电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » clone-graph
clone-graph
2018-01-30 12:08:29     打赏
Clone an undirected graph. Each node in the graph contains alabeland a list of itsneighbors.
OJ's undirected graph serialization:
Nodes are labeled uniquely.
We use#as a separator for each node, and,as a separator for node label and each neighbor of the node.
As an example, consider the serialized graph{0,1,2# 1,2# 2,2}.
The graph has a total of three nodes, and therefore contains three parts as separated by#.
  1. First node is labeled as0. Connect node0to both nodes1and2.
  2. Second node is labeled as1. Connect node1to node2.
  3. Third node is labeled as2. Connect node2to node2(itself), thus forming a self-cycle.
Visually, the graph looks like the following:
       1
    0 --- 2
         \_/
题意:
克隆一个无向图,途中的每个节点包含一个标签及其邻居的列表
Oj对于无向图的序列化;
节点的标签是唯一的。
我们使用#作为节点的分割符,使用逗号,作为节点标签以及每个邻居之间的分割符;
例如,考虑序列化图0,1,2#1,2#2,2
上图包含三个几点,
第一个节点标签为0, 节点0与节点1、2相连;
第二个节点标签为1,节点1与节点2相连;
第三个节点为2,节点2与节点2相连,形成了一个环;
这道题主要是数据结构的应用吧,用一个队列存放途中还未被访问的节点,
用一个map存放克隆的新节点。对于队列中的节点,访问其邻居节点,如果该
邻居已经被克隆,那么只需要维护克隆节点之间的邻居关系即可,如果该邻居
尚未被克隆,那么需要new一个新节点作为它的克隆,并维护克隆后的邻居关系;
[cpp] view plain copy
  1. class Solution {
  2. public:
  3.
  4.     map<int,UndirectedGraphNode*> record;
  5.     UndirectedGraphNode *clone(UndirectedGraphNode *node) {
  6.         UndirectedGraphNode *ngraph,*p;
  7.         map<int,UndirectedGraphNode*>::iterator iter;
  8.         p=node;
  9.         iter=record.find(p->label);
  10.         if(iter!=record.end())
  11.             return iter->second;
  12.         ngraph=new UndirectedGraphNode(p->label);
  13.         record.insert(map<int,UndirectedGraphNode*>::value_type(p->label,ngraph));
  14.         for(int i=0;i<p->neighbors.size();i++){
  15.             ngraph->neighbors.push_back(clone(p->neighbors[i]));
  16.         }
  17.         return ngraph;
  18.     }
  19.     UndirectedGraphNode *cloneGraph(UndirectedGraphNode *node){
  20.         UndirectedGraphNode *ngraph;
  21.         if(node==NULL)
  22.             return NULL;
  23.         record.clear();
  24.         ngraph=clone(node);
  25.         return ngraph;
  26.     }
  27. };
2018-01-31 10:44:10     打赏
听上去就非常非常的高深了
