电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » [求助]END驱动ping包问题
[求助]END驱动ping包问题
2006-12-29 18:13:14     打赏
新做了END驱动,放在相同的两块板子上相互ping对方,当ping包为64字节时,发现返回时间很长,且间隔960ms,ping包回应序列也不对,如下:
->ping "200.254.0.100",6
PING 200.254.0.100: 56 data bytes
64 bytes from 200.254.0.100: icmp_seq=0. time=0. ms
64 bytes from 200.254.0.100: icmp_seq=0. time=960. ms
64 bytes from 200.254.0.100: icmp_seq=0. time=1920. ms
64 bytes from 200.254.0.100: icmp_seq=0. time=2880. ms
64 bytes from 200.254.0.100: icmp_seq=1. time=2880. ms
64 bytes from 200.254.0.100: icmp_seq=1. time=3840. ms
----200.254.0.100 PING Statistics----
6 packets transmitted, 6 packets received, 0% packet loss
round-trip (ms) min/avg/max = 0/2080/3840
value = 0 = 0x0
查看了数据包的收发,200.254.0.100收到1个包后却回了2个包。驱动本身没有问题,是协议栈触发了驱动的两次发送中断。
于是我把ping包长度改大到2048(mtu 1500)却很正常如下:
->ping "200.254.0.100",5
PING 200.254.0.100: 2040 data bytes
2048 bytes from 200.254.0.100: icmp_seq=0. time=32. ms
2048 bytes from 200.254.0.100: icmp_seq=1. time=32. ms
2048 bytes from 200.254.0.100: icmp_seq=2. time=32. ms
2048 bytes from 200.254.0.100: icmp_seq=3. time=32. ms
2048 bytes from 200.254.0.100: icmp_seq=4. time=32. ms
5 packets transmitted, 5 packets received, 0% packet loss
round-trip (ms) min/avg/max = 32/32/32
value = 0 = 0x0
是不是工程哪里没配置对?还是哪些其他问题?请高手题点
关键词: 求助     驱动     包问题     问题     200.254.0.10
2007-01-06 19:46:00     打赏
有没有谁也碰到过这个情况啊?
