共4条
求几款廉价的USB全速单片机
like to inform you that I can solve the following difficult technical problems for you. ★ 超微超深细孔加工:可在金属上加工0.1mm以上的细孔,深度达到3mm. Manufacture capability of ultra-fine and ultra-deep for small bores: can machine holes with dia over 0.1mm, depth 3mm. ★ 五轴连动加工(瑞士米克朗) 5-axis continuum machining(Switzerland MIKRON) ★ 超细电极慢走丝线切割:瑞士阿奇夏米尔线切割,最细电极丝达到0.03mm,可进行超高光洁度(达到0.1μ),超细清角(最小尖角达到0.025mm)线切割加工. Ultra thin slow wire-cutting: Switzerland Agie Charmilles wire-cut, withthe thinnest 0.03mm, also capable of machining ultra-fine finish (0.1μ) and ultra-sharp angle (smallest 0.025mm). ★ 钨钢(硬质合金)成形加工:钨钢成型磨削、外园磨削. Tungsten steel (hard alloy) forming machining: tungsten forming grinding,cylindrical grinding. ★ 超长孔加工:最小孔径0.3mmX50mm(超长),公差在0.002mm. Ultra-long hole machining: smallest hole 0.3mmX50mm(super long), tolerance 0.002mm. ★ 精密外园磨削:超长、超细轴磨削,尺寸精度达到2μ,同轴跳动2μ以内. Precision cylindrical grinding: ultra-long and ultra-thin axis grinding, with precision to 2μ,coaxial jumping within 2μ. ★ 精密内,外螺纹磨削加工. Precision inner and outer thread grinding machining. ★ 精密镜面抛光,超平平面抛光. Precision mirror polishing. Ultra-flat surface polishing.
共4条
奖!发布技术笔记,技术评测贴换取您心仪的礼品 | |
【有奖活动】震撼来袭!这场直播将直击工程师的心灵! | |
【有奖活动】伙伴们:您的“需求”解决了吗? |
打赏帖 | |
老胖子聊电路--分析一个反馈电路被打赏50分 | |
