电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » [求助] scatterloading 错误
2006-02-22 00:12:08     打赏
重定向了_user_initial_stackheap,但仍出现以下错误
:Error : L6218E: Undefined symbol Image$$ZI$$Limit (referred from sys_stackheap.o)
AREA START, CODE, READONLY
CODE32
IMPORT _main
EXPORT Start
EXPORT _user_initial_stackheap
EXPORT stack_base
EXPORT heap_base
ENTRY
Start
BL InitStack
BL MAC7111Init
B _main
LDR R0, =heap_base
LDR R1, =stack_base
MOV PC, LR
InitStack
MOV R0, LR ;每种模式对应不同的LR,程序以管理员模式进入,以用户模式返回,所以要保存LR
MSR CPSR_c, #0xd3 ;设置管理员模式堆栈
LDR SP, StackSvc
MSR CPSR_c, #0xd1 ;设置FIQ模式堆栈
LDR SP, StackFIQ
MSR CPSR_c, #0xd2 ;设置IRQ模式堆栈
LDR SP, StackIRQ
MSR CPSR_c, #0xd7 ;设置中止模式堆栈
LDR SP, StackAbt
MSR CPSR_c, #0xdb ;设置未定义模式堆栈
LDR SP, StackUde
MSR CPSR_c, #0xdf ;设置SYS模式堆栈
LDR SP, =stack_base
MOV PC, R0
INTC_BASE EQU 0xFC048000
INTC_CFG EQU 0x0018
CRG_BASE EQU 0xFC088000
CRG_SYNR EQU 0x0000
CRG_RFDV EQU 0x0001
CRG_CLKSEL EQU 0x0005
CRG_PLLCTL EQU 0x0006
EIM_BASE EQU 0xFC008000
CASR0 EQU 0x0080 ;16BIT
CSMR0 EQU 0x0084 ;32BIT
CSCR0 EQU 0x0088 ;16BIT
CASR1 EQU 0x008C ;16BIT
CSMR1 EQU 0x0090
CSCR1 EQU 0x0094 ;16BIT
CASR2 EQU 0x0098 ;16BIT
CSMR2 EQU 0x009C
CSCR2 EQU 0x00A0 ;16BIT
;CASR0 EQU 0xFC008080
;CSMR0 EQU 0xFC008084
;CSCR0 EQU 0xFC008088
;CASR1 EQU 0xFC00808C
;CSMR1 EQU 0xFC008090
;CSCR1 EQU 0xFC008094
;CASR2 EQU 0xFC008098
;CSMR2 EQU 0xFC00809C
;CSCR2 EQU 0xFC0080A0
MAC7111Init
LDR R0, =CRG_BASE
LDR R1, =0x0
STRB R1, [R0, #CRG_CLKSEL] ;Fclk=Fosc=8MHz
STRB R1, [R0, #CRG_PLLCTL] ;PLL Disabled, Clock Monitor Disabled
;AT RESET ALL THE INTERRUPT ARE DISABLED
LDR R0, =EIM_BASE
LDR R1, =0x00000000
STR R1, [R0, #CASR1]
LDR R1, =0x00010001
STR R1, [R0, #CSMR1]
LDR R1, =0x000005A0
STR R1, [R0, #CSCR1]
LDR R1, =0x00300000
STR R1, [R0, #CASR2]
LDR R1, =0x00000001
STR R1, [R0, #CSMR2]
LDR R1, =0x000001A0
STR R1, [R0, #CSCR2]
LDR R1, =0x00020000
STR R1, [R0, #CASR0]
LDR R1, =0x000009A0
STR R1, [R0, #CSCR0]
LDR R1, =0x001F0000
STR R1, [R0, #CSMR0]
NOP
NOP
NOP
NOP
NOP
NOP
NOP
LDR R1, =0x001F0001
MOV PC, LR
AREA RAMDATA, DATA, READWRITE
StackIRQ SPACE 256
StackFIQ SPACE 256
StackSvc SPACE 256
StackAbt SPACE 256
StackUde SPACE 256
StackSys SPACE 256
AREA stack, DATA, NOINIT
stack_base SPACE 1024
AREA heap, DATA, NOINIT
heap_base SPACE 1024
END
scf文件
LOAD_RAM 0x00000000 ;加载域为RAM
RUN_RAM 0x00000000 0x5000 ;第一个运行时域,长20K Bytes
Vectors.o(vector, +First)
*(+RO)
ISR_table 0x00005000 ;256byte for 64 int sources
Vectors.o(ISRAddr, +First)
data 0x00005100
*(+RW, +ZI)
heaps 0x00006000 UNINIT
init.o(heap, +First)
stacks 0x00020000 UNINIT ;128K RAM的顶端
init.o(stack, +First)
关键词: 求助     scatterloading     错误
