:  IN  STD_LOGIC;
     diff , s_out:  OUT  STD_LOGIC
END ENTITY h_suber;
ARCHITECTURE one OF h_suber IS
   BEGIN
     Diff   <=  x XOR y;
s_out  <=(NOT x ) AND y;
END ARCHITECTURE one;
二输入或门;
LIBRARY IEEE;
ENTITY or2a IS
PORT (
          a, b:  IN  STD_LOGIC;
            c:  OUT  STD_LOGIC
END ENTITY or2a;
ARCHITECTURE one1 OF or2a IS
   BEGIN
   c  <=  a OR b;
END ARCHITECTURE one1;
全加器:
LIBRARY IEEE;
ENTITY f_suber IS
  PORT (
x,y, Sub_in: IN  STD_LOGIC;
      diffr , sub_out: OUT  STD_LOGIC
END ENTITY f_suber;
ARCHITECTURE fd2 OF f_suber IS
   COMPONENT h_suber
PORT (
         x, y:  IN  STD_LOGIC;
COMPONENT or2a
PORT (
         a, b:  IN  STD_LOGIC;
           c:  OUT  STD_LOGIC
END COMPONENT;
SIGNAL net1, net2 ,net3 :  STD_LOGIC;
BEGIN
U1 : h_suber PORT MAP(x=>x,y=>y, s_out=>net2, diff=>net1);
U2: h_suber PORT MAP(net1, Sub_in, net3, diffr);
U3:  or2a PORT MAP( a=>net2,b=>net3,c=> sub_out);
END ARCHITECTURE fd2;
      8位减法器:
LIBRARY IEEE;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTUTY suber8B IS
PORT (
         A, B:  IN  STD_LOGIC_VECTOR(7 DOWNTO 0);
        COUT: OUT  STD_LOGIC;
DOUT: OUT  STD_LOGIC_VECTOR(7 DOWNTO 0);
END ENTUTY suber8B;
ARCHITECTURE  BHV OF suber8B IS
SIGNAL DATA :  STD_LOGIC_VECTOR(8 DOWNTO 0);
    BEGIBN
DATA <=(‘0’ & A)+ (‘0’ & B)+ (‘00000000’ & Sub_in);
COUT <=DATA (8);
DOUT <=DATA (7 DOWNTO 0);
关键词: 3-8     译码器
