电子产品世界 » 论坛首页 » 行业应用 » 消费电子 » 瑞萨通信网络的网络监视头解决方案
瑞萨通信网络的网络监视头解决方案
2017-12-26 16:02:20    评分
  方案描述:
  The Renesas SH-MobileR2R (SH7724) microcontroller equipped with the MS7724 Linux platform is optimal for network camera applications. The platform comes with the Linux Kernel BSP (Board Support Package) sample program, and software for system development such as evaluation middleware (H.264/MPEG4 codec middleware) and sample applications, making it possible to start device evaluation and system development immediately after purchase, which helps shorten system development time. The MS7724 can encode and decode HD (1280 x 720) size images at 30 fps, satisfying the demand for higher image quality for network cameras. In addition, the SH-MobileR2R (SH7724) has two channels of camera input, making it a highly versatile device that is optimal for products using camera monitoring functions. By utilizing the H.264/MPEG4 codec and JPEG codec that are built-in as hardware IP and the 10/100 Mbps Ether MAC and LCD controller, the SH-MobileR2R (SH7724) can be used not only in network cameras but also in applications such as digital signage systems, TV conference systems, automotive backing & side monitoring, and drive recorders. The Renesas lineup of front-end ICs (R2J450xx series) and ASSPs such as motor drivers (R2A304xxBM series) is also suitable for use in the camera unit.
  方案设计图:
方案关键器件表:
类型
型号
厂商
说明
Microprocessor
R8A77240D500BG
Renesas
High performance, low power consumption,supports HD playback/recording support
Motor driver IC
R2A304xxBM
Renesas
Compact, thin, low power consumption
Reset IC
RNA50C27
Renesas
For 3.3V, 1.8V dual power supply MCU
Power MOS FET
HAT1021R, other
Renesas
Low on-resistance, high-speed switching, small package
  网络摄像头是传统摄像机与网络视频技术相结合的新一代产品,除了具备一般传统摄像机所有的图像捕捉功能外,机内还内置了数字化压缩控制器和基于WEB的操作系统,使得视频数据经压缩加密后,通过局域网,internet或无线网络送至终端用户。而远端用户可在PC上使用标准的网络浏览器,根据网络摄像机的IP地址,对网络摄像机进行访问,实时监控目标现场的情况,并可对图像资料实时编辑和存储,同时还可以控制摄像机的云台和镜头,进行全方位地监控。
  镜头
  镜头作为网络摄像机的前端部件,有固定光圈、自动光圈、自动变焦、自动变倍等种类,与模拟摄像机相同。
  图像声音传感器
  图像传感器有CMOSCCD两种模式。CMOS既互补性金属氧化物半导体,CMOS主要是利用硅和锗这两种元素所做成的半导体,通过CMOS上带负电和带正电的晶体管来实现基本的功能的。这两个互补效应所产生的电流即可被处理芯片记录和解读成影像。CMOS针对CCD最主要的优势就是非常省电。不像由二极管组成的CCDCMOS电路几乎没有静态电量消耗。这就使得CMOS的耗电量只有普通CCD1/3左右,CMOS重要问题是在处理快速变换的影像时,由于电流变换过于频繁而过热。暗电流抑制的好就问题不大,如果抑制的不好就十分容易出现坏点。
  CCD图像传感器由在单晶硅基片上呈二维排列的光电二级管及其传输电路构成。光电二极管把光转化成电荷,再经转化电路传送和输出。通常,传送优良图像质量的设备都采用CCD图像传感器,而注重功耗和成本的产品则选择CMOS图像传感器。但新的技术正在克服每种器体固有的弱点,同时保留了适合于特定用途的某些特性。这一部分与模拟摄像机相同。声音传感器即拾声器或叫麦克风,与传统的话筒原理一样。
  A/D转换器
  A/D转换器的功能是将图像和声音等模拟信号转换成数字信号。
  基于CMOS模式的图像传感器模块有直接数字信号输出的接口,无须A/D转换器;而基于CCD模式的图像传感器模块如有直接数字输出的接口,亦无须A/D转换器,但由于此模块主要针对模拟摄像机设计,只有模拟输出接口,故需要进行A/D转换。
  图像声音编码器
  经A/D转换后的图像、声音数字信号,按一定的格式或标准进行编码压缩。编码压缩的目的是为了便于实现音/视信号与多媒体信号的数字化;便于在计算机系统、网络以及万维网上不失真地传输上述信号。
https://www.iczoom.com/quotation/sof-sdesc-b-p-q-c-m-1-10.html?param=
关键词: 网络监视头
