电子产品世界 » 论坛首页 » 综合技术 » 通讯及无线技术 » 如何在工模下面读取蓝牙本机地址
如何在工模下面读取蓝牙本机地址
2017-09-14 17:59:37    评分
可以参考:alps/mediatek/factory/src/util/ftm_bt_op.c
在 ftm_bt_op.c文件中添加如下函数:
static BOOL BT_Read_LocalAddr(void)
DBG("BT_Read_LocalAddr\n");
UCHAR HCI_READ_LOCAL_ADDR[] = {0x01, 0x09, 0x10, 0x00};
UCHAR pAckEvent[13];
UCHAR ucEvent[] = {0x04, 0x0E, 0x0a, 0x01, 0x09, 0x10};
if (!glib_handle){
ERR("mtk bt library is unloaded!\n");
return FALSE;
if (bt_fd < 0){
ERR("bt driver fd is invalid!\n");
return FALSE;
if(bt_send_data(bt_fd, HCI_READ_LOCAL_ADDR, sizeof(HCI_READ_LOCAL_ADDR)) < 0){
ERR("Send read BD_ADDR command fails errno %d\n", errno);
return FALSE;
if(bt_receive_data(bt_fd, pAckEvent, sizeof(pAckEvent)) < 0){
ERR("Receive event fails errno %d\n", errno);
return FALSE;
if(memcmp(pAckEvent, ucEvent, sizeof(ucEvent))){
ERR("Receive unexpected event\n");
return FALSE;
}else{
DBG("Read LOCAL BD_ADDR: lup:0x%x-0x%x-0x%x,uap:0x%x,nap:0x%x-0x%x\n",
pAckEvent[7],pAckEvent[8],pAckEvent[9],pAckEvent[10],pAckEvent[11],pAckEvent[12]);
return TRUE;
然后在:FM_BT_init()函数中
BG("BT is enabled success\n");
这句下面调用此函数
BT_Read_LocalAddr();
然后有下列方法编译及测试
1. ./mk mediatek/factory
2. ./mk snod
3. enter factory mode:Press volume down and Power Key.
4. adb shell logcat
5. enter bluetooth test item.
6. you will see the BD_ADDR read Log .
Thanks
关键词: mtk
